Airplane Pilot's As Physicists
Old October 17th 07, 10:58 AM posted to sci.physics,rec.aviation.piloting
BDS
Default Airplane Pilot's As Physicists
"Mxsmanic" wrote in message
BDS writes:
Please do. Might I suggest you try a different approach when you ask
someone for help?
Like genuflection?
Funny that you and Bugs seem to be the only ones with this problem.
Maybe it's not a problem with the group...
BDS
  #192
Old October 17th 07, 11:46 AM posted to sci.physics,rec.aviation.piloting
jon
On 11 Okt, 22:49, "Androcles" wrote:
"CWatters" wrote in message
: "mike regish" wrote in message
: I think that the shape of the wing simply allows for a greater range of
: angles of attack. A sheet of plywood would providelift, but only at a
: very
: precise and small angle of attack.
: The airfoil shape allows the wing to
: provideliftthrough a much larger range of angles of attack.
: Well sort of.
: Thick wings do tend to operate over a wider range of angles than thin
wings
: but most subsonic wing sections will work from 0 to 10 degrees or more.
It's
: above 12 or 15 degrees that the section becomes more critical.
: A conventional wing section with camber can produce +veliftat zero
degrees
: AOA.
: The zeroliftangle (the angle at which noliftis produced) is actually
: negative on many conventional sections.
Ever heard ofBernoulli?
Try this demonstration:
http://www.youtube.com/watch?v=KCcZyW-6-5o
A Tomahawk cruise missile uses its wings as a control surface more
than forlift. Straight and level is useful for the computer programmer.
He thinks that way.
http://www.youtube.com/watch?v=19XXTArAGaM
All aircraft fly due to wings Angle of Attack (AOA).
All new airliners have supercritical wings and these wings have a
almost upper surface.
This web shows the vertical downwash from heavy jets, on landing at
London/Gatwick.
http://www.efluids.com/efluids/galle...plane_page.jsp
There are more of them att http://airteamimages.com/ search London/
Gatwick final
Before these pictures we only had the Cessna Citation flying over the
fog, making downwash grave.
  #193
Old October 17th 07, 12:22 PM posted to sci.physics,rec.aviation.piloting
Androcles
"jon" wrote in message
: On 11 Okt, 22:49, "Androcles" wrote:
: "CWatters" wrote in message
: : "mike regish" wrote in message
: : I think that the shape of the wing simply allows for a greater range
of
: : angles of attack. A sheet of plywood would providelift, but only at
a
: : very
: : precise and small angle of attack.
: : The airfoil shape allows the wing to
: : provideliftthrough a much larger range of angles of attack.
: : Well sort of.
: : Thick wings do tend to operate over a wider range of angles than thin
: wings
: : but most subsonic wing sections will work from 0 to 10 degrees or
more.
: It's
: : above 12 or 15 degrees that the section becomes more critical.
: : A conventional wing section with camber can produce +veliftat zero
: degrees
: : AOA.
: : The zeroliftangle (the angle at which noliftis produced) is actually
: : negative on many conventional sections.
: Ever heard ofBernoulli?
: Try this demonstration:
: http://www.youtube.com/watch?v=KCcZyW-6-5o
: A Tomahawk cruise missile uses its wings as a control surface more
: than forlift. Straight and level is useful for the computer programmer.
: He thinks that way.
: http://www.youtube.com/watch?v=19XXTArAGaM
: All aircraft fly due to wings Angle of Attack (AOA).
Tell it to a bumble bee (BB).
  #194
Old October 17th 07, 01:05 PM posted to sci.physics,rec.aviation.piloting
Bertie the Bunyip[_19_]
jon wrote in
ups.com:
: range of angles of attack. A sheet of plywood would providelift,
: but only at a
: very
: Well sort of.
: thin
wings
: more.
It's
degrees
: AOA.
: actually negative on many conventional sections.
programmer. He thinks that way.
London/Gatwick.
Gatwick final
Nope, not downwash, wake vortices,
and in fact this one nicely shows the low pressure causing fog on the
top of the wing...
http://www.efluids.com/efluids/galle...s/Morris_8.jsp
Bertie
  #195
Old October 17th 07, 01:07 PM posted to sci.physics,rec.aviation.piloting
Thomas wrote in
oups.com:
On 17 Oct, 00:48, Le Chaud Lapin wrote:
On Oct 16, 3:31 pm, Thomas wrote:
On 16 Oct, 19:41, Jim Logajan wrote:
Thomas wrote:
You may want to check out my web pages
http://www.physicsmyths.org.uk/bernoulli.htmand
http://www.physicsmyths.org.uk/drag.htmfora closer examination
of
the physics behind the aerodynamic lift and drag.
You might want to actually _include_ Bernoulli's theorem
somewhere in your pages. You talk about Bernoulli's equation,
Bernoulli's principle, and Bernoulli's law. And yet none of them
are actually presented. Are you saying they all the same or all
different? Why not use the terminology used by the professionals
and stick with "Bernoulli's theorem"? How about including
references to relevant texts on your pages? It's not like serious
texts and lab experiments haven't been done on the subject for a
zillion years. It helps to show you know what you're talking
about by showing you've first read the professional literature on
the subject and done your own relevant research.
