I own a Cessna 150 with a 150 HP engine installed (0-320- E2D)
The STC states the static RPM is not to be over 2250 RPM. My airplane meets the Static RPM Requirement. My question is am I getting the full 150 HP on takeoff??? turning 2250 RPM When rolling down the Runway the Tach reads about 2250 RPM During stable Cruise the engine spins up to 2600 RPM ++ full throttle : no problem It seem's to me that the engine should turn much faster like 2700 RPM or so for 150 HP??? on takeoff Just like a Cessna 172! Turning 2250 RPM seems like I am not getting the full rated engine HP??? perhaps 125 HP or so??????? What sets the engine RPM?? is it the diameter of the prop?? or is the Throttle travel limited??? Why would the STC limit the Static Engine RPM to 2250 RPM??? is it because the Tip of the props may exceed speed of sound ???? The STC states the Prop is a Mccauley 1C172/TM not over 74 inches not under 72.5 inches. Thanks for input |
On Oct 8, 11:27 pm, wrote:
I own a Cessna 150 with a 150 HP engine installed (0-320- E2D) The STC states the static RPM is not to be over 2250 RPM. My airplane meets the Static RPM Requirement. My question is am I getting the full 150 HP on takeoff??? turning 2250 RPM A variable pitch prop (expensive) can keep constant RPM near the max power output at takoff. But your fixed pitch prop is designed for overall average operation. If it was pitched for near full power 2700 rpm at takeoff it would go beyond the max RPM at cruise and ruin the engine. |
So why would a guy "upgrade" to an O-320 and limit it to 100 HP? What's
the "gain" ??? Scott Orval Fairbairn wrote: The placarding probably relates to the STC, which "limits you to 100 hp", for certification purposes. It is easier to get an STC for a higher power engine if you "limit, via placards, the max power" to that called out in the original type certificate. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) |
"Scott" wrote in message .. . So why would a guy "upgrade" to an O-320 and limit it to 100 HP? What's the "gain" ??? For much the same reason that one would spend a lot of money to install a turbo-normalizer? Same max horsepower, but more horsepower available under a wider set of conditions? Just guessing... Vaughn |
Scott: It is simple. An 0320 is said to be a 150hp engine at 59 degrees,
sea level, short exhaust stacks and a certain humidity. At Rioduoso (sp?) NM on a hot day the density altitude will make you wish that you had put an 0540 on there even if you have to limit it to 100 hp cause you ain't going to get 100hp out of the 0320 with a Cessna Exhaust and intake system at a high density altitude. Stu Fields Experimental Helo magazine "Scott" wrote in message .. . So why would a guy "upgrade" to an O-320 and limit it to 100 HP? What's the "gain" ??? Scott Orval Fairbairn wrote: The placarding probably relates to the STC, which "limits you to 100 hp", for certification purposes. It is easier to get an STC for a higher power engine if you "limit, via placards, the max power" to that called out in the original type certificate. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version) |
It IS simple. You are not getting 100% horsepower at takeoff. You
are inventing the need for the constant speed prop. Great example is the 180hp Tiger with a cruise prop! Now, I want to learn something from this... Why is it that maximum static RPM is independent of altitude? Horsepower drops with altitude. But static RPM does not. Horsepower is related to the cube of RPM for a fixed pitch prop IIRC. Why is it that static RPM stays constant? Good thing, actually, or a fixed pitch prop would be practically useless. Bill Hale On Oct 9, 4:51 pm, "Stuart & Kathryn Fields" wrote: Scott: It is simple. An 0320 is said to be a 150hp engine at 59 degrees, sea level, short exhaust stacks and a certain humidity. At Rioduoso (sp?) NM on a hot day the density altitude will make you wish that you had put an 0540 on there even if you have to limit it to 100 hp cause you ain't going to get 100hp out of the 0320 with a Cessna Exhaust and intake