Tow Vehicle Woes
Old October 16th 07, 02:25 PM posted to rec.aviation.soaring
rlovinggood
Default Tow Vehicle Woes
The discussion on tow vehicles hits home. I have to replace the
trusty Accord with something that has a beefier hitch attachment
point.
I've managed to rip the hitch off from the bottom of the trunk twice
now.
Car: 2000 Honda Accord V6 sedan, 201,000 miles.
Trailer: 2006 Swan, with fiberglass top. Tongue weight: 170 lbs.
Total weight: Not yet weighed, but empty trailer is, according to the
manufacturer, 500 kg and the glider (LS1-d)weighs around 550 lbs, I
think. I would imagine the total trailer weighs about 1,700 lbs. I
hope to weigh it soon.
The first hitch attached with three bolts to the bottom of the Honda
trunk. The sheet metal measures "Oh Too Thin" I found out the hard
way. I think the trunk started tearing when the trailer hitch
wouldn't release from the knob as I was cranking the trailer hitch up
off of the knob and I was lifting the rear end of the car. Why was
the knob sticking? Because, unknown to me at the time, the Al-Ko
hitch has a little rubber cover that provides a cushion for the
trailer tongue when you back your car's bumper into it. It prevents
the trailer tongue from scratching your bumper. Well, a bit of the
rubber would get caught on the knob when hooking up the trailer and
when I tried to release, I would end up jacking up the rear of the car
a bit and stomp on the trailer hitch to release it. I thought it was
just a tight connection. Turns out the car wasn't made for this
abuse. Duh.
A body shop welded up the trunk and I found another hitch design.
This one bolted to the "frame" in two points and also to the "tie
down" or "tow" loop that is right over the center of the hitch. The
first hitch bolted here, too.
But I've managed to tear that out too. I think I did that when I
bottomed out recently. That is, when I drove the car out of a gravel
driveway onto a road and the trailer hitch hit the ground. I suppose
that's when the bottom of the trunk cracked around the central hitch
attachment point.
Damn.
So now, I need a vehicle that I can afford to buy, and afford to
commute 80 miles per day to work. Oil just hit US$88 per barrel.
I try to ride a bus to work as often as I can, but sometimes, I still
drive.
So, no, I'm not buying a Ford F-150 or Chevy pickup truck. I'm not
getting an Avalanche or Ford Excursion. In fact, I'm not getting a
Ford of anything. I've had two and they both lived up to the name of
"Found on the Road Dead."
I wish Honda had their turbo diesel here in America in the CR-V.
Sigh.
So, I think I've narrowed my search to the current Toyota RAV4 with V6
and the current Hyundai Santa Fe with V6. Both seem to have good
reviews in media that I have found. The plus for the RAV4 is that it
is a Toyota. It also gets about the same mileage as my Accord, even
with all wheel drive and 69 more horsepower! The Hyundai gets
excellent reviews on safety, but mileage isn't as good as the RAV4.
Both are rated to tow 2,000 lbs without the trailer towing package.
And both can tow 3,500 lbs with the tow package.
Which shall it be? I don't know, the story isn't over yet. But if
anyone wants a good hitch for a 2000 Accord (probably fit any sixth
generation Accord), send me a note. Should be great for a bicycle
rack.
Ray Lovinggood
Carrboro, North Carolina, USA
Have trailer and glider, but no tow vehicle
Old October 16th 07, 03:08 PM posted to rec.aviation.soaring
Udo
My Honda Odyssey has a sub frame which holds a 3500 lb hitch.
I understand may car is based on an Accord chassis.
I have 120000 miles on it 75% of it with my trailer.
On its own, at normal highway speed, I get 25-27m/g
If you like your accord you will love the Odyssey, new or used
Udo
Old October 16th 07, 04:28 PM posted to rec.aviation.soaring
Bob Salvo
Check out Saturn Vue Hybrid. A fellow contest pilot is very happy with his.
Old October 16th 07, 06:20 PM posted to rec.aviation.soaring
rlovinggood
A coworker has a 2007 Toyota Highlander Hybrid with a towing package.
It's rated to tow something like 3,300 or 3,500 lbs. It is
interesting, but PRICEY!
The new Saturn Vue, based on an Opel does look nice, but one "little"
thing turned me off: A 40 foot turning radius. No, I won't be
turning tight pulling a trailer, but my "tow" vehicle HAS to be my
every day driver, too. I don't want to take up so much space just to
turn around. The others I'm looking at turn somewhere in the 34 feet
to 36 feet radius. Not much less? Doesn't seem like it, but I think
40' is pushing it a bit.
Also, I'm not "in" to the hybrid stuff yet. I typically drive my cars
for long time and I don't know what a new set of batteries will cost
plus I would like to see the technology mature a bit. Diesel has been
around for a long time and it is still "maturing" with the new "Blue
Tec" stuff from Mercedes and other new stuff from the other German
automakers and Honda, etc...