You might also want to redraw your figures so they include
vertical labeled arrows. Then present the assumptions and math
needed to show your work and why you think the vertical
magnitudes sum to zero. Just saying they do, or they only yield a
torque, isn't good enough. It is more useful to _show_ - not
pontificate and hand-wave.
P.S. Chapter section 40-3 in volume 2 of Feynman's Lectures on
Physics is as good a place as any to start.
Bernoulli's theorem is not a fundamental physical law and thus not
required to understand the principle behind the aerodynamic lift.
And its misinterpretation and misapplication quite evidently leads
to incorrect physical conclusions, like the claim that a moving gas
would inherently have a lower static pressure than a stationary
one. The net flow velocity of a gas has per se nothing to do with
the static pressure.
I so agree. The amout of hand-waving that goes on when (presumably
technically-inclined) individuals invoke Bernoulli is perplexing.
Oddly, my college physics book is almost as guilty - after chapters
and chapters of Newtonian mechanics that are quite clear, they seem
to imply just that.
It is not so much a case of 'hand waving' arguments, but of
insufficient and contradictory physical definitions (especially with
regard to the notion of an 'inviscid' gas). Applying some physical
equation to a situation where it can not be applied is bound to lead
to paradoxes and wrong results.
As a thought experiment, consider a large tank containing gas with
a pipe attached to it which leads into a vacuum space. Assume first
this pipe is closed at the end; then the flow velocity in the pipe
is zero because the molecules heading outwards will be reflected at
the end and reverse their velocity (assume for simplicity that the
molecules do not collide with each other but only with the walls of
the pipe and the tank). If one now opens the pipe, the only thing
that changes is that the molecules heading outwards will not be
reflected anymore at the end but simply carry on heading into the
vacuum space (with the corresponding loss of molecules being
replaced from the large tank). So we now have a net flow velocity
within the pipe without that either the density nor the speed of
the molecules has changed in any way. This means that the pressure
exerted on the inside wall of the pipe is unchanged despite the
fact that we now have a net flow velocity within it. So Bernoulli's
theorem would quite evidently give a wrong result here.
Hmmm...technically, someone could argue that, in the vicinity of the
exit hole of the tank, there would be resulting decrease in pressure,
which would be true.
As should be evident from what I said above already, for an inviscid
gas (i.e. assuming the molecules do not collide with each other but
only with the walls), it should not make any difference whatsoever if
the pipe is open or closed at the end. The rate with which the
molecules hit the inside wall (and thus the pressure on it) is exactly
the same anywhere within the pipe (assuming the lost molecules for the
open pipe situation are readily replaced from the tank).
The misapplication, I think, results from too much hand-waving and
not being very specific about what pressure decreases over what. A
venturi apparutus, for example, very clearly demonstrates a drop in
pressure, and that drop is real, but the points chosen to measure the
pressure in the apparutus is very specific.
The Venturi effect (like the paper sheet example, the Coanda effect
and the Magnus effect) is merely a result of the viscosity of the
medium. It does not occur for an ideally inviscid medium (i.e. if the
collisions of molecules amongst each other can be neglected), whereas
the aerodynamic lift does.
Jesus Christ you're boring.
You want to have something done about that.
Oh yes, also, you;re wrong.
Bertie
  #196
Old October 17th 07, 02:30 PM posted to sci.physics,rec.aviation.piloting
"BDS" wrote in news:WYkRi.60257$YL5.53077
@newssvr29.news.prodigy.net:
Le Chaud Lapin writes:
What about my orignial post is abrasive and insulting?
You refused to submit to the alpha dog and his pack.
What, no blame for the angry young males that incessantly torment you?
We're such bullies. We should be so ashamed.
Bertie
  #197
Old October 17th 07, 06:21 PM posted to sci.physics,rec.aviation.piloting
Mxsmanic
BDS writes:
I simply used a synonym.
  #198
Mxsmanic
BDS writes:
Or maybe it is.
  #199
Old October 17th 07, 06:29 PM posted to sci.physics,rec.aviation.piloting
Mxsmanic
Androcles writes:
Bees are not aircraft.
  #200
Old October 17th 07, 06:40 PM posted to sci.physics,rec.aviation.piloting
Mxsmanic wrote in
Androcles writes:
Yes, they are, fjukwit.
They certainly do more flying than you do.
But then, so do pigs.
Bertie
Pilot's Assistant V1.6.7 released AirToob Simulators 2 July 7th 07 10:43 AM
A GA pilot's worst nightmare? Kingfish Piloting 49 February 1st 07 02:51 PM
Pilot's Political Orientation Chicken Bone Piloting 533 June 29th 04 12:47 AM
Update on pilot's condition? Stewart Kissel Soaring 11 April 13th 04 09:25 PM
Pilot's Funeral/Memorial TEW Piloting 6 March 17th 04 03:12 AM
