My wife getting scared
Old October 6th 07, 10:13 PM posted to rec.aviation.piloting
Morgans[_2_]
Default My wife getting scared
"Jay Honeck" wrote in message
Jay, old sport, I fear the problem is that you are *hearing* a foreign
language.
Whatever. If you guys don't believe that beating an engine won't kill
it quicker than babying it, because I lack "evidence", there's not
much else I can say but "To each, his own."
I will continue to fly my engine carefully and gently, nonetheless.
I think you may be starting to get defensive, now.
NOBODY here would think that an engine that is getting beaten will last as
long as an engine running at constant output.
The debate is whether running from idle, up to full power (gently) often
will be worse on it than constant output.
You and your mechanic have an opinion on the subject, and that is your
right.
I (and others) just don't agree that frequent power changes (done correctly)
are significantly detrimental to the life of your engine, and no studies or
numbers have been offered on either side to prove the case, either way.
Beat an engine, no contest. Beyond that, it all comes down to opinion.
That is all it could be, at this point.
Jim in NC
  #182
Old October 6th 07, 10:29 PM posted to rec.aviation.piloting
Matt Whiting
language.
And I'll continue to run mine as suggested by the service manager at the
BMW shop when I bought my 1200LT ... "run it like you stole it." He
said that BMW engines that weren't run hard right from the get-go tended
not to seat the rings well and then always had oil consumption issues.
So far, at nearly 4,000 miles, so good! The K engine really sings above
6 grand!
Matt
  #183
Old October 6th 07, 10:48 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Jay Honeck wrote in news:1191703656.050532.274020
@d55g2000hsg.googlegroups.com:
Ah, this is truly a rare alignment of the stars, to have all three of
these guys present in one thread...
My work here is done. I can achieve no higher goal.
A useful suggestion from a very experienced user of USENET: Never take
anything on USENET personally.
I never do. Been here a long time, and I ain't goin' anywhere...
Larry, Thomas, and, yes, even you, Anthony, would receive nothing but
hospitality (and a cold one or three) at my dinner table, should you
ever find your way to Iowa.
Well,if you could insert your dinner table into MSFS, he's there.
Bertie
  #184
Old October 6th 07, 11:20 PM posted to rec.aviation.piloting
B A R R Y
On Sat, 6 Oct 2007 21:48:46 +0000 (UTC), Bertie the Bunyip
There ya' go, Jay!
One of the pre-programmed "Adventure Flights" in MSFS should arrive at
the home airport of the Alexis Park Inn for the pre-OSH simulated pool
party!
The second leg of the flight could continue on to OSH.
You read it here first, folks!
  #185
Old October 6th 07, 11:28 PM posted to rec.aviation.piloting
B A R R Y wrote in
There ya' go, Jay!
party!
Actually, it coudl be done. If you go to one of the bulletin boards that
simmers hang out at someone could do that for you.
BTW, Anthony isn't exactly popular in those palces either.
Bertie
  #186
Old October 6th 07, 11:45 PM posted to rec.aviation.piloting
Jay Honeck
There ya' go, Jay!
party!
Well, it's almost been done. Go he
http://www.alexisparkinn.com/iowa_ci..._simulator.htm
to download free Iowa City enhanced scenery -- which includes detailed
renditions of the Alexis Park Inn & Suites!
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
  #187
Old October 6th 07, 11:51 PM posted to rec.aviation.piloting
Jay Honeck
6 grand!
With a motorcycle engine that is nearly disposable (and easily/cheaply
repairable) I agree 100%. Goose that hog till it squeals. Besides,
what's the worst thing that can happen if you blow it up?
With my aircraft engine, no way. Not only is my butt hanging
suspended two miles in the air, but the engine itself is currently
valued at nearly $30K. For that kind of money I will do things
gently, carefully, and by the book.
Jay Honeck
Iowa City, IA
Pathfinder N56993
  #188
Old October 7th 07, 12:16 AM posted to rec.aviation.piloting
B A R R Y
On Sat, 06 Oct 2007 15:45:13 -0700, Jay Honeck
I think you should pursue having it added to the retail distribution
CD package! Make sure the user passes "Atlas" and the Mighty Pea
while taxiing.
  #189
Old October 7th 07, 12:32 AM posted to rec.aviation.piloting
Matt Whiting
6 grand!
Does Lycoming tell you not to practice emergency landings? I hadn't
seen that before.
If believing a myth gives you comfort, then by all means. :-)
Matt
  #190
Old October 7th 07, 01:45 AM posted to rec.aviation.piloting
Mxsmanic
Jay Honeck writes:
Done! I shall try it out.
Scared of mid-airs Frode Berg Piloting 355 August 20th 06 05:27 PM
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
The kids are scared, was Saddam evacuated D. Strang Military Aviation 0 April 7th 04 10:36 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
