Which Tow Vehicle
Old October 18th 07, 01:36 AM posted to rec.aviation.soaring
Dave Doe
Default Which Tow Vehicle
In article . com,
says...
You guys are leaving out a very important part of the equation when it
comes to stability and the ability to prevent sway. That would be
tires and the stiffness of their sidewalls. This makes a huge
difference. This can have as much of an impact as suspension.
Case in point; My brother and I at one time both had Dodge Ram trucks.
I had "E" rated tires, and he had really low rated tires (can't
remember which load designation). One of my trailers is a large 4-
place enclosed snowmobile trailer. We hitched it up to his truck to
head north for some snowmobiling and that rig was all over the place.
Glad the trailer had electric brakes because he had to apply them a
number of times to get the sway under control. Well, it wasn't very
many miles of this adventure before we turned back to switch to my
truck. When we got back from the trip, he replaced all of his tires
with a higher load range (don't remember if he went all the way to
"E") and we took a test drive with the trailer. The difference was
night and day. Problem solved!
Some of you guys with sway issues should see your tire dealer and
inquire about stiffer tires. Granted, the ride is not quite as soft,
but it's a lot safer. Even when you're not towing.
Some good points. I run LT tires (light truck) on my tandem trailer.
These have stiffer sidewalls, and are not rated for speeds over about
100km/hr I believe. Having stiffer sidewalls seems to get the tires to
the right temp when towing (warm to the touch), where "standard" tires
would undoubtably be a lot warmer.
Duncan
Saturn V Vehicle for the Apollo 4 Mission in the Vehicle Assembly Building 6754387.jpg [email protected] Aviation Photos 0 April 12th 07 01:38 AM
Lunar Roving Vehicle Installation of the Lunar Roving Vehicle in the Lunar Module.jpg [email protected] Aviation Photos 0 April 10th 07 02:47 PM
Suburban as a tow vehicle? Ken Ward Soaring 11 March 3rd 07 03:40 PM
Looking for a towable tow vehicle [email protected] Soaring 19 February 5th 05 02:14 AM
Tow vehicle for sale Sam Fly Soaring 0 February 4th 05 06:06 PM
