Engine power question???
Old October 10th 07, 05:08 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Default Engine power question???
J.Kahn wrote:
It forces you to use a certain minimum prop pitch to avoid overspeeding
it in flight.
An O-320 makes 120 hp at 2300 rpm and 26". At wide open throttle at SL
and 2250 it is probably around 130 hp. Add a couple thousand feet and
125 hp at the start of the roll sounds about right.
Any fixed pitch airplane is the same. A 150 with a stock O200 doesn't
have 100 hp available while static either, probably more like 80-85. So
all things being equal you still have 50% more power available than stock.
You know, we ALL really ought to go get another hour in a 150 every once
in a while.
When I was in high school, the 150 was IT! WoW!
But I flew one a couple of years ago and the prevelant thought was,
"What happened? This used to be FUN".
With all the old wives' tales about running constant speed engines
"oversquare" (rpm below mp) it's amusing to note that fixed pitch
aircraft are way oversquare all through their takeoff and climb phase
until they're going fast enough.
John
Old October 10th 07, 05:15 AM posted to rec.aviation.homebuilt
Dave S
John
But without that manifold pressure gauge on a fixed pitch prop, us
knuckledraggers are blissfully unaware of that fact. I did see at 152
with a MP gauge once.. nice "feature".
Dave
Old October 10th 07, 02:14 PM posted to rec.aviation.homebuilt
Scott[_1_]
OK, I guess I can buy into that one, but I'm still confused a bit. If
one is limiting it (the O-320) to a given RPM that gives 100 HP out,
wouldn't that same RPM give less than 100 HP at high density altitude
just as an O-200 would?
Scott
Stuart & Kathryn Fields wrote:
Scott: It is simple. An 0320 is said to be a 150hp engine at 59 degrees,
sea level, short exhaust stacks and a certain humidity. At Rioduoso (sp?)
NM on a hot day the density altitude will make you wish that you had put an
0540 on there even if you have to limit it to 100 hp cause you ain't going
to get 100hp out of the 0320 with a Cessna Exhaust and intake system at a
high density altitude.
Stu Fields
Experimental Helo magazine
"Scott" wrote in message
So why would a guy "upgrade" to an O-320 and limit it to 100 HP? What's
the "gain" ???
Scott
Orval Fairbairn wrote:
The placarding probably relates to the STC, which "limits you to 100 hp",
for certification purposes.
It is easier to get an STC for a higher power engine if you "limit, via
placards, the max power" to that called out in the original type
certificate.
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
Scott
Old October 10th 07, 04:16 PM posted to rec.aviation.homebuilt
Scott
They're not deliberately limiting it to 100 hp. The fixed-pitch
prop does that on any airplane. Your O-320 will make any O-200 look
sick. You need to fly a 150 with the O-200, and you won't complain
anymore. A 150 with the O-200 on takeoff won't generate anywhere near
100 hp. In fact, I have my suspicions that it never did, even at 2750
RPM. We had those engines in a couple of 150s, and I flew an Aircoupe
with a C-90, 10 less hp than the O-200, and it took off much shorter,
climbed and cruised much faster than the 150. It generated that 90 hp
at a lower RPM, which means that less hp was lost to drag. The
airplane weighed only 150 lb less than the 150.
A guy in the US did some testing on a 150. He did a static
thrust test, full RPM with the airplane pulling on a hefty spring
scale. Got around 230 lb, IIRC. Then he took that O-200 out and put in
a 100 hp Subaru conversion and did the static test again and got
almost 300 lb. That wasn't with a lower-pitched prop, either; the
airplane cruised as well as before at a similar RPM. Makes one wonder
about hp claims.
Dan
Old October 11th 07, 12:10 AM posted to rec.aviation.homebuilt
J.Kahn
cavelamb himself wrote:
overspeeding it in flight.
SL and 2250 it is probably around 130 hp. Add a couple thousand feet
and 125 hp at the start of the roll sounds about right.
So all things being equal you still have 50% more power available than
stock.
in a while.
John
Actually, I'm starting to look for a 150 to play around with and for the
kids to learn in next spring. They fly about as well as most
airplanes, with a really good useful load for that size. The 150 does a
lot of things reasonably well and are becoming dirt cheap as the big
flight schools unload them. Where else can you get a 600 lb useful
load, electrics, really powerful fowler flaps, etc all for 20k.
Everybody else hates them, but I like the '64/65 straight tails. If
you block out the front half of the airplane in a picture, it looks like
an A-26.
Apparently aileron gap seals make the ailerons much lighter and
snappier, probably the biggest complaint in handling.
John
Old October 11th 07, 04:00 AM posted to rec.aviation.homebuilt
stock.
in a while.
John
an A-26.
John
We're at 3000' ASL here. We found the 150 to be underpowered
and really tight inside, and the O-200 would usually give top end
problems by mid-life. There were days in the summer (30°C/85°F, 5000'
DA) when the dumb thing would climb at under 200 FPM and take all day
to reach circuit altitude. They might be OK near sea level.
The older straight tails, or at least the ones without the
back window, were lighter and faster. Not many of them around now. The
150's flaps are awesome, and the rudder has enough authority to deal
with strong crosswinds, better than the 172. And it'll spin readily,
something the 172 is really reluctant to do.
Dan
Old October 11th 07, 04:17 AM posted to rec.aviation.homebuilt
Kyle Boatright
Scott
about hp claims.
Dan
Don't confuse thrust with HP unless you're using the exact same prop and
prop RPM. An 0-360 powered Robinson R-22 generates what, 1500 lbs of thrust
because of gearing, disc area, etc? But, that thrust is only effective in a
narrow (vertical) speed range. The same engine, combined with an RV-style
cruise prop, would only generate (WAG coming) 250 lbs of static thrust.
HP claims on certified engines were +/- 5% back in the day when most "100
hp" 0-200's were built, meaning that a "bad" engine generated 95 HP when it
was built.
KB
Old October 11th 07, 04:19 AM posted to rec.aviation.homebuilt
stock.
in a while.
John
an A-26.
John
Dan
Well, that's all right, I guess.
But it's sure no 65 HP Taylorcraft.
(Which gets off shorter, climbs better and is (no ****) faster!)
Richard
Old October 11th 07, 03:56 PM posted to rec.aviation.homebuilt
That Soob had the same diameter of prop and ran at the
same RPM. I'm aware of the diameter/RPM/pitch effects, and that's why
the results were so startling to me. The 150s performance was much
better with the Soob, confirming its output. So either the Soob
produced more power than claimed, or the O-200 was really sick. Yet
the guy said that the O-200 was OK and the 150's performance with it
was typical.
Dan
Ship's Power (or portable GPS) Question Kyle Boatright Home Built 9 May 29th 07 03:17 PM
Decathlon engine managment-> power off spins max Aerobatics 3 July 5th 05 02:48 AM
Auto. engine >> vertical shaft power output [email protected] Rotorcraft 4 June 2nd 05 07:16 PM
747 engine takeoff power Gord Beaman Naval Aviation 23 November 29th 04 05:52 PM
rough engine just after power reduction Sydney Hoeltzli Owning 11 July 30th 03 03:37 PM
