I'm always puzzled by the impact obstacles (trees, buildings, etc) have on a
crosswind. On the day ten years ago when I earned my tailwheel endorsement, there was a 15 knot direct crosswind above the treeline. But, the field was buried in a small gap between 75' trees and the crosswind effectively disappeared once the airplane descended below the trees. Even better, there was no turbulence. I'm still surprised at how easy it was to land in those conditions. As opposed to yesterday, when I was landing at a nearby field in a 10 knot, 60 degree crosswind. There was a row of 50' trees a hundred and fifty feet upwind of the runway, and those trees (presumably) created a nasty burble at groundlevel. Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB |
Kyle Boatright wrote:
I'm always puzzled by the impact obstacles (trees, buildings, etc) have on a crosswind. On the day ten years ago when I earned my tailwheel endorsement, there was a 15 knot direct crosswind above the treeline. But, the field was buried in a small gap between 75' trees and the crosswind effectively disappeared once the airplane descended below the trees. Even better, there was no turbulence. I'm still surprised at how easy it was to land in those conditions. As opposed to yesterday, when I was landing at a nearby field in a 10 knot, 60 degree crosswind. There was a row of 50' trees a hundred and fifty feet upwind of the runway, and those trees (presumably) created a nasty burble at groundlevel. Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB Hi KB; The way I've always handled this and taught others to handle it is NEVER to fly ANY approach based entirely on expected wind conditions. I know this sounds over simplistic on the face of it, but you'd be surprised how many pilots get a handle on wind somewhere between the base turn and final and get mentally nailed into that wind mindset. The result can easily be over concentration on an expected wind direction down through the approach. Then a sudden gust or wind change catches you napping. The result of that is a second or two DELAY in reaction time to the change. Usually it comes out ok, but if a pilot gets caught at exactly the wrong instant (usually down low just before the flare or entering the flare) that two second delay can suddenly become a potentially serious affair. What I like to instill in the pilots I train (in my case have trained :-) is what I call a non committal mindset for wind on the approach. Loosely explained, this simply amounts to a pilot developing a habit pattern that digests wind data as received, and begins the approach with that data in mind, but instead of thinking of wind direction, I like pilots to think wind CONTROL. By thinking aircraft control as opposed to expected wind, what happens is that you are mentally and physically a bit more "loose" on the approach because you're not expecting a specific wind correction; you are correcting for what's HAPPENING NOW all through the approach. Basically it's nothing more than a slight change in the way a pilot THINKS and FLIES the approach. You're cutting into that 2 second reaction time because now you're flying the approach as though the winds were unexpected instead of expected. You have nothing to lose and everything to gain by using this mindset. If the winds are as expected, you're automatically correcting for them. But if you get nailed, you're loose and expecting that as well!! DH -- Dudley Henriques |
"Kyle Boatright" wrote in
news ![]() I'm always puzzled by the impact obstacles (trees, buildings, etc) have on a crosswind. On the day ten years ago when I earned my tailwheel endorsement, there was a 15 knot direct crosswind above the treeline. But, the field was buried in a small gap between 75' trees and the crosswind effectively disappeared once the airplane descended below the trees. Even better, there was no turbulence. I'm still surprised at how easy it was to land in those conditions. As opposed to yesterday, when I was landing at a nearby field in a 10 knot, 60 degree crosswind. There was a row of 50' trees a hundred and fifty feet upwind of the runway, and those trees (presumably) created a nasty burble at groundlevel. Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Depends, and it's hard to predict. I know of an airport that spend tens of thousands on determining whether a new hangar would have a detrimental effect on a nearby runway threshold. Wind tunnel tests, slide ules. they built it and it's a nasty approach when the wind is coming that way. Don't think so much. Do what needs to be done as it needs to be done. Period. Bertie |
I'm always puzzled by the impact obstacles (trees, buildings, etc) have on a crosswind. On the day ten years ago when I earned my tailwheel endorsement, there was a 15 knot direct crosswind above the treeline. But, the field was buried in a small gap between 75' trees and the crosswind effectively disappeared once the airplane descended below the trees. Even better, there was no turbulence. I'm still surprised at how easy it was to land in those conditions. As opposed to yesterday, when I was landing at a nearby field in a 10 knot, 60 degree crosswind. There was a row of 50' trees a hundred and fifty feet upwind of the runway, and those trees (presumably) created a nasty burble at groundlevel. Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB When the winds are just right, the 4 windsocks at my home airport will be pointing in 4 different directions and there will be an updraft about half way down the runway. Trying to guess where the wind is blowing at any given point at any given time is an exercise in futility. The center line on the runway is there for a reason. -- Jim Pennino Remove .spam.sux to reply. |