system at a high density altitude. Stu Fields Experimental Helo magazine"Scott" wrote in message .. . So why would a guy "upgrade" to an O-320 and limit it to 100 HP? What's the "gain" ??? Scott Orval Fairbairn wrote: The placarding probably relates to the STC, which "limits you to 100 hp", for certification purposes. It is easier to get an STC for a higher power engine if you "limit, via placards, the max power" to that called out in the original type certificate. -- Scott http://corbenflyer.tripod.com/ Gotta Fly or Gonna Die Building RV-4 (Super Slow Build Version)- Hide quoted text - - Show quoted text - |
On Oct 9, 8:27 am, Orval Fairbairn wrote:
In article om, wrote: On Oct 8, 11:27 pm, wrote: I own a Cessna 150 with a 150 HP engine installed (0-320- E2D) The STC states the static RPM is not to be over 2250 RPM. My airplane meets the Static RPM Requirement. My question is am I getting the full 150 HP on takeoff??? turning 2250 RPM A variable pitch prop (expensive) can keep constant RPM near the max power output at takoff. But your fixed pitch prop is designed for overall average operation. If it was pitched for near full power 2700 rpm at takeoff it would go beyond the max RPM at cruise and ruin the engine. The placarding probably relates to the STC, which "limits you to 100 hp", for certification purposes. It is easier to get an STC for a higher power engine if you "limit, via placards, the max power" to that called out in the original type certificate. Baloney. The STC, and any TCDS, will specify a static RPM range. Yours probably says "Not under 2150 RPM, not over 2250 RPM." The O-320E2D in a 172M will spec not under 2270, not over 2370 RPM. The figure relates to brakes locked, full throttle, zero wind RPM and won't change much with density altitude. The static RPM is used for engine and prop health purposes. A fixed-pitch prop will never give you full engine hp until you are in flight at standard conditions (sea level, 59°F) so you'd have to be at or near full throttle with the wheels just above the waves. Your O-320 in the 152 is NOT derated any more than the O-320s in our 172s are. We don't get 2700 RPM unless we're in flight and the throttle is wide open. Many aircraft with fixed-pitch props use exactly that criteria for propeller pitch: max throttle in level flight gives redline RPM. Too much pitch would prevent reaching full hp, too little would leave unusable throttle travel in level flight. Since the O-320 is certified to produce full power with no time limitation, you could, with the correct prop, cruise at 2700 and go places fast. Your range would be a lot shorter since the fuel burn would be pretty bad. We have to break in new engines over a 3-hour flight, with the last half-hour being at full throttle, which gives us 2700 RPM. The old 172 goes nearly 140 mph at that setting. Without wheel pants, too. Dan |
Baloney. The STC, and any TCDS, will specify a static RPM range. Yours probably says "Not under 2150 RPM, not over 2250 RPM." The O-320E2D in a 172M will spec not under 2270, not over 2370 RPM. The figure relates to brakes locked, full throttle, zero wind RPM and won't change much with density altitude. The static RPM is used for engine and prop health purposes. A fixed-pitch prop will never give you full engine hp until you are in flight at standard conditions (sea level, 59°F) so you'd have to be at or near full throttle with the wheels just above the waves. Just one that I know of... you da man, Leon! http://www.aircraft-spruce.com/da11.html |
| Thread Tools | |
| Display Modes | |
| Ship's Power (or portable GPS) Question | Kyle Boatright | Home Built | 9 | May 29th 07 04:17 PM |
| Decathlon engine managment-> power off spins | max | Aerobatics | 3 | July 5th 05 03:48 AM |
| Auto. engine >> vertical shaft power output | [email protected] | Rotorcraft | 4 | June 2nd 05 08:16 PM |
| 747 engine takeoff power | Gord Beaman | Naval Aviation | 23 | November 29th 04 06:52 PM |
| rough engine just after power reduction | Sydney Hoeltzli | Owning | 11 | July 30th 03 04:37 PM |
