Airplane Pilot's As Physicists
Old October 9th 07, 10:29 PM posted to sci.physics,rec.aviation.piloting
Gatt
Default Airplane Pilot's As Physicists
"Le Chaud Lapin" wrote in message
ps.com...
I am an electrical engineer with experience in analag
That would be "analog" there, wouldn't it, engineer? Now, think about how
"attention to detail" applies to math.
I count 8-9 people in the group who are utterly convinced that I am inept
at physics, mathematics, etc.
Nobody's saying you're inept at anything; just arrogant about your
assumptions, and wrong, and quite possibly dishonest about your identity.
Taking on the science of NASA, for example, challenges the kind of people
who put men on the moon, shuttle aircraft into space and back, and robots on
Mars. What I'm saying is, they've proven their ability to do math and
physics. You're talking about two pieces of paper on a table or whatever,
admitting you don't fully understand aerodynamics, and then challenging the
kind of people who did research using SR-71 blackbirds and spacecraft.
....in a pilots' forum. What in hell kind of response did you possibly
expect?
-c
Old October 9th 07, 10:30 PM posted to sci.physics,rec.aviation.piloting
Mxsmanic
Le Chaud Lapin writes:
If you read carefully, the premise of what they are saying is that, if
you have, for example, a sealed jar with air in it, you are permitted
to consider the air on the _inside_ of the jar, pushing up on the lid
as contributing to a force to lift the jar off the ground, but you are
not allowed to consider the air on the _inside_ of the jar, pushing
down on the jar un the upper surface of the bottom of the jar.
The atmosphere is not a sealed jar. The source of air pressure in the
atmosphere is gravity, not confinement and kinetic energy.
Old October 9th 07, 10:32 PM posted to sci.physics,rec.aviation.piloting
Mxsmanic
Sam Wormley writes:
The same way that your hand gets pulled upwards if you stick it out the
car window and tilt it. The lift of an airfoil is determined by two
things - the shape of the wing, and it's angle of attack.
Actually, only the angle of attack matters.
So when the lift from angle of attack in the up direction, exceeds the lift from
the shape of the wing ...
All of the lift comes from the positive angle of attack.
Answered by: Frank DiBonaventuro, B.S., Physics, The Citadel, Air Force
officer
I guess even the Citadel is passing on some bad information.
Mxsmanic
Even though this (new) thread is not about what causes a wing to lift,
I just wanted to say for the record that I agree with this answer,
that it is both AoA and curvature of the wing.
It's just AOA.
Old October 9th 07, 10:33 PM posted to sci.physics,rec.aviation.piloting
Gatt
"Randy Poe" wrote in message
As I said, I lean toward the angle-of-attack arguments now. Take
a flat rectangle, tilt it into the wind. The wind blows against the
front which is also the bottom, not the back/top. So the
forces are on the bottom.
The day the physics guys were passing out good wing designs, the aerospace
designers were all out drinking beer, which is why every airplane since the
Wright flyer has camber when they could have just used flat plywood.
-c
Old October 9th 07, 10:35 PM posted to sci.physics,rec.aviation.piloting
Gatt
WTF is he talking about? Nobody said anything about air -inside- of a wing.
-c
Old October 9th 07, 10:37 PM posted to sci.physics,rec.aviation.piloting
Robert M. Gary
I don't understand the subject of the post. "Airplane Pilot's" what?
Why are you using a possessive noun here?
-Robert
Old October 9th 07, 10:38 PM posted to sci.physics,rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Sam Wormley writes:
the car window and tilt it. The lift of an airfoil is determined by
two things - the shape of the wing, and it's angle of attack.
Nope, wrong again fjukkwit.
the lift from the shape of the wing ...
Nope, worng again.
Force officer
Nope.
They fly, you don;t.
You never will,.
Nor wil your sockpuppets.
Bertie
Mxsmanic wrote in
It's just AOA.
Nope.
bertie
Old October 9th 07, 10:40 PM posted to sci.physics,rec.aviation.piloting
Mxsmanic wrote in
Randy Poe writes:
The essential feature of an airfoil is that it twists the flow of air
as it passes (or as the airfoil passes through still air, which is
equivalent, and that's how it works in airplanes). The air is
accelerated downward, and this engenders an equal and opposite force
that is lift.
So how does a wing produce lift? By twisting air downwards, creating
a downwash. Accelerating a mass of air downwards tends to accelerate
the wing upwards, and there's your lift.
The theory gets more complicated when you try to explain exactly how
and why airfoils twist an airflow. Just looking at a flat board with
a positive angle of attack, you'd think that it would twist the air,
and that's exactly what it does. But the devil is in the details.
Fortunately, aviators don't have to know or care about the details.
All they need to know is that a wing with a positive angle of attack
(and below the stall angle) will generate lift.
Lift, like so many other phenomena in physics, can be analyzed and
explained in a number of different, equally valid ways, depending on
one's point of view. All analyses and explanations converge on the
same reality. Of course, some explanations of lift are just plain
incorrect, and unfortunately a few of them are quite widespread.
Nope
Bertie
Pilot's Assistant V1.6.7 released AirToob Simulators 2 July 7th 07 10:43 AM
A GA pilot's worst nightmare? Kingfish Piloting 49 February 1st 07 02:51 PM
Pilot's Political Orientation Chicken Bone Piloting 533 June 29th 04 12:47 AM
Update on pilot's condition? Stewart Kissel Soaring 11 April 13th 04 09:25 PM
Pilot's Funeral/Memorial TEW Piloting 6 March 17th 04 03:12 AM
