Cessna Anticipates AvGas Demise
Old October 7th 07, 11:43 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default Cessna Anticipates AvGas Demise
"Morgans" wrote in
"Bertie the Bunyip" wrote
Any airplane I've flown that has Fadec has some sort of manual
reversion.
Yes, but when you take off without any charge in your back-up battery,
it is the idiot at the stick bypassing the reversion that is the
problem.
It's irrelevant when you're talking design flaw. On that occasion it was
the idiot, but thre's a thousand ways the fadec can be robbed of sparks.
Every airplane I've flown with a fadec, ECU, EEC or whatever, has had soome
sort of limp home capability. This one does not. No electrics, no power.
I've had two Fadec malfunctions in the last four months whihc required a
disconnect and reversion to manual FCU. No big deal. 90 seconds n the
checklist and we were back to bitching about how hard our lives were
Bertie
  #92
Old October 8th 07, 12:22 AM posted to rec.aviation.piloting
Matt Whiting
Stefan wrote:
Matt Whiting wrote:
Drain the coolant and go flying. Tell me how long the FADEC
prevents the engine from overheating.
Yawn. Dry the oil and go flying.
So, you finally admit that the FADEC can't prevent overheating.
FADEC can't prevent to become a moron, either.
True, but that wasn't the original claim.
  #93
Old October 8th 07, 12:24 AM posted to rec.aviation.piloting
Matt Whiting
Stefan wrote:
Matt Whiting wrote:
*I* don't want to prove anything. It was you who claimed that the
life span of the Thielert was too short to be competitive.
No, I never claimed that.
Matt
You wrote:
Yes, this may be the case, however the TBR has to get closer to 4,000
hours than to 2,400. Most auto and truck diesels will last at least
twice as long as similar size gas engines, so with Lycs and Contis
lasting 2,000 hours fairly routinely, the Thielert needs to at least
double that ... unless the replacement cost is equivalent to an
overhaul of a Lyc or Conti.
Matt
Of curse I did completely misunderstand you. No, please don't explain.
It gets boring.
Yes, what part of "unless the replacement cost is equivalent to an
overhaul of a Lyc or Conti" wasn't clear?
Matt
  #94
Old October 8th 07, 12:26 AM posted to rec.aviation.piloting
Andrew Gideon
On Sat, 06 Oct 2007 20:03:28 +0000, Blueskies wrote:
Yup, gotta pay for the new improved NAS. JetA power GA aircraft are
going to pay more taxes per gallon than the 100LL drivers, so UnkaSam
wants more JetA sales...
The salespeople at AOPA were really cagey WRT the Diesel 172. As best
several of us can figure, this is for the overseas market.
The salesperson did mention, for example, that 100LL was not to be found
in South Africa. I've no idea whether or not this is true, but it seems
to indicate the target market at which this is aimed.
- Andrew
  #95
Old October 8th 07, 12:32 AM posted to rec.aviation.piloting
Blueskies
"Stefan" wrote in message ...
Blueskies wrote:
I think those Theilberts are throw away at 1800 hours or something...
You think wrongly. It's 2400.
Ok, so throw away the engine at 2400 hours...
  #96
Old October 8th 07, 12:37 AM posted to rec.aviation.piloting
Blueskies
Larry Dighera wrote:
Re ringing and doing valves are things that an air cooled engine may need often, but a diesel will probably not need
until it is replaced.
So the diesel is liquid cooled?
http://www.centurion-engines.com/
It's liquid cooled, so no discussion about shock cooling anymore.
It's fully FADEC controlled, so no overheating possible.
It's geared, so a prop strike doesn't affect the engine.
It's fully FADEC controlled, so always best prop pitch to the chosen power setting.
and and and... in short, everything I would expect from a modern engine.
http://www.avweb.com/avwebflash/news..._195091-1.html
  #97
Old October 8th 07, 10:00 AM posted to rec.aviation.piloting
Thomas Borchert
Blueskies,
Yup. You were probably trying to make a point by mentioning it. What is
it?
Thomas Borchert (EDDH)
  #98
Old October 8th 07, 04:19 PM posted to rec.aviation.piloting
Gig 601XL Builder
Stefan wrote:
Matt Whiting wrote:
Ain't that great? Power by the hour. You know in advance what it
will cost you to run that engine 2400 hours. No surprise midtime
overhauls. If it doesn't make TBR, Thielert will prorate it on the
new engine.
That is great as long as the cost per hour is competitive.
I pointed you to the numbers. But I understand that you're too lazy to
do the math but want to argue just for the sake of arguing.
Well I missed it. How much is the replacment and how much will it cost?
  #99
Old October 9th 07, 12:30 AM posted to rec.aviation.piloting
Stefan
new engine.
  #100
Old October 9th 07, 12:40 AM posted to rec.aviation.piloting
Stefan
Matt
It gets boring.
Ah, I finally understand. I've always thought you were insuinating
something by insisting that the Theilert ist only a good deal provided
it is a good deal and repeating that statement over and over. But I
finally understand that you didn't insuinate anything. You just meant
what you wrote: It's only a good deal if it's a good deal.
I don't know how you call such a statement in English, but in German I
call it a "Null-Aussage", a zero-statement. It's only a good deal if
it's a good deal... geezz. Sorry for searching for a message in your
statement.
100/130 avgas Roy Smith General Aviation 1 December 24th 06 09:17 AM
Old AvGas gwengler Piloting 2 December 16th 06 01:07 PM
Survival and Demise Kit; Contest Points Jim Culp Soaring 1 June 21st 04 04:35 AM
The demise of the Sea Harrier Henry J Cobb Naval Aviation 39 April 25th 04 07:27 PM
Here's to Arafat's Speedy Demise robert arndt Military Aviation 0 September 12th 03 07:45 AM
