AOA indicator pinout
Old October 17th 07, 02:35 AM posted to rec.aviation.military,rec.aviation.homebuilt
Dan[_2_]
Default AOA indicator pinout
Les Matheson wrote:
It may read to a number 40, but that is not degrees, it is units of AOA.
Units are relatable to Angle of Attack, but not equal to angle.
IIRC F-4 optimum turn was 16 units, not 16 degrees of AOA, buffet was 23
units. Pilots don't know degrees, they fly units. Test pilots and
engineers can tell you what the unit-angle relation is, but it isn't 1:1.
Les
"Bill Daniels" bildan@comcast-dot-net wrote in message
Interesting question. This AOA indicator reads out to +40 degrees and
AFIK no general aviation airfoil stalls at more than 16 degrees. Whatcha
usin' in on?
Bill Daniels
"Dan" wrote in message
I need the pinout for ARK-10A/A24G-8 AOA indicator. Part number is
SLZ9421. Can anyone provide a source or the information?
Dan, U.S. Air Force, retired
Any idea what the conversion is? I have modified a vane AOA
transducer to use synchro. I suppose I could figure it out.
Old October 17th 07, 03:11 AM posted to rec.aviation.military,rec.aviation.homebuilt
Morgans[_2_]
"Dan" wrote
1/2 scale A-10, aluminum, Vne 350ish, range on internal fuel at 75%
approximately 400 miles, ducted fan (7,000 rpm-ish), 1 place. It started
as an mind exercise based on my headroom requirements not being available
in any homebuilt design plus A-10 being a rather neat aircraft. I'm not
going to build it because I will probably never get my medical back, but I
make sub assemblies for the fun of it. I have made two main instrument
panels for it, one IFR the other VFR. It's occupational therapy
Sounds cool!
Re think it as a two place, and find someone else that has the same dream,
or you can fly with another pilot.
Jim in NC
Old October 17th 07, 04:01 AM posted to rec.aviation.military,rec.aviation.homebuilt
Bill Daniels
1/2 scale A-10, aluminum, (snip)
Whew! Had to read that three times. I thought you said, "1/2 A scale . .
." I envisioned a Cox .049. )
Rich S.
You know it's just a matter of time before someone builds a man
capable airplane powered by a huge number of TeeDee .049 engines.
Hmm, just duct tape a bunch of them on a sailplane - mine only requires 20
pounds of thrust for level flight.
Bill Daniels
Old October 17th 07, 05:14 AM posted to rec.aviation.military,rec.aviation.homebuilt
Dan[_2_]
Sounds cool!
When I saw the two seater version of the real thing I thought about
it. Problem is I want a sliding canopy so that's out. Besides, despite
the back seat being closer to the CG the math gets complicated. In my
plan there's a hell hole on the bottom between the engines. In order to
make CG with the second seat I'd have to move the batteries aft to where
the access panel is.
Old October 17th 07, 05:15 AM posted to rec.aviation.military,rec.aviation.homebuilt
Dan[_2_]
Rich S.
Bill Daniels
Now THAT I'd like to see. You could do like the guy with the Cri Cri
did and use a pair of model jet engines.
Old October 17th 07, 05:49 AM posted to rec.aviation.homebuilt
cavelamb himself[_4_]
Dan wrote:
cavelamb himself wrote:
Dan wrote:
Morgans wrote:
"Dan" wrote
Mine reads to + 30º. I am finishing out an instrument panel for
an airplane I will never be able to afford to complete. My own design.
Hmmm, interesting.
Now that our curiosity is aroused, care to tell us more?
Planform, construction materials/methods, approximate performance
parameters, locomotion, how many places?
So many questions! ;-))
started as an mind exercise based on my headroom requirements not
being available in any homebuilt design plus A-10 being a rather neat
aircraft. I'm not going to build it because I will probably never get
my medical back, but I make sub assemblies for the fun of it. I have
made two main instrument panels for it, one IFR the other VFR. It's
I thought about building a cockpit simulator - for similar reasons.
Decided to go sailing instead.
But I certainly understand...
Richard
Sailing has its advantages not the least of which is no FAA. I haven't
been sailing in decades, maybe I should build a boat instead.
if you want to build, build.
If you want to fly, buy.
Works the same with boats.
Old October 17th 07, 05:57 AM posted to rec.aviation.homebuilt
Dan[_2_]
Dan wrote:
design.
Hmmm, interesting.
75% approximately 400 miles, ducted fan (7,000 rpm-ish), 1 place. It
neat aircraft. I'm not going to build it because I will probably
never get my medical back, but I make sub assemblies for the fun of
it. I have made two main instrument panels for it, one IFR the other
Richard
haven't been sailing in decades, maybe I should build a boat instead.
See? There you go being practical again. I have plans for 12 - 16
foot sailboats. Maybe you can buy me a 42 footer for my birthday, it's 1
November
Old October 17th 07, 06:15 AM posted to rec.aviation.homebuilt
Dan wrote:
design.
Hmmm, interesting.
It started as an mind exercise based on my headroom requirements
not being available in any homebuilt design plus A-10 being a
rather neat aircraft. I'm not going to build it because I will
probably never get my medical back, but I make sub assemblies for
the fun of it. I have made two main instrument panels for it, one
Richard
November
Get a smaller boat to start with.
They are a lot more fun and a whole lot less hassle.
(and a whole lot less expensive!)
I might offer to sell my Catalina 18 for your birthday.
But ONLY because I have a lead on a Catalina 30.
http://www.home.earthlink.net/~cavelamb/index.htm
Richard, U.S. Navy, retired
Old October 17th 07, 03:49 PM posted to rec.aviation.military,rec.aviation.homebuilt
Bill Daniels
. ." I envisioned a Cox .049. )
Rich S.
20 pounds of thrust for level flight.
Bill Daniels
Now THAT I'd like to see. You could do like the guy with the Cri Cri did
It's been done. Bob Carlton has an airshow act with a jet sailplane.
Jet sailplanes may well have a real future. Although the specific fuel
efficiency of model airplane dog whistles is terrible, (but improving)
mating them with an extremely efficient airframe seems to work really well.
Some 'back of the envelope' calcualtions show that a single RC model
microjet in the 50 Lb thrust range would push my glider along at well over
100 knots. The 75 gallon wing tanks normally used for water ballast would
provide a very nice range. If the 'dog whistle' quits, just retract it an
you still have a 50:1 glide ratio.
Bill Daniels
Bill Daniels
Old October 17th 07, 04:18 PM posted to rec.aviation.military,rec.aviation.homebuilt
Dan[_2_]
Rich S.
Bill Daniels
Bill Daniels
Bill Daniels
I hadn't realized it had been done. I wonder how altitude affects
performance of the engine.
Century Ic Pinout Grandmaster Owning 1 November 28th 06 03:18 PM
KR-21 pinout Tri-Pacer Piloting 0 September 9th 06 02:37 AM
Pinout for StormScope WX-900 epotenziani Products 0 August 22nd 05 08:32 PM
KAA 455 pinout Mike Rapoport Owning 0 February 28th 05 12:57 AM
RT-540A pinout help Billc851 Home Built 1 December 12th 04 04:27 PM