Interesting runway environment... no trees.. but when the cross winds get
nasty here we get mechanical turbulence on final from the multi story hotel about 1/2 mile to the offset to final.. clear that and the burble goes away and just deal with the decreasing performance crosswind as you get closer to the ground. BUT !! The runway is slightly elevated above the drainage ditch between the two runways.. more of an easy swale than a ditch.. and the low level breeze can create "ridge lift" in glider pilot language.. as it comes up the swale to the runway.. low level lift right over the runway.. and you find yourself with the power back.. wing low crosswind approach and "soaring in ridge lift and climbing".. with the tire looking at the terra firma only mere inches below. The "code to be cracked"? NEVER EVER stop flying the airplane.. tail wheel or nose tragger.. until it is in the chocks and chained. I experienced the same "tree line cross wind shear" when I first learned taildraggin in a J3 more than 25yrs ago on a grassy runway just off the beach in New Hampshire. BT "Kyle Boatright" wrote in message news ![]() I'm always puzzled by the impact obstacles (trees, buildings, etc) have on a crosswind. On the day ten years ago when I earned my tailwheel endorsement, there was a 15 knot direct crosswind above the treeline. But, the field was buried in a small gap between 75' trees and the crosswind effectively disappeared once the airplane descended below the trees. Even better, there was no turbulence. I'm still surprised at how easy it was to land in those conditions. As opposed to yesterday, when I was landing at a nearby field in a 10 knot, 60 degree crosswind. There was a row of 50' trees a hundred and fifty feet upwind of the runway, and those trees (presumably) created a nasty burble at groundlevel. Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB |
![]() "Dudley Henriques" wrote in message ... You have nothing to lose and everything to gain by using this mindset. If the winds are as expected, you're automatically correcting for them. But if you get nailed, you're loose and expecting that as well!! DH -- Dudley Henriques Yes, always keep flying the plane, all the way to the hangar/tiedown. Need to always watch for those little movements and peg them before they get big... |
Blueskies wrote:
"Dudley Henriques" wrote in message ... You have nothing to lose and everything to gain by using this mindset. If the winds are as expected, you're automatically correcting for them. But if you get nailed, you're loose and expecting that as well!! DH -- Dudley Henriques Yes, always keep flying the plane, all the way to the hangar/tiedown. Need to always watch for those little movements and peg them before they get big... I've often described flying to students as simply the constant solving of little problems before they become big problems :-)) -- Dudley Henriques |
On Tue, 16 Oct 2007 23:41:18 -0400, Dudley Henriques
wrote: The way I've always handled this and taught others to handle it is NEVER to fly ANY approach based entirely on expected wind conditions. I know this sounds over simplistic on the face of it Great description of how to handle winds. Not simplistic at all, in my opinion. Furthermore, it also gets you into the mindset of going elsewhere if the winds turn out to be more than can be handled by the pilot/skillset/airplane combination. --ron |
![]() "Dudley Henriques" wrote in message ... Kyle Boatright wrote: snip Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB Hi KB; The way I've always handled this and taught others to handle it is NEVER to fly ANY approach based entirely on expected wind conditions. big snip of good stuff -- Dudley Henriques Agreed 100%, Dudley. What's your experience along the following line: This (insert lengthy experience based finding here) seems to be a workable rule of thumb for picking a good touchdown point for taking advantage or minimizing the negative impact of local obstacles to the wind. KB |
"Dudley Henriques" wrote in message ... Kyle Boatright wrote: snip Because of my widely varied experience with obstacles interacting with crosswinds, I struggle to pick the *best* runway or landing spot. Is it better to bet on an obstacle reducing the crosswind, or is that obstacle likely to cause a burble that will result in a rotten (or exciting) landing? I'm still trying to crack the code on this one... Thoughts? KB Hi KB; The way I've always handled this and taught others to handle it is NEVER to fly ANY approach based entirely on expected wind conditions. big snip of good stuff -- Dudley Henriques Agreed 100%, Dudley. What's your experience along the following line: This (insert lengthy experience based finding here) seems to be a workable rule of thumb for picking a good touchdown point for taking advantage or minimizing the negative impact of local obstacles to the wind. KB Not sure exactly what you are asking here. Can you rephrase the question sans all literary artifice perhaps? :-) -- Dudley Henriques |
Navy's 'Ring Of Steel Bomb' Flattens Obstacles | dumpster4@hotmail.com | Naval Aviation | 0 | August 28th 07 03:27 AM |
%%%%HOW TO BE FUNNY!%%%% | Expert Humor | Soaring | 0 | March 31st 06 04:13 PM |
%%%%HOW TO BE FUNNY!%%%% | Expert Humor | Owning | 0 | March 31st 06 04:12 PM |
Garmin GPS196 Update v.4 - obstacles? | jacobowitz73@yahoo.com | Piloting | 13 | March 16th 05 06:05 PM |
Funny B-2 Pic | Leadfoot | Military Aviation | 1 | October 26th 03 08:35 PM |
