#161
Le Chaud Lapin wrote in
ups.com: On Oct 16, 3:47 am, "Androcles" wrote: "Le Chaud Lapin" wrote in glegroups.com... : On Oct 15, 7:54 pm, "Androcles" wrote: : "Le Chaud Lapin" wrote in ooglegroups.com... : : On Oct 15, 6:42 pm, "Gatt" wrote: : : "Le Chaud Lapin" wrote in : messagenews:1192488325.423647.30120 @i38g2000prf.googlegroups.com.. : . : : : : I read last night in another piloting book, again, that the : : common : belief : : about the dynamics of airfoils is wrong, : : : : Yeah? Which one? : : : : I'd have to go back to bookstore to find the name. : : AHAHAHAHAHAHA! : Or back to sleep to dream again... : : Barry Schiff, in "The Proficient Pilot", "An AOPA Book", writes on : page 2: : : "There is, for example, this amusing fable: "Air flowing above the : wing has a greater distance to travel (because of camber) than air : flowing beneath the wing. Therefore, air above the wing must travel : faster so as to arrive at the wing's trailing edge at the same time : as air flowing underneath. This is pure nonsense." Since it is true Schiff must be a raving lunatic. Maybe you don't understand that travelling the greater path in the same time involves a greater speed. Perhaps you could explain in detail what you mean by this last statement. I am sure that there are plenty of people here would would like, for once, that a pilot explains what s/he means by this. What's it matter? Yo'll never be a pilot. Any math that wil enable you to dial up for home delivered pizza and escargot should suffice. # Bertie |
#162
oups.com: On Oct 16, 5:01 am, "BDS" wrote: "Le Chaud Lapin" wrote Therefore, one could conclude that the vitriolic attacks against me personally for broaching the subject might be a sign of something deeper, perhaps the attackers' distaste for having the topic openly discussed. And yet still, after my 1st post, after more than 600 replies cummulative, not one pilot has dared answered the question why the bottom paper rises. [Yawn] Perhaps no one here is interested in discussing this with you and going out of their way to help you to learn because of your abrasive and insulting approach. I think you will find that pilots with a considerable amount of experience no longer feel like they have anything to prove, so the "insulting challenge" approach does not work with them. IOW, they are not interested in trying to impress you. What about my orignial post is abrasive and insulting? Bwawahwhahwhahwhahwhahhwhahwhahwwhahwhahwhahhwhahw hahwwhahwhahwhahhwhahw hahwwhahwhahwhahhwhahwhahwwhahwhahwhahhwhahwhahwwh ahwhahwhahhwhahwhahwwh ahwhahwhahhwhahwhahwwhahwhahwhahhwhahwhahwwhahwhah whahhwhah Bertie |
#163
On Oct 16, 6:31 am, Thomas wrote:
On 9 Oct, 21:08, Le Chaud Lapin wrote: You may want to check out my web pageshttp://www.physicsmyths.org.uk/bernoulli.htm andhttp://www.physicsmyths.org.uk/drag.htm for a closer examination of the physics behind the aerodynamic lift and drag. The main point I am making there is that it is physically nonsense to claim that changing merely the tangential velocity of the air stream relative to the surface would in any way produce a resultant force (at least for a non-viscous gas). What one needs for a pressure change (and thus a force) on the surface is a change in the numbers and/or the velocity of the molecules hitting it, i.e. it is only the vertical component of the velocity that is relevant here. Only this can produce the lift for an airfoil, either because of the increased number of collisions on the lower side or the decreased number of collisions on the upper side (both situations lead to a lift). I agree, but there are some that seem to think the contrary, as you know, with the Coanda effect. http://en.wikipedia.org/wiki/Coand%C4%83_effect What is troubling about many of these theories is that, at the precise moment where the reader is most alert in anticipation of the meat of the explanation, the hand-waving begins. In the link above, the clause entitled Causes, it is written: "The effect of a spoon apparently attracting a flow of water is caused by this effect as well, since the flow of water entrains gases to flow down along the stream, and these gases are then pulled, along with the flow of water, in towards the spoon, as a result of the pressure differential. " Hmmm...."and these gases