Airplane Pilot's As Physicists
Old October 17th 07, 02:01 AM posted to sci.physics,rec.aviation.piloting
Bertie the Bunyip[_19_]
Default Airplane Pilot's As Physicists
"Morgans" wrote in
"Bertie the Bunyip" wrote
What's it matter? Yo'll never be a pilot. Any math that wil enable
you to dial up for home delivered pizza and escargot should suffice.
Are you kidding? He doesn't have a job to provide enough money for
escargot.
The only escargot he is going to see is from the snails he plucks out
of the river!
Mmmmmm!
Nah, they're cheap enough in France.
They sell 'em on the streets for about $2 a bag. I can speak on this with
some authority, BTW, since that's where I am today and I seen some for
sale.
Bertie
  #182
Old October 17th 07, 02:03 AM posted to sci.physics,rec.aviation.piloting
Le Chaud Lapin wrote in
ups.com:
On Oct 16, 6:31 am, Thomas wrote:
On 9 Oct, 21:08, Le Chaud Lapin wrote:
You may want to check out my web
pageshttp://www.physicsmyths.org.uk/bernoulli.htm
andhttp://www.physicsmyths.org.uk/drag.htm for a closer examination
of the physics behind the aerodynamic lift and drag.
The main point I am making there is that it is physically nonsense to
claim that changing merely the tangential velocity of the air stream
relative to the surface would in any way produce a resultant force
(at least for a non-viscous gas).
What one needs for a pressure change
(and thus a force) on the surface is a change in the numbers and/or
the velocity of the molecules hitting it, i.e. it is only the
vertical component of the velocity that is relevant here. Only this
can produce the lift for an airfoil, either because of the increased
number of collisions on the lower side or the decreased number of
collisions on the upper side (both situations lead to a lift).
I agree, but there are some that seem to think the contrary, as you
know, with the Coanda effect.
http://en.wikipedia.org/wiki/Coand%C4%83_effect
What is troubling about many of these theories is that, at the precise
moment where the reader is most alert in anticipation of the meat of
the explanation, the hand-waving begins. In the link above, the clause
entitled Causes, it is written:
"The effect of a spoon apparently attracting a flow of water is caused
by this effect as well, since the flow of water entrains gases to flow
down along the stream, and these gases are then pulled, along with the
flow of water, in towards the spoon, as a result of the pressure
differential. "
Hmmm...."and these gases are then pulled"...
pulled? By what?
And it should be
obvious that for this to be the case, one must either have the lower
side of the wing facing to a certain degree into the airstream,
and/or the upper side facing to a certain degree opposite to the
airstream. This is why one either needs a certain 'angle of attack'
or a correspondingly shaped airfoil. And it should be obvious that in
order to have an asymmetric force (i.e. a higher upward than downward
force) one needs the surfaces of the airfoil to be orientated in some
way asymmetrical relatively to the airstream. So a perfectly
symmetrical airfoil (front to back) at a zero angle of attack (like I
indicated in Fig.1 on my
pagehttp://www.physicsmyths.org.uk/bernoulli.htm) should not produce
any lift as the upward force (from the rear part) is exactly equal to
the downward force (from the front part). All that would happen is
that the wing experiences an anti-clockwise torque. This is the
reason why the rear part of the wing (behind the apex) must always
have a larger surface than the front part. At least I have yet to see
an airfoil where this is not the case and where it can be used at a
zero angle of attack. (the Bernoulli principle is in direct
contradiction to this as it would also predict a lift for a perfectly
symmetric airfoil in this sense).
I just read both your web pages.
BTW, your explanation of d'Alembert's Paradox and the blow-over-paper-
attached-to-table experiment could both use diagrams. I am trying the
blow over the paper experiment now and I am not sure if I am doing it
as you described. Could you provide a more vivid description so I can
make sure?
MAybe if you took your head out of your ass first..
Bertie
  #183
Old October 17th 07, 02:28 AM posted to sci.physics,rec.aviation.piloting
Morgans[_2_]
Or bend over, and blow it up your ass.
Jim in NC
  #184
Old October 17th 07, 02:40 AM posted to sci.physics,rec.aviation.piloting
ManhattanMan
Well, damn! He did it!!!!!!!!!!!!
http://www.members.cox.net/drpics/hua2.jpg
  #185
Old October 17th 07, 04:23 AM posted to sci.physics,rec.aviation.piloting
Mxsmanic
BDS writes:
Please do. Might I suggest you try a different approach when you ask
someone for help?
Like genuflection?
  #186
Mxsmanic
Le Chaud Lapin writes:
What about my orignial post is abrasive and insulting?
You refused to submit to the alpha dog and his pack.
  #187
Old October 17th 07, 04:37 AM posted to sci.physics,rec.aviation.piloting
Mxsmanic wrote in
BDS writes:
someone for help?
Like genuflection?
Or you could just kiss my ring.
Bertie
  #188
Old October 17th 07, 04:38 AM posted to sci.physics,rec.aviation.piloting
Mxsmanic wrote in
God I love usenet.
