Cessna Anticipates AvGas Demise
Old October 7th 07, 09:25 PM posted to rec.aviation.piloting
Stefan
Default Cessna Anticipates AvGas Demise
Matt Whiting wrote:
I don't plan to buy one so I have no need to do the math. If you want
to prove a point, you do the math.
*I* don't want to prove anything. It was you who claimed that the life
span of the Thielert was too short to be competitive.
  #82
Old October 7th 07, 09:32 PM posted to rec.aviation.piloting
Stefan
Larry Dighera wrote:
So, are you saying that the FADEC will command a reduction in engine
power to reduce heating as the high-temp limit is approached?
I'm not absolutely sure on this, but I don't think so. I think it just
has an extremely efficient cooling system (overkill, so to speak) which
is regulated by FADEC, i.e. reduced to keep the engine temperature high
enough.
Of course I believe that if one really tries, one *will* find a way to
kill the engine. E.g. the POH forbids a sustained power setting of more
than 75%. Or, as others have pointed out, remove the coolant before
flight. Or if nothing else helps, take a sledge hammer.
  #83
Old October 7th 07, 10:21 PM posted to rec.aviation.piloting
Roy Smith
Matt Whiting wrote:
Roy Smith wrote:
Matt Whiting wrote:
It's fully FADEC controlled, so no overheating possible.
Automobile engines have been digitally controlled for two decades and
they still can overheat.
Yes, but they don't overheat because somebody set the wrong combination of
three different knobs.
What part of "so no overheating possible" didn't you understand? That
statement is simply factually incorrect.
Matt
Taken literally, the statement, "no overheating possible" is indeed
incorrect. But, FADEC still gives you a protection against most of the bad
things people do to engines through poor technique.
  #84
Old October 7th 07, 11:12 PM posted to rec.aviation.piloting
Matt Whiting
Stefan wrote:
Matt Whiting schrieb:
Drain the coolant and go flying. Tell me how long the FADEC prevents
the engine from overheating.
Yawn. Dry the oil and go flying.
So, you finally admit that the FADEC can't prevent overheating.
Matt
  #85
Matt Whiting
Matt
No question about it. That wasn't the statement made, however.
Matt
  #86
Old October 7th 07, 11:13 PM posted to rec.aviation.piloting
Matt Whiting
No, I never claimed that.
Matt
  #87
Old October 7th 07, 11:23 PM posted to rec.aviation.piloting
Stefan
Matt
You wrote:
Yes, this may be the case, however the TBR has to get closer to 4,000
hours than to 2,400. Most auto and truck diesels will last at least
twice as long as similar size gas engines, so with Lycs and Contis
lasting 2,000 hours fairly routinely, the Thielert needs to at least
double that ... unless the replacement cost is equivalent to an
overhaul of a Lyc or Conti.
Matt
Of curse I did completely misunderstand you. No, please don't explain.
It gets boring.
  #88
Old October 7th 07, 11:25 PM posted to rec.aviation.piloting
Stefan
FADEC can't prevent to become a moron, either.
  #89
Old October 7th 07, 11:31 PM posted to rec.aviation.piloting
Morgans[_2_]
"Matt Whiting" t wrote
I didn't see any details on their web site, but if they use a hydraulic
coupling then that should isolate the prop during a strike assuming proper
design of the hydraulic drive. There is likely though some loss of
efficiency as I don't know of any hydraulic drives that are 100%
efficient.
I read that a clutch protects the engine from prop strikes, and a harmonic
dampener isolates torsional harmonics. I take that to mean an isolation
rubber dampener, as is common in industrial motors and transmissions.
Jim in NC
  #90
Old October 7th 07, 11:39 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
"Morgans" wrote in news:lX9Oi.32$Mx6.29
@newsfe05.lga:
"Bertie the Bunyip" wrote
You try letting the coolant out?
That would definitely make it easier!
Only you would think of doing that. ;-))
Well, the manufacture hopefully would, but being German they would probably
say "this cannot happen"
Bertie
100/130 avgas Roy Smith General Aviation 1 December 24th 06 09:17 AM
Old AvGas gwengler Piloting 2 December 16th 06 01:07 PM
Survival and Demise Kit; Contest Points Jim Culp Soaring 1 June 21st 04 04:35 AM
The demise of the Sea Harrier Henry J Cobb Naval Aviation 39 April 25th 04 07:27 PM
Here's to Arafat's Speedy Demise robert arndt Military Aviation 0 September 12th 03 07:45 AM
