I'm driving a 1986 T210R.
400 hours ago we had a reman engine installed and ever since the CHT and oil temperature gauges(original) haver read higher than they used to. Over the last couple months the temps have been climbing until now the oil is above redline and the CHT near redline in cruise. We have an engine monitor with all EGT/CHT probes and it says the CHT's are fine, hottest(#1) is 370, lowest 315. We don;t have a secondary oil temp gauge but the oil pressure is running 58-60 steady as a rock no matter what the oil temp gauge reads. The high temps displayed on the old gauges will change if the electrical load is changed. Higher the load, higher the temps. With everything off but the master switch, the displayed temps are close to normal but still a tad high. I'd say the oil temp varies 50 degrees between no load and say a 60 amp load. I tested with a digital volt meter and the voltage stays in a range of 27.6 to 28 vdc no matter what the load is. There are 2 alternators, a 65 amp and a 90 amp, both functional, temp display does not change if running on both or either one. With both off the temps drop even more, but the voltage also drops to 24.5-25 volts. Not sure if the additional drop in temp display is because the voltage is so low? Anybody have a clue as to what is going on? We are stumped as is our A&P. thanks, Scott |
On Oct 7, 7:50 pm, Scott Derrick wrote:
I'm driving a 1986 T210R. 400 hours ago we had a reman engine installed and ever since the CHT and oil temperature gauges(original) haver read higher than they used to. Over the last couple months the temps have been climbing until now the oil is above redline and the CHT near redline in cruise. We have an engine monitor with all EGT/CHT probes and it says the CHT's are fine, hottest(#1) is 370, lowest 315. We don;t have a secondary oil temp gauge but the oil pressure is running 58-60 steady as a rock no matter what the oil temp gauge reads. The high temps displayed on the old gauges will change if the electrical load is changed. Higher the load, higher the temps. With everything off but the master switch, the displayed temps are close to normal but still a tad high. I'd say the oil temp varies 50 degrees between no load and say a 60 amp load. I tested with a digital volt meter and the voltage stays in a range of 27.6 to 28 vdc no matter what the load is. There are 2 alternators, a 65 amp and a 90 amp, both functional, temp display does not change if running on both or either one. With both off the temps drop even more, but the voltage also drops to 24.5-25 volts. Not sure if the additional drop in temp display is because the voltage is so low? Anybody have a clue as to what is going on? We are stumped as is our A&P. thanks, Scott There's a bad grounding connection between the engine and firewall. When the alternator is at work, its return flow is through a heavy wire from the alternator case to the firewall. An additional ground strap is connected between the crankcase and engine mount, and the mount should be bare metal where it touches the firewall and bolt heads or nuts. The alternator case is mounted directly to the engine and this is an additional path. If there's more than the tiniest amount of resistance between the alternator/engine case and airframe, there will be a voltage difference between them and some of the flow will seek out a path through the temperature or oil pressure sender grounds and through their circuits, increasing their flow and giving erroneously high readings. Some of those gauges have their own ground wire to the engine case to minimize this, but a really bad ground will soon overwhelm that small wire anyway. So see if those oil temp and CHT ground wires are in place, and check and clean both the ground strap and alternator ground cable connections. I bet that when the engine was replaced, the connections were just bolted back up without cleaning them, and the small instrument grounds might have been left off altogether. Dan |
On Oct 8, 7:58 pm, Scott Derrick wrote:
Dan, I thought about a bad ground but ruled it out because the starter turns so easily. I will check the main ground straps. The oil, temp and cht probes are single wire so they are relying on the engine grand strap. thanks, Scott wrote: On Oct 7, 7:50 pm, Scott Derrick wrote: I'm driving a 1986 T210R. 400 hours ago we had a reman engine installed and ever since the CHT and oil temperature gauges(original) haver read higher than they used to. Over the last couple months the temps have been climbing until now the oil is above redline and the CHT near redline in cruise. We have an engine monitor with all EGT/CHT probes and it says the CHT's are fine, hottest(#1) is 370, lowest 315. We don;t have a secondary oil temp gauge but the oil pressure is running 58-60 steady as a rock no matter what the oil temp gauge reads. The high temps displayed on the old gauges will change if the electrical load is changed. Higher the load, higher the temps. With everything off but the master switch, the displayed temps are close to normal but still a tad high. I'd say the oil temp varies 50 degrees between no load and say a 60 amp load. I tested with a digital volt meter and the voltage stays in a range of 27.6 to 28 vdc no matter what the load is. There are 2 alternators, a 65 amp and a 90 amp, both functional, temp display does not change if running on both or either one. With both off the temps drop even more, but the voltage also drops to 24.5-25 volts. Not sure if the additional drop in temp display is because the voltage is so low? Anybody have a clue as to what is going on? We are stumped as is our A&P. thanks, Scott There's a bad grounding connection between the engine and firewall. When the alternator is at work, its return flow is through a heavy wire from the alternator case to the firewall. An additional ground strap is connected between the crankcase and engine mount, and the mount should be bare metal where it touches the firewall and bolt heads or nuts. The alternator case is mounted directly to the engine and this is an additional path. If there's more than the tiniest amount of resistance between the alternator/engine case and airframe, there will be a voltage difference between them and some of the flow will seek out a path through the temperature or oil pressure sender grounds and through their circuits, increasing their flow and giving erroneously high readings. Some of those gauges have their own ground wire to the engine case to minimize this, but a really bad ground will soon overwhelm that small wire anyway. So see if those oil temp and CHT ground wires are in place, and check and clean both the ground strap and alternator ground cable connections. I bet that when the engine was replaced, the connections were just bolted back up without cleaning them, and the small instrument grounds might have been left off altogether. Dan We had this same problem in a 172, and it was poor grounding. The starter still turned well. It went away when we installed a separate ground wire from a bolt near the sender on the case to the back of the instrument itself. Got to eliminate any differential, see. We twigged to the solution when Cessna sent us a retrofit kit for another 172 to replace the mechanical temp gauge, and this kit had the ground wire and warnings to make sure it got installed. Dan |
Wanted T210 Intercooler | RC | Aviation Marketplace | 0 | October 30th 06 06:28 AM |
Oil temperature questions | Peter R. | Owning | 10 | April 22nd 06 05:43 PM |
I've decided to buy a T210. Advice is welcom | john szpara | Owning | 7 | June 20th 05 08:59 PM |
Manifold pressure gauge problem | Dave Russell | Aerobatics | 3 | January 29th 04 03:46 AM |
Carb Temperature Gauge | fly_the_skies | Home Built | 6 | January 14th 04 03:32 PM |
