#61
On Oct 7, 2:51 pm, "Robert M. Gary" wrote:
On Oct 7, 2:32 pm, Union Thug wrote: On Oct 7, 12:57 pm, "Robert M. Gary" wrote: On Oct 6, 11:51 am, Bertie the Bunyip wrote: People who prefer the numbers usualy don't fly very well at all. Which is every test pilot the military has used since the 60's. Minimum requirement is an engineering degree but most have PhDs. Which branch of the service where they in when they were test pilots. -Robert- Hide quoted text - One at GD and one AF and NASA. |
#62
Mxsmanic wrote in
: Snowbird writes: Then you must prefer performing your flight simulation with the B747-100 over the B747-400, right? They both provide about the same amount of information. That said, sometimes even the most basic steam gauges are quite capable of generating information overload ;-) I find some analog altimeter designs to be rather counterintuitive. For once, I have to partly agree. There is still improvement potential in the user interfaces. However, compared to mechanical gauges it's no contest. Until the computer fails, that is. You gotta have some good old fashioned stuff for backup.. Well, until recently you did anyway! Bertie |
#63
"Snowbird" wrote in
ti.fi: "Mxsmanic" wrote ... Snowbird writes: .....However, compared to mechanical gauges it's no contest. Until the computer fails, that is. Mechanics are not failure-free either. In fact, during my brief aviator career I've already experienced two (2) creeping altimeters and one (1) stuck VSI. The worst, however, was an airspeed indicator that did not move until the airplane was up to 35 knots. Makes for interesting decision situations during take-off. I still don't know if the fault was in the instrument or if there was water or a bug in the pitot line. Bit different from watching your screens disappear completely. Also the computers often tie in several instruments together. for instance, theres only one gyro on larger aircraft for the attitude and heading. For the pressure instruments, all th estuff comes off the Air Data Computer. Thus, a single failure results in the loss fo several instruments at once. Bertie |
#64
"Robert M. Gary" wrote in news:1191787050.286971.212410
@y42g2000hsy.googlegroups.com: On Oct 6, 11:51 am, Bertie the Bunyip wrote: People who prefer the numbers usualy don't fly very well at all. Which is every test pilot the military has used since the 60's. Minimum requirement is an engineering degree but most have PhDs. There's a difference between using the numbers and preferring them. Bertie |
#65
On Sat, 06 Oct 2007 15:21:27 -0000, Arno
wrote: Hello, I am computer scientist and usually really like fancy technology. But I just had my first flight with a "glass" PFD (Avidyne) and must say I am not impressed. In particular reading altitude and airpeed from these scrolling bands requires a lot more attention than with regular gauges, just like reading a digital clock takes longer than reading an analog one. Glancing at it and checking against a known picture, like "speed at 3 o'clock is fine on final" or "altitude at 20 minutes past midnight is minimum", just does not work anymore, instead I end up reading the actual numbers every time I look. Does anyone feel the same? Am I missing a particular technique? Arno I had the same problem at first, but as others have said it's just a matter of practice. It's similar to the transition I made to using the HUD on my car. With the standard speedometer it's not so much about reading the number as it is in recognizing the geometry / location of the needle. With the HUD it takes another few milleseconds to read and process a displayed number. Kirk PPL-ASEL |
#66
![]() "Kirk Ellis" wrote in message ... On Sat, 06 Oct 2007 15:21:27 -0000, Arno wrote: Hello, I am computer scientist and usually really like fancy technology. But I just had my first flight with a "glass" PFD (Avidyne) and must say I am not impressed. In particular reading altitude and airpeed from these scrolling bands requires a lot more attention than with regular gauges, just like reading a digital clock takes longer than reading an analog one. Glancing at it and checking against a known picture, like "speed at 3 o'clock is fine on final" or "altitude at 20 minutes past midnight is minimum", just does not work anymore, instead I end up reading the actual numbers every time I look. Does anyone feel the same? Am I missing a particular technique? Arno I had the same problem at first, but as others have said it's just a matter of practice. It's similar to the transition I made to using the HUD on my car. With the standard speedometer it's not so much about reading the number as it is in recognizing the geometry / location of the needle. With the HUD it takes another few milleseconds to read and process a displayed number. Kirk PPL-ASEL In other words, you need to further increase your following distance in order to read your speedometer--even though it is placed closed to your normal line of vision. Actually, a little more following distance might be a good idea for most drivers, but this is an example of really poor ergonomics--without even considering the "wait until you wear bifocals" argument. Peter |