are then pulled"... pulled? By what? And it should be obvious that for this to be the case, one must either have the lower side of the wing facing to a certain degree into the airstream, and/or the upper side facing to a certain degree opposite to the airstream. This is why one either needs a certain 'angle of attack' or a correspondingly shaped airfoil. And it should be obvious that in order to have an asymmetric force (i.e. a higher upward than downward force) one needs the surfaces of the airfoil to be orientated in some way asymmetrical relatively to the airstream. So a perfectly symmetrical airfoil (front to back) at a zero angle of attack (like I indicated in Fig.1 on my pagehttp://www.physicsmyths.org.uk/bernoulli.htm) should not produce any lift as the upward force (from the rear part) is exactly equal to the downward force (from the front part). All that would happen is that the wing experiences an anti-clockwise torque. This is the reason why the rear part of the wing (behind the apex) must always have a larger surface than the front part. At least I have yet to see an airfoil where this is not the case and where it can be used at a zero angle of attack. (the Bernoulli principle is in direct contradiction to this as it would also predict a lift for a perfectly symmetric airfoil in this sense). I just read both your web pages. BTW, your explanation of d'Alembert's Paradox and the blow-over-paper- attached-to-table experiment could both use diagrams. I am trying the blow over the paper experiment now and I am not sure if I am doing it as you described. Could you provide a more vivid description so I can make sure? -Le Chaud Lapin- |
#164
![]() "Le Chaud Lapin" wrote in message ups.com... : On Oct 16, 3:47 am, "Androcles" wrote: : "Le Chaud Lapin" wrote in glegroups.com... : : On Oct 15, 7:54 pm, "Androcles" wrote: : : "Le Chaud Lapin" wrote in : ooglegroups.com... : : : On Oct 15, 6:42 pm, "Gatt" wrote: : : : "Le Chaud Lapin" wrote in : : oglegroups.com... : : : : : : I read last night in another piloting book, again, that the common : : belief : : : about the dynamics of airfoils is wrong, : : : : : : Yeah? Which one? : : : : : : I'd have to go back to bookstore to find the name. : : : : AHAHAHAHAHAHA! : : Or back to sleep to dream again... : : : : Barry Schiff, in "The Proficient Pilot", "An AOPA Book", writes on : : page 2: : : : : "There is, for example, this amusing fable: "Air flowing above the : : wing has a greater distance to travel (because of camber) than air : : flowing beneath the wing. Therefore, air above the wing must travel : : faster so as to arrive at the wing's trailing edge at the same time as : : air flowing underneath. This is pure nonsense." : : Since it is true Schiff must be a raving lunatic. Maybe you don't : understand that travelling the greater path in the same time involves : a greater speed. : : Perhaps you could explain in detail what you mean by this last : statement. I am sure that there are plenty of people here would would : like, for once, that a pilot explains what s/he means by this. Really? Ok, for plenty of cretins such as yourself... Travelling 70 miles (distance) in one hour (duration of time) is a speed of 70 mph by definition. 100 miles (the greater distance) in the same time (1 hour) is 100 mph. 100 mph is faster than 70 mph. People unaware of this simple fact are prone to getting speeding tickets and losing their license. Aircraft pilots are even more aware of it than motorists, using their stop watches to compute distance. In this video the air moves MUCH faster over the top of the wing than it does over the bottom: http://www.youtube.com/watch?v=KCcZyW-6-5o Now you can go back to sleep and dream of Barry Schiff and his "nonsense". |
#165
On Oct 16, 9:53 am, "Gatt" wrote:
Barry Schiff, in "The Proficient Pilot", "An AOPA Book", writes on page 2: "There is, for example, this amusing fable: "Air flowing above the wing has a greater distance to travel (because of camber) than air flowing beneath the wing. Therefore, air above the wing must travel faster so as to arrive at the wing's trailing edge at the same time as air flowing underneath. This is pure nonsense." Like I said. Upper camber is a conspiracy by the aluminum manufacturers to sell more metal... Bournoulli was a shill. You wrote repeatedly that lack of attention to detail (mostly due to my spelling errors) indicated lack of understangind, was not becoming of a critical thinker, etc...yet you keep making spelling errors youself. ![]() I never disputed Bernoulli's Principle, not once. I said that there was a lot of hand-waving going on when pilots uttered greater/lesser/ camber/Bernoulli in the same sentence. Bernoulli's principle is correct. That the camber influences lift is correct. But how the camber influences lift has nothing to do with greater distances traveled, IMO. -Le Chaud Lapin- |
#166
On Oct 16, 10:20 am, "Androcles" wrote:
"Le Chaud Lapin" wrote in oglegroups.com... : On Oct 16, 3:47 am, "Androcles" wrote: : "Le Chaud Lapin" wrote in glegroups.com... : : On Oct 15, 7:54 pm, "Androcles" wrote: : : "Le Chaud Lapin" wrote in : ooglegroups.com... : : : On Oct 15, 6:42 pm, "Gatt" wrote: : : : "Le Chaud Lapin" wrote in : : oglegroups.com... : : : : : : I read last night in another piloting book, again, that the common : : belief : : : about the dynamics of airfoils is wrong, : : : : : : Yeah? Which one? : : : : : : I'd have to go back to bookstore to find the name. : : : : AHAHAHAHAHAHA! : : Or back to sleep to dream again... : : : : Barry Schiff, in "The Proficient Pilot", "An AOPA Book", writes on : : page 2: : : : : "There is, for example, this amusing fable: "Air flowing above the : : wing has a greater distance to travel (because of camber) than air : : flowing beneath the wing. Therefore, air above the wing must travel : : faster so as to arrive at the wing's trailing edge at the same time as : : air flowing underneath. This is pure nonsense." : : Since it is true Schiff must be a raving lunatic. Maybe you don't : understand that travelling the greater path in the same time involves : a greater speed. : : Perhaps you could explain in detail what you mean by this last : statement. I am sure that there are plenty of people here would would : like, for once, that a pilot explains what s/he means by this. Really? Ok, for plenty of cretins such as yourself... Travelling 70 miles (distance) in one hour (duration of time) is a speed of 70 mph by definition. 100 miles (the greater distance) in the same time (1 hour) is 100 mph. 100 mph is faster than 70 mph. People unaware of this simple fact are prone to getting speeding tickets and losing their license. Aircraft pilots are even more aware of it than motorists, using their stop watches to compute distance. In this video the air moves MUCH faster over the top of the wing than it does over the bottom: http://www.youtube.com/watch?v=KCcZyW-6-5o I just looked at this video. What you wrote and what this video demonstrates are two entirely different things. There is no reason to say that the air moving above the wing must meet beneath the wing. I keep hearing people say, "The air moves faster, therefore Bernoulli's Principle must be invoked." The thesis of what I have been saying all along can be seeing in an inversion of this sentence. "It is Bernoulli's principle that causes the air to flow faster." In particular, it is the pressure gradient that causes the air in the contstriction to flow faster. This same pressure gradient exists above a wing in an air craft, and it has nothing to do with the distance traveled. The camber of the wing is carefully designed my airfcraft manufacturers to incudes, as much as possible, this pressure gradient, at a particular speed, but *with* the conflicting requirement that resulting drag must be reduced. This is why I said earlier that pressure at the front of the wing is not necessarily bad. It is desirable, but it also causes some laminar drag. Intuitively, one can see what the edge must not be made sharp - doing that would elimate the very pressure that is need to bring about the pressure gradient. Now you can go back to sleep and dream of Barry Schiff and his "nonsense". -Le Chaud Lapin- |
#167
![]() "Bertie the Bunyip" wrote What's it matter? Yo'll never be a pilot. Any math that wil enable you to dial up for home delivered pizza and escargot should suffice. # Are you kidding? He doesn't have a job to provide enough money for escargot. The only escargot he is going to see is from the snails he plucks out of the river! Mmmmmm! -- Jim in NC |
#168
