#41
Larry, I agree.
I drove at one point an extended version of the old Aero Star. This combination was good for about 60m/h max no wind, with the same sort of trailers I am towing now. This was ok for the odd retrieve and contest. The points you raised were also the things I was looking for in a new Mini Van. But only one Mini Van met those criteria, the Honda Odyssey. Low C of G, short coupled between ball hitch and rear independent suspension. Powerful and fun to drive, comfortable and reasonably good on gas. In any case I found it handled the Schreder trailer as well as a Cobra unit, The Schreder trailer Van combination use more gas then the cobra trailer combo. With the currant cobra trailer I noted a difference, even though this one is newer and has shocks. It was not as stable as the other cobra trailer. Lucky for me I marked my drive way for my first cobra trailer wheels. I noticed that the trailer was to close to the garage door. It turns out the wheels are to far forward by at least 10". Also the trailer hitch would not stay down when the trailer is empty, which all other trailers did with about 15 lb down force empty. I think that would explain the slightly less stable set-up In time I will move the axle. Udo and everything will be fine" approaches. In addition to the obvious things that have been written about in this thread (vehicle weights, tongue weights, tires and tire pressures, etc.) there are _many_ other significant factors in play. To name a few (very incomplete list): --moment arm of the hitch ball to rear axle of the car (one of the most significant from my experience) --suspension dynamics of tow vehicle --aerodynamic shape of the trailer --combined aerodynamic interactions between tow vehicle and trailer --environmental considerations where you tow ( prevailing wind, etc.) --proximity to field effects of passing vehicles, etc. --necessary or desired speed for trip -- on and on....... So to say that "Towing is simple. Follow these rules, and your rig will be stable in all conditions and not need stabiliser hitch." is in my experience a gross oversimplification. Larry - |
#42
Tom Gardner wrote:
Martin Gregorie wrote in news:kg50u4- : I'd never knock the series II or III. Mine did a London-India out and return in 10 months without any problems apart from a tendency to consume speedometers that I never got to the bottom of, a clutch change in Mysore and a clutch slave cylinder replacement in Turkey. I had a series II with a 4litre perkins diesel engine. Yes, it would pull the skin off custard, and yes the engine mountings and transmission spiders were problematical. Mine had the trad. 4 cyl 2.25 litre petrol engine and it would happily pull skin off custard, but slowly. However, the engine mountings and transmission were plenty strong enough for that small donk. The standard diesel was a dog (a diesel version of the four potter, gutless and noisy). The other standard engine, the 2.6 litre petrol straight six was also bad news. It was all revs and no torque and very thirsty with it. However, when we hit Asia I did rather wish I had the diesel because that was never more than half the price of petrol from the Bosphorus east and at that time [1] in Iran it was 1/5 the price of petrol. I had at least fitted an electronic ignition that moved the beast up from 16 mpg to 18 mpg. Mine seemed to have a lot of parts in common with Minis, e.g. rear lights and driver's seat. Mine was the 10-12 seat wagon version with up-market seating for five. I don't recall any Mini parts but it was a long time ago. [1] 1977/78 when the ******* Shah and his nasty Savak were still there. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#43
On Oct 12, 3:57 pm, "01-- Zero One" wrote:
So to say that "Towing is simple. Follow these rules, and your rig will be stable in all conditions and not need stabiliser hitch." is in my experience a gross oversimplification. Think we'll have to agree to disagree - but I'd like to know of examples where these guidelines were met, but the rig was still unstable. One thing I don't mention which could be called an "oversimplification" is weight distribution within the trailer, mass should be concentrated low and over the axle. However you don't usually have much choice about that with a glider. Dan |
#44
On Oct 11, 9:51 pm, Eric Greenwell wrote:
Dan G wrote: We've discussed this one before, and there is no evidence suggesting 7% is appropriate for glider trailers, as the number comes from a study of caravans (travel trailers). The more common numbers are 10%-15%, also with the requirement to stay within the vehicle and hitch load specifications. I won't disagree, though I'm not sure glider trailers and caravans are *that* different. I guess the real "rule" is simply having plenty of weight on the hitch, but not more than the tow vehicle is rated for. The list does not include the most important factor: speed. Every tow vehicle and trailer is stable below some speed; unfortunately, there isn't any safe and easy way to determine this that I know of. I do suspect most trailer accidents from loss of control could be avoided if the driver had paid attention to signs of instability in the past, and drove more slowly as a result. Isn't that common sense, really? Dan |
#45
On Oct 11, 3:41 pm, Eric Greenwell wrote:
Dan G wrote: Crash-worthiness and energy absorbtion is ENTIRELY down to design, not material. The major glider manufacturers don't agree with this: take look at the cockpit of a Schleicher glider, for example, and see how little of it is carbon fiber. Aramids and glass fiber absorb energy better than carbon fiber, and so a designer will use them if it is possible. Didn't I say it's design, not material? :-) However Shleicher do actually use carbon fibre reinforcements on at least some of their cockpits - check their website: http://www.alexander-schleicher.de/p...g29_main_e.htm Lange might do too - they say they use "F1 materials" for the cockpit of the Antares. The underlying point is that you want the safety cell - whether car, glider or even train cab - to be extremely strong to resist collapse, with deformable parts elsewhere to absorb energy and hence lower peak G on the occupant. Dan |
#46
Dan G wrote:
