Tina,
and he's paying $100 an hour dry Hobbs time, As I said, my remarks hold only if cost is independent of power setting. Dry rentals are very uncommon, AFAIK. And I overread his remark that he is indeed renting dry blush. Sorry! Sure, but in terms of learning good flying techniques, don't you think slower is better than faster? Not at all. Both is important, IMHO. -- Thomas Borchert (EDDH) |
john wrote:
Shortly after getting my private license I went to a different FBO and got checked out in their aircrafts - C172 and Piper Cherokee. I talked with the CFI and asked what RPM settings he would recommend. I'm renting dry, so one way to reduce cost is to slow down and thus save fuel. At the present time I'm just building hours towards my commercial ticket. Rarely am I in a hurry to get anywhere. He mentioned that if I needed to get somewhere quickly, to keep it around 2400. If I'm just building time then to reduce to 2300. It will save fuel as well as reduce the sound level. The CFI no longer flies out of that airport, so I don't have contact with him. I'm interested in others opinions related to rpm settings. Is there any harm to the engine with reducing the RPM even lower, say 2200 or even 2100 RPM. I will confess to bringing it back to as low as 1800 for a short X-C and found it to be good slow flight practice., which gave my one leg a work out in order to keep the bubble in the middle. I wouldn't want to make many flights at 1800 though. In the 172 I have reduced fuel from over 7.5 gph at 2400rpm to about 5.5 gph at 2200-2300. What power settings are in the airplane's operation manual? Any setting listed by Cessna in the manual should be fine. Just don't forget to lean properly. Matt |
I cannot speak about a 172 but if you are actually cruising in slow
flight, as opposed to flying slow, I hope you are considering your cylinder head temperatures and oil temperature. John john wrote: Shortly after getting my private license I went to a different FBO and got checked out in their aircrafts - C172 and Piper Cherokee. I talked with the CFI and asked what RPM settings he would recommend. I'm renting dry, so one way to reduce cost is to slow down and thus save fuel. At the present time I'm just building hours towards my commercial ticket. Rarely am I in a hurry to get anywhere. He mentioned that if I needed to get somewhere quickly, to keep it around 2400. If I'm just building time then to reduce to 2300. It will save fuel as well as reduce the sound level. The CFI no longer flies out of that airport, so I don't have contact with him. I'm interested in others opinions related to rpm settings. Is there any harm to the engine with reducing the RPM even lower, say 2200 or even 2100 RPM. I will confess to bringing it back to as low as 1800 for a short X-C and found it to be good slow flight practice., which gave my one leg a work out in order to keep the bubble in the middle. I wouldn't want to make many flights at 1800 though. In the 172 I have reduced fuel from over 7.5 gph at 2400rpm to about 5.5 gph at 2200-2300. Thanks, John |
Thanks for all of your imputs.
I don't have a 1974 POH, but I do have one for the 1978. It list the green arc as 2200 - 2700, so as long as I keep it in the green I should be alright. I'll check the 1974 POH next time I use that plane, but I would be surprised if it is different since they have the same engine. I do keep an eye on the temp guage. The main plane that I fly tends to run a little hot anyways so reducing the throttle helps keep the temps where they need to be. In response to Kontiki's suggestion on new and interesting place, I need the X-C time as well, so yes, I try to pick x-c trips when I have more than an hour or two planned. Last week I took a friend up so that he could take pictures of some land. When he was finished I asked if he needed to get back right away. Since he didn't, I diverted to an airport 30 miles further south where we landed and grabbed a coke. I only need another 2 hours to complete the X-C requirement, which I should complete next week when I take another friend out for dinner. However, my goal is to land at every public airport in the state. So I will have more than the hours needed in that catagory. John On Oct 14, 8:08 am, The Visitor wrote: I cannot speak about a 172 but if you are actually cruising in slow flight, as opposed to flying slow, I hope you are considering your cylinder head temperatures and oil temperature. John john wrote: Shortly after getting my private license I went to a different FBO and got checked out in their aircrafts - C172 and Piper Cherokee. I talked with the CFI and asked what RPM settings he would recommend. I'm renting dry, so one way to reduce cost is to slow down and thus save fuel. At the present time I'm just building hours towards my commercial ticket. Rarely am I in a hurry to get anywhere. He mentioned that if I needed to get somewhere quickly, to keep it around 2400. If I'm just building time then to reduce to 2300. It will save fuel as well as reduce the sound level. The CFI no longer flies out of that airport, so I don't have contact with him. I'm interested in others opinions related to rpm settings. Is there any harm to the engine with reducing the RPM even lower, say 2200 or even 2100 RPM. I will confess to bringing it back to as low as 1800 for a short X-C and found it to be good slow flight practice., which gave my one leg a work out in order to keep the bubble in the middle. I wouldn't want to make many flights at 1800 though. In the 172 I have reduced fuel from over 7.5 gph at 2400rpm to about 5.5 gph at 2200-2300. Thanks, John- Hide quoted text - - Show quoted text - |