![]() "Le Chaud Lapin" wrote in message ups.com... : On Oct 16, 10:20 am, "Androcles" wrote: : "Le Chaud Lapin" wrote in oglegroups.com... : : On Oct 16, 3:47 am, "Androcles" wrote: : : "Le Chaud Lapin" wrote in : glegroups.com... : : : On Oct 15, 7:54 pm, "Androcles" wrote: : : : "Le Chaud Lapin" wrote in : : ooglegroups.com... : : : : On Oct 15, 6:42 pm, "Gatt" wrote: : : : : "Le Chaud Lapin" wrote in : : : oglegroups.com... : : : : : : : : I read last night in another piloting book, again, that the : common : : : belief : : : : about the dynamics of airfoils is wrong, : : : : : : : : Yeah? Which one? : : : : : : : : I'd have to go back to bookstore to find the name. : : : : : : AHAHAHAHAHAHA! : : : Or back to sleep to dream again... : : : : : : Barry Schiff, in "The Proficient Pilot", "An AOPA Book", writes on : : : page 2: : : : : : : "There is, for example, this amusing fable: "Air flowing above the : : : wing has a greater distance to travel (because of camber) than air : : : flowing beneath the wing. Therefore, air above the wing must travel : : : faster so as to arrive at the wing's trailing edge at the same time as : : : air flowing underneath. This is pure nonsense." : : : : Since it is true Schiff must be a raving lunatic. Maybe you don't : : understand that travelling the greater path in the same time involves : : a greater speed. : : : : Perhaps you could explain in detail what you mean by this last : : statement. I am sure that there are plenty of people here would would : : like, for once, that a pilot explains what s/he means by this. : : Really? : Ok, for plenty of cretins such as yourself... : : Travelling 70 miles (distance) in one hour (duration of time) : is a speed of 70 mph by definition. : 100 miles (the greater distance) in the same time (1 hour) : is 100 mph. : 100 mph is faster than 70 mph. : People unaware of this simple fact are prone to getting : speeding tickets and losing their license. : Aircraft pilots are even more aware of it than motorists, : using their stop watches to compute distance. : : In this video the air moves MUCH faster over the top of the wing : than it does over the bottom: : http://www.youtube.com/watch?v=KCcZyW-6-5o : : I just looked at this video. : : What you wrote and what this video demonstrates are two entirely : different things. There is no reason to say that the air moving above : the wing must meet beneath the wing. What do you think it meets, water? : : I keep hearing people say, : : "The air moves faster, therefore Bernoulli's Principle must be : invoked." That's right. : : The thesis of what I have been saying all along can be seeing in an : inversion of this sentence. : : "It is Bernoulli's principle that causes the air to flow faster." Oh sure... and it is falling that causes gravity and losing that causes cretins to buy lottery tickets. As the other person said, your entertainment value is zero. *plonk* |
#169
![]() "BDS" wrote Please do. Might I suggest you try a different approach when you ask someone for help? Too late. Everyone knows that he is not worth the dynamite it would take to blow him to H*ll and back. -- Jim in NC |
#170
On Oct 16, 11:04 am, "Androcles" wrote:
"Le Chaud Lapin" wrote in : In this video the air moves MUCH faster over the top of the wing : than it does over the bottom: : http://www.youtube.com/watch?v=KCcZyW-6-5o : : I just looked at this video. : : What you wrote and what this video demonstrates are two entirely : different things. There is no reason to say that the air moving above : the wing must meet beneath the wing. What do you think it meets, water? BTW, there is nothing in that video about airplane wings. It only shows Bernoulli's principle using smoke stacks, hanging balls, piece of paper, etc. At no point do I see any demonstration of air above and below having disparity in speed, unless you count the book. -Le Chaud Lapin- |
Pilot's Assistant V1.6.7 released | AirToob | Simulators | 2 | July 7th 07 10:43 AM |
A GA pilot's worst nightmare? | Kingfish | Piloting | 49 | February 1st 07 02:51 PM |
Pilot's Political Orientation | Chicken Bone | Piloting | 533 | June 29th 04 12:47 AM |
Update on pilot's condition? | Stewart Kissel | Soaring | 11 | April 13th 04 09:25 PM |
Pilot's Funeral/Memorial | TEW | Piloting | 6 | March 17th 04 03:12 AM |
