On most modern turbo charged engines, the position of the waste gate
is governed by a pressure-sensing control mechanism coupled to an actuator. engine oil directed into or away from this actuator moves the waste gate position. On these systems, the actuator is automatically positioned to produce the desired MAP simply by changing the position of the throttle control. This was post from the http://ma3naido.blogspot.com blog. |
On Oct 12, 12:48 pm, wrote:
On most modern turbo charged engines, the position of the waste gate is governed by a pressure-sensing control mechanism coupled to an actuator. engine oil directed into or away from this actuator moves the waste gate position. On these systems, the actuator is automatically positioned to produce the desired MAP simply by changing the position of the throttle control. This was post from thehttp://ma3naido.blogspot.com blog. sorry i miss the complete source at http://ma3naido.blogspot.com |
Screw It's Aircraft Tie Down System | User | Home Built | 20 | November 28th 06 05:31 PM |
Fire protection system for homebuilt aircraft | [email protected] | Home Built | 0 | February 22nd 05 12:57 AM |
S-Tec System 20/30 Versus System 40/50 | Marco Leon | Piloting | 3 | November 9th 04 04:15 PM |
Small Aircraft Transportation System (SATS) first practical trial | Larry Dighera | Piloting | 0 | November 27th 03 03:11 PM |
FA: AIRCRAFT/RACE CAR HALON FIRE EXT SYSTEM | N329DF | Aviation Marketplace | 0 | August 16th 03 03:11 PM |
