#21
On Oct 15, 10:27 am, Ron Wanttaja wrote:
So then I assume the pilot would need a current class 3 medical, correct? Correct, but only when performing those tasks that require use of a Recreational or higher license. A Sport Pilot can climb into the airplane and fly day VFR, but if he's going to go on the gauges he needs the appropriate license and rating (and medical to go with the license). In this case the task of flying IFR requires at least a private rating so a class 3 medical seems to be required. The FAA made a big terminology mistake with the new rules; they use the same term for a *definition* as for an aircraft certification category. Any aircraft meeting the 14 CFR Part 1 definition for "Light Sport Aircraft" can be flown by a pilot exercising Sport Pilot privileges, whether it's a Private pilot with an expired medical, or a person with the new Sport Pilot rating. This definition is summarized at: I understand that. In fact that was my point. A LSA can be IFR certified but in order to fly it a pilot now must have a medical. So the idea of letting your medical lapse when you get old and buying an LSA only works for VFR. For IFR you have to exercise the priv of an instrument rated private pilot and not the priv of a sport pilot. -Robert |
Robert M. Gary wrote:
On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. |
Matt Barrow wrote:
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in message ... Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified. http://www.newplane.com/amd/amd/601_SLSA/601.html Ya know, I can't imagine spending an hour on a seven mile final in IMC. :~( Lots of actual time for the log book. ![]() |
#24
Gig 601XL Builder wrote:
Robert M. Gary wrote: On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. Yes. I'm instrument rated and was simply wondering what, if any, LSA's could be flown IFR. I;m debating whether to buy one just for fun flying, but with the capability to occasionally fly in IMC if needed. I can buy a 20 year-old 182 that burns 12 GPH or I can buy a new LSA that burns half that ... and is new! Yes, I give up two seats, but most of my flying is alone anyway or with one other person, so I'll just rent when I need four seats. That was the rationale behind my question. Matt |
#25
Almost entirely. Some of the control surfaces are fabric covered on the
older models and parts of the cowling have some composites. The rest is aluminum. Matt Whiting wrote: Is the Tecnam all aluminum? I'd be worried about a composite airplane taking a lightning hit if it doesn't have the embedded metal mesh, etc. Matt |
#26
What the FAA issues is a Special Airworthiness Certificate rather than a
standard airworthiness certificate. While issued by the FAA, the standards that must be met are all published by ASTM rather than the FAA. Helen Matt Whiting wrote: Helen wrote: The VFR only limitation is strictly on the light sport airman not the light sport aircraft. You aren't going to find this anywhere in the FARs because most of these planes are not certified by the FAA, but by ASTM. Are you sure about this? I thought the FAA still had to certify them, just that they will certify any that meet the ASTM standard. Matt |
#27
Helen wrote:
What the FAA issues is a Special Airworthiness Certificate rather than a standard airworthiness certificate. While issued by the FAA, the standards that must be met are all published by ASTM rather than the FAA. Helen Matt Whiting wrote: Helen wrote: The VFR only limitation is strictly on the light sport airman not the light sport aircraft. You aren't going to find this anywhere in the FARs because most of these planes are not certified by the FAA, but by ASTM. Are you sure about this? I thought the FAA still had to certify them, just that they will certify any that meet the ASTM standard. Matt Yes, understand. However, I still think it is the FAA that is really certifying the aircraft even though they aren't developing the standards. I don't think ASTM has any authority to certify aircraft, but I could be wrong. Matt |
#28
Matt Whiting wrote:
Gig 601XL Builder wrote: Robert M. Gary wrote: On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. Yes. I'm instrument rated and was simply wondering what, if any, LSA's could be flown IFR. I;m debating whether to buy one just for fun flying, but with the capability to occasionally fly in IMC if needed. I can buy a 20 year-old 182 that burns 12 GPH or I can buy a new LSA that burns half that ... and is new! Yes, I give up two seats, but most of my flying is alone anyway or with one other person, so I'll just rent when I need four seats. That was the rationale behind my question. Matt Then follow that link up there the 601XLi might be just the plane for you. |
#29
On Oct 12, 7:30 pm, Matt Whiting wrote:
Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt You've gotten a lot of good replies here so it may be redundant, but I did want to mention I saw the Skycatcher at OshKosh and asked one of the Cessna salesdrones if it would be IFR capable and he said no. Putting the technical and regulatory limitations aside, I doubt Cessna would want to cannibalize 172 sales by offering a much cheaper IFR alternative. |
#30
Matt Whiting wrote: Gig 601XL Builder wrote: Robert M. Gary wrote: On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote: Robert M. Gary wrote: On Oct 12, 4:30 pm, Matt Whiting wrote: Does anyone know if the Skycatcher will be IFR certified? It doesn't appear to be from what little I've found at the Cessna web site. Matt Will Sport aircraft be allowed to be IFR certified? -Robert There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html So then I assume the pilot would need a current class 3 medical, correct? -Robert And an IFR ticket. But the question wasn't about pilot certificates it was about aircraft. Yes. I'm instrument rated and was simply wondering what, if any, LSA's could be flown IFR. I;m debating whether to buy one just for fun flying, but with the capability to occasionally fly in IMC if needed. I can buy a 20 year-old 182 that burns 12 GPH or I can buy a new LSA that burns half that ... and is new! Yes, I give up two seats, but most of my flying is alone anyway or with one other person, so I'll just rent when I need four seats. That was the rationale behind my question. Matt Then follow that link up there the 601XLi might be just the plane for you. Except that the wing is in the wrong place! Matt |
Cessna's new LSA: "Skycatcher" | Jim Logajan | Piloting | 107 | September 23rd 07 01:18 AM |
Cessna's new LSA: "Skycatcher" | Jim Logajan | Owning | 110 | September 23rd 07 01:18 AM |
Cessna's new LSA: "Skycatcher" | miffich | Piloting | 1 | July 24th 07 12:04 AM |