Nope, hybrids just don't excite me, yet. Give it a few years.
Ray
Old October 16th 07, 07:56 PM posted to rec.aviation.soaring
309
Udo
I have an '01 Odyssey, 120k miles, new tranny at 108k (thank you
Honda).
Watch out for the 01-04 years (I think). Very problematic
transmissions. Do your research before buying a used one.
www.odyclub.com
Otherwise, excellent vehicles. Tows a 1-26 on an open trailer quite
nicely - but nowhere near 75% of that dragging the trailer.
-Pete
#309
Old October 16th 07, 08:18 PM posted to rec.aviation.soaring
Ray Lovinggood
My 2000 Accord got a new (rebuilt?, remanufactured?)
transmission at 96,000 miles. Thank you, Honda.
Honda must have realized they had a bad batch of automatic
transmissions because they extended the warranty on
my Accord's tranny from 36,000 miles to 100,000 miles.
As mentioned above, it got replaced at 96,000 miles.
Now at 201,000 miles, it's still shifting as required
and not making any nasty or strange noises.
I also had a transmission oil cooler installed earlier
this year.
By the way, the car towed the trailer nicely up to
about 70 mph. However, weather (winds) and traffic
(large trucks hauling ass), could make the car/trailer
sway a little with speeds over 70 mph. Below that
speed, it seemed pretty steady to me. In calm air
and not many trucks, it was steady at 80 mph, but I
felt more comfortable at 65 to 70 mph.
I really don't like the idea of having to get rid of
it just because the damned tow hitch won't stay attached.
Sigh.
Well, my brother still has the 1968 Chrysler New Yorker
four door 'hard top' (no 'b' pillar between the doors)
and 440 cubic inch gas guzzler V8. And, it still has
a trailer hitch on it for the times many, many years
past when dad pulled the camping trailer with it.
Naaahhhhh!
Ray
(thank you
Honda).
one.
www.odyclub.com
trailer quite
trailer.
-Pete
#309
Old October 16th 07, 08:43 PM posted to rec.aviation.soaring
On Oct 16, 2:18 pm, Ray Lovinggood
this year.
Sigh.
Naaahhhhh!
Ray
(thank you
Honda).
one.
www.odyclub.com
trailer quite
trailer.
-Pete
#309- Hide quoted text -
- Show quoted text -
Ray,
Go to a "trailer hitch shop" and see if they can re-inforce the
Accord. I'm sure something can be done to beef up the hitch attach
points. I've seen this done on uni-body cars before.
Dave
Old October 16th 07, 10:24 PM posted to rec.aviation.soaring
GK[_1_]
- If you consider that GM bought the hybrid technology from Toyota
you might consider the original not some couterfits, that have a long
earned reputation of...
I tow a Minden trailer with 2005 4 cylinder Accord. Next year Honda
will bring their 2.2 turbo Diesel from Europe and having already
driven the European Diesel Accord, it will be the car to own.
Old October 17th 07, 07:59 AM posted to rec.aviation.soaring
Michael Huber
I just canīt believe there is no solution to the hitch problem. Try to find
a hitch that attaches to the structure that holds the rear bumper, not some
sheet metal of the trunk, and keep the car.
Michael
Old October 17th 07, 10:47 AM posted to rec.aviation.soaring
Ray Lovinggood
I did as you suggested, to the best that I could find
another hitch.
The first hitch attached with two bolts through the
bottom of the trunk and one bolt through the 'tie down'
loop that is centered on the car and right at the rear
of the car.
The second hitch did away with the two bolts in the
trunk sheet metal and bolted to the 'frame rails',
but it still had a connection to the 'tie down' loop.
Problem is: The 'tie down' loop, while reinforced,
is still a part of the trunk bottom sheet metal.
Also, the car is rated to tow 1,000 lb. I'm pulling
a trailer that is over 1,000 lbs, closer to 2,000 lbs.
Also, the tongue weight shouldn't be more than 100
lbs for this particular car and I measured the tongue
last weekend with bathroom scales: 170 lbs.
This particular car just isn't going to pull this particular
trailer any more. The hitch has been removed, the
trunk repaired, for the second and last time, and I'm
going to have to get another tow vehicle.
Ray
Michael
Tow Vehicle Woes rlovinggood Soaring 25 October 18th 07 10:40 PM
Saturn V Vehicle for the Apollo 4 Mission in the Vehicle Assembly Building 6754387.jpg [email protected] Aviation Photos 0 April 12th 07 01:38 AM
license woes gen Piloting 30 November 10th 06 08:03 PM
Volkslogger woes Dan Rihn Soaring 10 March 25th 04 03:10 PM
Copyright Đ2004-2025 AviationBanter.
