My wife getting scared
Old October 10th 07, 02:34 AM posted to rec.aviation.piloting
Shirl
Default My wife getting scared
Jay:
Well, ya got me there. But, of course, the odds of a real engine out
are (thankfully) quite small.
Shirl:
Yeah, I used to say that, too!
Thomas Borchert wrote:
They still are, even thought you've experienced one.
Yes, that's true.
What I meant was that no one should take comfort that "the odds of a
real engine out are quite small" or use that as justification for never
practicing the engine-out drill, because even small odds mean that they
happen to *someone*.
  #232
Old October 10th 07, 10:26 AM posted to rec.aviation.piloting
Thomas Borchert
Shirl,
Excellent point.
Thomas Borchert (EDDH)
  #233
Old October 10th 07, 04:11 PM posted to rec.aviation.piloting
Mxsmanic
Shirl writes:
If the odds were small enough, practicing the drill might be more dangerous
than not practicing the drill, at least if it were carried out in a real
aircraft.
  #234
Old October 10th 07, 04:27 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Mxsmanic wrote in
Shirl writes:
never practicing the engine-out drill, because even small odds mean
that they happen to *someone*.
dangerous than not practicing the drill, at least if it were carried
out in a real aircraft.
Yeah, right, fjukkwit.
Bertie
  #235
Old October 10th 07, 05:04 PM posted to rec.aviation.piloting
Shirl
Shirl:
aircraft.
The odds are NOT small enough that practicing the drill is more
dangerous than not practicing it -- there are, no doubt, many who have
not experienced it, but it is said that is isn't "if" you'll have one,
it is "when". Just happened to a guy at our airport after 30 years of
flying, with only 700 hours on the engine. No guarantees, no matter how
anyone thinks they're doing all the "right" things with regard to engine
care and use. And If that were the case (practicing being more dangerous
than not), it would be removed from the curriculum, ala spin training
that is now spin "awareness" training.
  #236
Old October 10th 07, 08:13 PM posted to rec.aviation.piloting
Mxsmanic
Shirl writes:
it is "when".
That would depend on the aircraft.
Airline pilots, for example, can go for their entire careers without having to
deal with an engine failure on an actual flight. Simulators are invaluable in
this case because they allow pilots to practice engine failures until they
become second nature, without risking an actual aircraft (which would be very
dangerous and expensive).
Piston-driven aircraft are much less reliable and so engine failures are much
more likely to occur. But still, practicing them in the real aircraft is
dangerous and potentially expensive. If they aren't handled correctly, you
(potentially) write off the aircraft, and perhaps the pilots as well.
Sometimes practice mitigates this risk by not actually failing an engine, and
simply setting it to idle or something. Unfortunately this isn't the same as
an actual engine failure, so the practice it provides doesn't correspond
exactly to the real thing, which can also be a problem. A simulator would be
ideal, but apparently full-motion simulators for these small aircraft are hard
to find.
What type of aircraft?
Does the curriculum specify engine-out training by shutting an engine off
completely?
  #237
Old October 10th 07, 08:36 PM posted to rec.aviation.piloting
BDS[_2_]
and
"or something"?
How is it different?
hard
to find.
Why does this require a full-motion sim?
BDS
  #238
Old October 10th 07, 10:02 PM posted to rec.aviation.piloting
Shirl
Shirl:
it is "when".
Mxsmanic wrote:
That would depend on the aircraft. Airline pilots, for
We were talking about GA, and how often we, in GA, practice engine-out
emergencies. We were not talking about airliners. The degree of danger
in intentionally practicing them in a small aircraft vs. in an airliner
is not the same.
What is "second nature" when you are safely sitting on the ground in a
simulator is not always second nature when you're in a real airplane in
flight, or further, in a real airplane in a real in-flight emergency.
In-flight simulated engine failure may not be exactly like the real
thing, either, but it's a lot closer than any simulator.
Hire a CFI if you aren't sure how to do it. In-flight engine-out
practice wouldn't be part of the private pilot curriculum if it is so
dangerous that no one should ever practice it.
Duh--that's the whole point! FLYING is dangerous and potentially
expensive if not handled correctly. That's why pilots practice various
things to stay as proficient as possible and why regulations re pilot
currency and periodic review exist.
Odds may be small, but if a REAL engine out isn't handled correctly,
there's even more of a chance of writing off the aircraft and the
pilot/passenger(s). That's why the drill is taught to private pilot
students, why it is included in checkrides, why (some) CFIs include it
in BFRs, and why (some) pilots practice it on occasion to maintain some
level of skill/proficiency.
Football practice may not be the same as the actual game, either, but
that's how players train. In-flight simulated engine failure practice is
as close to "the real thing" as possible without actually shutting down
the engine in flight ... close enough to provide experience and develop
skills that can and HAVE helped in actual emergencies.
A simulator would be ideal, but apparently full-motion simulators
for these small aircraft are hard to find.
No, a simulator wouldn't be "ideal". Can you learn useful emergency
skills in a simulator? Yes. Is it an ideal substitute for practicing
them in a real airplane while you're actually *in the air*, FLYING the
plane, making decisions, etc.? No. To my knowledge, you can't satisfy
the emergency portion of the private pilot checkride in a simulator; it
must be done in an actual airplane...while in flight!
Cessna 140. It was mechanical, not pilot error. And yes, he landed
safely. Point is, after 30 years, he thought the odds were small, too,
but thankfully, he was well prepared.
That said, it's up to each individual whether or not they do them
between BFRs. I personally don't think the wear-and-tear on the engine
in an occasional engine-out practice outweighs the value to me in
maintaining some level of proficiency by going through the drill
periodically in the airplane I fly (not in a rental that may react
differently). IMO, many more factors exist when an engine doesn't make
it to TBO than *occasional* engine-out practices, go-arounds or
touch-n-gos. And even some engines with the best possible care and use
don't make it to TBO. But that's JMO.
completely?
Of course not. Do airports actually crash a plane to train emergency
personnel how to react in an actual crash? It's true that a simulated
engine failure *in an airplane* with the engine at idle is not quite the
same as an *actual* engine failure ... but the practice (at idle) in a
small aircraft is much closer to what you would actually feel and
experience than a simulator.
  #239
Old October 10th 07, 10:16 PM posted to rec.aviation.piloting
Bertie the Bunyip
On 10 Oct, 20:13, Mxsmanic wrote:
Shirl writes:
it is "when".
Wrong again asshole.
I've had catastrophic failures in two nearly new JT8s, shut down three
others, shingled yet another and had to cage two turboprops and I'm
far from done yet.
Bertie
  #240
Old October 10th 07, 10:17 PM posted to rec.aviation.piloting
Bertie the Bunyip
On 10 Oct, 20:36, "BDS" wrote:
and
"or something"?
hard
to find.
It doesn't, but even if it did he wouldn't know why.
Bertie
Scared of mid-airs Frode Berg Piloting 355 August 20th 06 05:27 PM
UBL wants a truce - he's scared of the CIA UAV John Doe Aviation Marketplace 1 January 19th 06 08:58 PM
The kids are scared, was Saddam evacuated D. Strang Military Aviation 0 April 7th 04 10:36 PM
Scared and trigger-happy John Galt Military Aviation 5 January 31st 04 12:11 AM