#67
On Sun, 7 Oct 2007 21:42:31 -0400, "Peter Dohm"
wrote: In other words, you need to further increase your following distance in order to read your speedometer--even though it is placed closed to your normal line of vision. Actually, a little more following distance might be a good idea for most drivers, but this is an example of really poor ergonomics--without even considering the "wait until you wear bifocals" argument. Peter I haven't done any ergonomic studies, but it does seem to take a tad less time for a quick glance at the dash. Still, tailgating is never an option. As opposed to a HUD in an aircraft, the practicality of a HUD in a car is completely lost on me. It displays ther fuel level, and oil temperatures, but I have to admit I don't see the point. It may be helpful if your zipping down the interstate at F-18 rotation speeds so you don't have to take your eyes off the road. But, mostly it's all about the "coolness" factor. Kirk PPL-ASEL |
#68
On Oct 6, 8:21 am, Arno wrote:
Hello, I am computer scientist and usually really like fancy technology. But Arno When I used to fly Avidyne equipped planes, I absolutly loved the tape altimeter, but preferred the dial airspeed. Ever since switching back to steam gauges (about 600 flight hours ago) I've never quite gotten used to the round altimeter. I still want to level off at 3800 instead of 2800 etc. The range of possible airspeed values varies within a limited range (Vso to Vne). Depicting that data as a specified position within that range makes the most sense to me. On the other hand, altitudes can be anywhere from -600feet to 60,000 feet. The only relation the different values have to each other is "higher" and "lower". The best way to logically depict that relation is with a "tape" display. With a steam gauge altimeter, 6000 feet looks pretty darn similar to 7000 feet, 8000 feet and 9000 feet, even though those values have no meaningful relation (other than they all end with zeros which means nothing to a pilot). With a tape display, 6000 looks nothing like 7000, but it does kind of look similar to 6100 and 5900, which is meaningful to a pilot. |
#69
Snowbird writes:
Mechanics are not failure-free either. True, but a glass cockpit concentrates too much in too few components, raising the risk of catastrophic failure. Also, digital systems typically have catastrophic failure modes, whereas analog systems do not. |
#70
Bertie the Bunyip writes:
You gotta have some good old fashioned stuff for backup.. Well, until recently you did anyway! I fear what may happen when there is no longer a back-up--or when pilots forget how to use the back-ups. Also, while you may have some back-up instruments, a situation that would be both safe and manageable with a complete avionics suite in working order can become dangerous and unrecoverable if you have only a handful of instruments. There are some things that you can do with fancy avionics that you cannot do with just two or three steam gauges ... otherwise there'd be little point in the fancy avionics. But this inevitably means that there will be situations that are safe with the fancy stuff that become deadly without it, even with back-up instruments. Flying with three or four instruments is fine as long as you limit your flying to situations that can be handled by those instruments. Of course, if you have a fancy glass cockpit, you may well go far beyond those situations, and if the glass cockpit then fails, you're in deep trouble. |
OSH Homerun? Glass Cockpit for the Budget-Challenged | Marco Leon | Piloting | 4 | July 27th 07 11:27 PM |
winter is hard. | Bruce Greef | Soaring | 2 | July 3rd 06 06:31 AM |
Why Not Use PC To Make Glass Cockpit? | Le Chaud Lapin | Instrument Flight Rules | 52 | July 19th 05 03:45 AM |
It ain't that hard | Gregg Ballou | Soaring | 8 | March 23rd 05 01:18 AM |
Glass Cockpit in Older Planes | Charles Talleyrand | Owning | 2 | May 20th 04 01:20 AM |