![]() Mortimer Schnerd, RN wrote: One thought about continued flight at 1800 rpm: if you were running with the carb heat on to avoid icing, then you're ingesting unfiltered air. Best to keep that at a minimum if you can. In a cruise flight you should be running the amount of carb heat that gives you a carb temp of 40F. |
![]() Don't they teach Flight for Range in the U.S.? Start at cruise RPM. Record the airspeed when things have stabilized. Reduce the RPM by 100, wait for everything to stabilize, including adjusting the throttle for the RPM target, trim the airplane for level flight, and record the airspeed again. Do this in 100 RPM increments until the airspeed suffers a much bigger drop than with the previous settings, and go back to the last setting. Now you have the lowest fuel flow for the best airspeed. Be sure to lean as necessary and keep that RPM where it should be. Remember the power setting for that airplane for the next time. Best endurance involves finding the lowest RPM where the airplane will maintain altitude. It'll be a pretty slow airplane. Slow flight involves a lower airspeed but more power to maintain the altitude. Dan |
john wrote:
I don't have a 1974 POH, but I do have one for the 1978. It list the green arc as 2200 - 2700, so as long as I keep it in the green I should be alright. I'll check the 1974 POH next time I use that plane, but I would be surprised if it is different since they have the same engine. That's simply the normal operating range. The POH will also have graphs or tables that will give you power and fuel burn information for various altitudes and temperatures. Use them. I often hear pilots saying things like, "What rpm should I use for cruise? " and hardly ever hear the correct answer, which is : It depends. What it depends on is the amount of power you wish to generate, and the density altitude at which you'll be flying. To make a given percentage of power, the rpm required will increase as the density altitude increases (in a fixed pitch plane like the 172). If you want to fly around at an economical 55% power setting, the rpm you should set will be very different if you're flying low on a cold day, or high on a hot day. Quick example : The rpm that I use in my Cherokee to fly 75% cruise at 6, 000 ft. on a hot day is very close to the rpm that I'd use to fly at 100% power (not a good cruise setting) near sea level on a standard day. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200710/1 |
It seems to me that you would set up whatever power required to cruise at
best L/D and that would necessarily give you best range. Brett "JGalban via AviationKB.com" u32749@uwe wrote in message news:79bea10122a88@uwe... john wrote: I don't have a 1974 POH, but I do have one for the 1978. It list the green arc as 2200 - 2700, so as long as I keep it in the green I should be alright. I'll check the 1974 POH next time I use that plane, but I would be surprised if it is different since they have the same engine. That's simply the normal operating range. The POH will also have graphs or tables that will give you power and fuel burn information for various altitudes and temperatures. Use them. I often hear pilots saying things like, "What rpm should I use for cruise? " and hardly ever hear the correct answer, which is : It depends. What it depends on is the amount of power you wish to generate, and the density altitude at which you'll be flying. To make a given percentage of power, the rpm required will increase as the density altitude increases (in a fixed pitch plane like the 172). If you want to fly around at an economical 55% power setting, the rpm you should set will be very different if you're flying low on a cold day, or high on a hot day. Quick example : The rpm that I use in my Cherokee to fly 75% cruise at 6, 000 ft. on a hot day is very close to the rpm that I'd use to fly at 100% power (not a good cruise setting) near sea level on a standard day. John Galban=====N4BQ (PA28-180) -- Message posted via AviationKB.com http://www.aviationkb.com/Uwe/Forums...ation/200710/1 |
By Aerodynamic Definition, your most efficient cruise speed for time
aloft is the the drag curve minima (point between the induced drag curve and the profile drag curve), which also conveniently happens to be defined as Vg. This is the speed at which the aircraft requires the least amount of energy to stay aloft. Power back to maintain Vg, lean the hell out of it (At such a low power setting detonation is a non-issue), and cruise to your hearts content. Do not fly "as slow as possible", keep in mind if your airspeed drops below Vg, your power requirements will actually go back up. -Scott |
Bob Moore wrote in
46.128: EridanMan wrote By Aerodynamic Definition, your most efficient cruise speed for time aloft is the the drag curve minima (point between the induced drag curve and the profile drag curve), which also conveniently happens to be defined as Vg. This is the speed at which the aircraft requires the least amount of energy to stay aloft. By who's definition? In 50 years of flying, 39 years of instructing, 10 years military and 25 years of airline flying, I've never heard of Vg, L/D Max maybe, even Best Glide Speed, but Vg? Not here in the USofA. Neither have I. And I can add glider to that list. Bertie |
setting up a Garmin 296 | Cub Driver | Piloting | 10 | October 29th 04 08:43 PM |
Setting up for an approach | C Kingsbury | Piloting | 1 | August 12th 04 01:09 AM |
Setting QNH | BTIZ | Piloting | 31 | March 12th 04 04:29 PM |
ASW-20 flaps setting VS speed | AttentionLEcureuil | Soaring | 4 | March 9th 04 11:25 PM |
Setting up the workshop.... | Evan Batchelor | Restoration | 3 | March 4th 04 02:54 PM |