Bertie
  #189
Old October 17th 07, 09:41 AM posted to sci.physics,rec.aviation.piloting
Thomas
On 17 Oct, 00:48, Le Chaud Lapin wrote:
On Oct 16, 3:31 pm, Thomas wrote:
On 16 Oct, 19:41, Jim Logajan wrote:
Thomas wrote:
You may want to check out my web pages
http://www.physicsmyths.org.uk/bernoulli.htmand
http://www.physicsmyths.org.uk/drag.htmfora closer examination of
You might want to actually _include_ Bernoulli's theorem somewhere in your
pages. You talk about Bernoulli's equation, Bernoulli's principle, and
Bernoulli's law. And yet none of them are actually presented. Are you
saying they all the same or all different? Why not use the terminology used
by the professionals and stick with "Bernoulli's theorem"? How about
including references to relevant texts on your pages? It's not like serious
texts and lab experiments haven't been done on the subject for a zillion
years. It helps to show you know what you're talking about by showing
you've first read the professional literature on the subject and done your
own relevant research.
You might also want to redraw your figures so they include vertical labeled
arrows. Then present the assumptions and math needed to show your work and
why you think the vertical magnitudes sum to zero. Just saying they do, or
they only yield a torque, isn't good enough. It is more useful to _show_ -
not pontificate and hand-wave.
P.S. Chapter section 40-3 in volume 2 of Feynman's Lectures on Physics is
as good a place as any to start.
Bernoulli's theorem is not a fundamental physical law and thus not
required to understand the principle behind the aerodynamic lift. And
its misinterpretation and misapplication quite evidently leads to
incorrect physical conclusions, like the claim that a moving gas would
inherently have a lower static pressure than a stationary one. The net
flow velocity of a gas has per se nothing to do with the static
pressure.
I so agree. The amout of hand-waving that goes on when (presumably
technically-inclined) individuals invoke Bernoulli is perplexing.
Oddly, my college physics book is almost as guilty - after chapters
and chapters of Newtonian mechanics that are quite clear, they seem to
imply just that.
It is not so much a case of 'hand waving' arguments, but of
insufficient and contradictory physical definitions (especially with
regard to the notion of an 'inviscid' gas). Applying some physical
equation to a situation where it can not be applied is bound to lead
to paradoxes and wrong results.
As a thought experiment, consider a large tank containing gas with a
pipe attached to it which leads into a vacuum space. Assume first this
pipe is closed at the end; then the flow velocity in the pipe is zero
because the molecules heading outwards will be reflected at the end
and reverse their velocity (assume for simplicity that the molecules
do not collide with each other but only with the walls of the pipe and
the tank). If one now opens the pipe, the only thing that changes is
that the molecules heading outwards will not be reflected anymore at
the end but simply carry on heading into the vacuum space (with the
corresponding loss of molecules being replaced from the large tank).
So we now have a net flow velocity within the pipe without that either
the density nor the speed of the molecules has changed in any way.
This means that the pressure exerted on the inside wall of the pipe is
unchanged despite the fact that we now have a net flow velocity within
it. So Bernoulli's theorem would quite evidently give a wrong result
here.
Hmmm...technically, someone could argue that, in the vicinity of the
exit hole of the tank, there would be resulting decrease in pressure,
which would be true.
As should be evident from what I said above already, for an inviscid
gas (i.e. assuming the molecules do not collide with each other but
only with the walls), it should not make any difference whatsoever if
the pipe is open or closed at the end. The rate with which the
molecules hit the inside wall (and thus the pressure on it) is exactly
the same anywhere within the pipe (assuming the lost molecules for the
open pipe situation are readily replaced from the tank).
The misapplication, I think, results from too much hand-waving and not
being very specific about what pressure decreases over what. A venturi
apparutus, for example, very clearly demonstrates a drop in pressure,
and that drop is real, but the points chosen to measure the pressure
in the apparutus is very specific.
The Venturi effect (like the paper sheet example, the Coanda effect
and the Magnus effect) is merely a result of the viscosity of the
medium. It does not occur for an ideally inviscid medium (i.e. if the
collisions of molecules amongst each other can be neglected), whereas
the aerodynamic lift does.
Thomas
  #190
Old October 17th 07, 10:53 AM posted to sci.physics,rec.aviation.piloting
BDS
"Mxsmanic" wrote in message
What, no blame for the angry young males that incessantly torment you?
BDS
Pilot's Assistant V1.6.7 released AirToob Simulators 2 July 7th 07 10:43 AM
A GA pilot's worst nightmare? Kingfish Piloting 49 February 1st 07 02:51 PM
Pilot's Political Orientation Chicken Bone Piloting 533 June 29th 04 12:47 AM
Update on pilot's condition? Stewart Kissel Soaring 11 April 13th 04 09:25 PM
Pilot's Funeral/Memorial TEW Piloting 6 March 17th 04 03:12 AM