On Oct 11, 9:51 pm, Eric Greenwell wrote: Dan G wrote: We've discussed this one before, and there is no evidence suggesting 7% is appropriate for glider trailers, as the number comes from a study of caravans (travel trailers). The more common numbers are 10%-15%, also with the requirement to stay within the vehicle and hitch load specifications. I won't disagree, though I'm not sure glider trailers and caravans are *that* different. Even glider trailers can differ markedly from one another, so it's no stretch to imagine caravans (less than half the length, 30% wider, and twice as tall as a glider trailer of the same weight) might act very differently behind the same tow vehicle. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#47
Dan G wrote:
On Oct 11, 3:41 pm, Eric Greenwell wrote: Dan G wrote: Crash-worthiness and energy absorbtion is ENTIRELY down to design, not material. The major glider manufacturers don't agree with this: take look at the cockpit of a Schleicher glider, for example, and see how little of it is carbon fiber. Aramids and glass fiber absorb energy better than carbon fiber, and so a designer will use them if it is possible. Didn't I say it's design, not material? :-) However Shleicher do actually use carbon fibre reinforcements on at least some of their cockpits - check their website: http://www.alexander-schleicher.de/p...g29_main_e.htm All Schleicher gliders, beginning with the ASW 24, use carbon fiber rails on the cockpit sill, but even on the ASG 29, most of the cockpit structure is still glass fiber and aramid composite. Gerhard Waibel had an excellent article describing the design of the ASW 24 cockpit, considered the first of the modern "safety cockpits", in Soaring Magazine about 20 years ago, and also more recent articles in Technical Soaring. Those articles can explain the design of an improved cockpit much better than I can here. Lange might do too - they say they use "F1 materials" for the cockpit of the Antares. The underlying point is that you want the safety cell - whether car, glider or even train cab - to be extremely strong to resist collapse, with deformable parts elsewhere to absorb energy and hence lower peak G on the occupant. To the contrary, Schleicher and the others have chosen not to use a "safety cell" design. The nose would have to extend several feet beyond were it does now to have sufficient crush distance, and they do not believe pilots will buy such a glider. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#48
of the Antares. The underlying point is that you want the safety cell - whether car, glider or even train cab - to be extremely strong to resist collapse, with deformable parts elsewhere to absorb energy and hence lower peak G on the occupant. To the contrary, Schleicher and the others have chosen not to use a "safety cell" design. The nose would have to extend several feet beyond were it does now to have sufficient crush distance, and they do not believe pilots will buy such a glider. Lange does use a crush zone, and it certainly did not require "several feet longer fuselage" for Antares. See: http://www.lange-flugzeugbau.de/htm/...0e/safety.html The crushable nose-cone is a separate part from the remainder of the safety cockpit, attached late in the manufacturing. I'll try get some pictures on my web site... See ya, Dave "YO" |
#49
Just to clear some things up:
The Antares family of gliders has been designed with a safety cell and energy absorbing nosecone. In order to facilitate this, the cockpit was extended forward at approximately zero aerodynamic loss. The whole cockpit is using a special carbon-carbon technology (no kevlar or dyneema), and was designed mainly by a F1 crash structure designer. The safety cell has been design to fail only after there is nothing left to save inside (due to extreme g-loads). Fitting the lower part of the pilot into the crumble-zone is, in my personal opinion, not the best of ideas, as damage to the feet tend to take extremely long to heal. Andor At 02:18 13 October 2007, Eric Greenwell wrote: Dan G wrote: On Oct 11, 3:41 pm, Eric Greenwell wrote: Dan G wrote: Crash-worthiness and energy absorbtion is ENTIRELY down to design, not material. The major glider manufacturers don't agree with this: take look at the cockpit of a Schleicher glider, for example, and see how little of it is carbon fiber. Aramids and glass fiber absorb energy better than carbon fiber, and so a designer will use them if it is possible. Didn't I say it's design, not material? :-) However Shleicher do actually use carbon fibre reinforcements on at least some of their cockpits - check their website: http://www.alexander-schleicher.de/p...sg29_main_e.ht m All Schleicher gliders, beginning with the ASW 24, use carbon fiber rails on the cockpit sill, but even on the ASG 29, most of the cockpit structure is still glass fiber and aramid composite. Gerhard Waibel had an excellent article describing the design of the ASW 24 cockpit, considered the first of the modern 'safety cockpits', in Soaring Magazine about 20 years ago, and also more recent articles in Technical Soaring. Those articles can explain the design of an improved cockpit much better than I can here. Lange might do too - they say they use 'F1 materials' for the cockpit of the Antares. The underlying point is that you want the safety cell - whether car, glider or even train cab - to be extremely strong to resist collapse, with deformable parts elsewhere to absorb energy and hence lower peak G on the occupant. To the contrary, Schleicher and the others have chosen not to use a 'safety cell' design. The nose would have to extend several feet beyond were it does now to have sufficient crush distance, and they do not believe pilots will buy such a glider. -- Eric Greenwell - Washington State, USA * Change 'netto' to 'net' to email me directly * 'Transponders in Sailplanes' http://tinyurl.com/y739x4 * 'A Guide to Self-launching Sailplane Operation' at www.motorglider.org |
Saturn V Vehicle for the Apollo 4 Mission in the Vehicle Assembly Building 6754387.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 01:38 AM |
Lunar Roving Vehicle Installation of the Lunar Roving Vehicle in the Lunar Module.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 02:47 PM |
Suburban as a tow vehicle? | Ken Ward | Soaring | 11 | March 3rd 07 03:40 PM |
Looking for a towable tow vehicle | [email protected] | Soaring | 19 | February 5th 05 02:14 AM |
Tow vehicle for sale | Sam Fly | Soaring | 0 | February 4th 05 06:06 PM |
