"Osprey may get turret-mounted machine gun"
Old October 18th 07, 04:50 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Andrew Swallow[_2_]
Default "Osprey may get turret-mounted machine gun"
BradGuth wrote:
On Oct 16, 6:51 am, Mike wrote:
[snip]
If the object is to spend the most possible in order to kill off as
many humans as possible, why not just stick with using VX dirty
cluster bombs?
- Brad Guth -
Cluster bombs are not very effective agaist flying aircraft.
Andrew Swallow
Old October 20th 07, 02:50 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Henry J Cobb
Vince wrote:
Also under consideration is a redesign of the V-22’s nose to accommodate
a chin gun, Birkholz said. “It’s all do-able,” he said. “It’s just
expensive.”
http://www.nationaldefensemagazine.o.../V-22_Aims.htm
it wasn't doable
you can hang it on the belly at the center of lift,
that is where they put the cargo hook
http://www.defenseindustrydaily.com/...ng_M777_lg.jpg
Delete the hook. Any mission that the V-22 can use the hook for the
H-53 series can do better.
For any mission that doesn't include a sling load the V-22 flies faster,
higher and further.
-HJC
Old October 20th 07, 03:15 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Vince
expensive.”
it wasn't doable
higher and further.
-HJC
no it doesn't
Carry 5 tons as far as you can and drop it off
Carry 10 tons as far as you can and drop it off
Carry the biggest payload you want 200 miles
Who wins?
Vince
Old October 21st 07, 07:19 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BradGuth
On Oct 17, 8:13 am, Dan wrote:
BradGuthwrote:
snip
There are multiple species of humans on Earth, with some way dumber
than others. Not all humans are Zion Yids, and not all smart Yids are
Third Reich. Go figure.
Brad Guth
So, how long have you been this afraid of Jews?
Hitler was actually a fairly good Jewish puppet, much like our
resident LLPOF warlord(GW Bush), and I'm still afaraid of what either
of those two incest cloned *******s have accomplished. Obviously you
and others of your semitic Third Reich kind could care less about the
past, present or future, that is as long as it's semitic dominated.
- Brad Guth -
Old October 21st 07, 07:27 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
BradGuth
On Oct 17, 8:50 pm, Andrew Swallow wrote:
[snip]
cluster bombs?
- Brad Guth -
Muslims don't have any such flying aircraft. So, what's your point?
Arnt you semitic (aka pretend atheist) folks going for the absolute
maximum of Muslim population extermination?
- Brad Guth -
Old October 21st 07, 08:14 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Dan[_2_]
[snip]
cluster bombs?
- Brad Guth -
They don't? How about Pakistan, Saudi Arabia, Egypt, Syria, Iran etc?
Dan, U.S. Air Force, retired
Old October 21st 07, 11:13 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
David E. Powell
http://www.marinecorpstimes.com/
Posted : Thursday Oct 11, 2007 15:11:37 EDT
Air Force and Marine Corps V-22 Ospreys may get a turret-mounted
machine gun, fulfilling a long-sought requirement for a forward-firing
defensive weapon and making it unique among today's U.S. transport
aircraft.
There's little agreement on when such a gun might arrive, but at least
one major defense company is spending its own money to compete for the
job.
A nose gun was considered early in the tilt-rotor's two-decade
gestation but was branded too costly, Air Force requirements officials
said.
The fiscal 2008 supplemental request includes $82 million for
research, development and testing of an "all-quadrant," or 360-degree,
defensive weapon to augment the ramp-mounted 7.62mm machine gun the
Marines use for now.
Navy program spokesman James Darcy said there is no timetable for
finding such a gun, and the search will be bound by finances and the
plodding acquisition process.
"SOCom is looking at a faster turnaround," Darcy said. "But Air Force
Special Operations Command is flying a different mission than the
Marine Corps."
The squadron of 10 Marine-owned Ospreys now in Iraq will be used
largely to transport troops, equipment and supplies. The Air Force,
which handles the tilt-rotor program for U.S. Special Operations
Command, is buying the plane for long-range special ops missions.
While the Air Force's CV-22s are not slated to hit the desert until
2009, the service's Chief of Staff Gen. T. Michael Moseley is
considering deploying his aircraft earlier.
In September, SOCom announced the search for an "interim all-quadrant
defensive weapon system" for its CV-22 tilt-rotors, with the intention
of flight-testing such a weapon within 120 days of the contract award.
"We both have a requirement for some sort of defensive weapon system,"
said Air Force Lt Col. Chet Treloar, deputy director for mobility and
special operations requirements.
But for the most part, those requirements are intentionally vague, he
said, leaving the door open for industry to be as innovative as
possible. It is not even specified whether the system should be fully
integrated into the aircraft in the future or if a drop-in solution is
the best plan.
"There are advantages and disadvantages to total, permanent
integration," said Air Force Maj. Rob Pittman of the Air Force
acquisition office. "The quick-and-dirty solution that gets the job
done might be the answer."
Pittman, Treloar and Darcy said the requirements are joint Marine-Air
Force requirements and the expectation is that everyone will get the
same weapon. But they added that nothing has been decided except the
requirements.
"There's no competition yet and there's been no selection yet," Darcy
said.
"It's possible that the solution may be different" for different
versions of the V-22, Pittman said. "But we push for as much
commonality as possible."
"I don't think we're there yet" as to what the final solution will be,
Treloar said. "But the Air Force and the Navy and the Marine Corps are
committed to keeping the troops safe. They want to deploy this
aircraft tin a way that is as safe and effective as possible."
BAE jumping the gun
Meanwhile, BAE Systems has been spending its own money to develop the
Remote Guardian System, a turreted, remote-operated, retractable
weapon that could be fielded in the third quarter of 2008 and fitted
aboard the V-22 and other aircraft, said Clark B. Freise, vice
president and general manager of defense avionics for BAE.
"We've been investing for two years and created our own program to
develop the capability," Freise said.
While Freise would not say how much BAE has spent or how much it would
charge per weapon, he did say the price would be low enough to appeal
to the Pentagon and high enough to recoup its investment.
"We spent a lot of money on it," he said. "We found a hole in their
protection, we're covering it for now, and we'll get it back. We'd
rather not say how much we've invested. We have shared with the Marine
Corps what we think it will cost to go into production, and it is
significantly lower than other solutions."
So far, the Remote Guardian has been tested only while mounted on a
Humvee, but Freise said it has fired various U.S. weapons and is
currently cleared to handle 300 knots and four times the force of
gravity. Guns can include a 7.62mm Gatling gun, a .50-caliber machine
gun and more, he said. He said it has an easily upgradeable sensor
suite.
A concern with any 360-degree system, especially a remote-firing one,
is taking a shot at your own propeller or landing gear.
According to BAE, that is not a risk with Remote Guardian.
"The gun will never, ever point at a part of the aircraft. We
integrated the safety keys into the design from the very beginning,"
Freise said.
My God! (are we good at killing innocent hummans, or what?)
- Brad Guth
People trying to kill you are not innocent. If you actually look at
things, you'll see the idea of avoiding killing civilians is a great
concern to the US, even to where more US troops get put at risk tuhan
might otherwise. Civilians are targeted by the enemy, who would also
kill you if they could.
Modern turreted guns on aircraft, with modern sighting and
stabilizers, can be directed with good precision. Hardy a cluster
bomb, or the terrorist's market place bomb or bombs like were used to
attack Benazir Bhutto's convoy in Pakistan recently. That is
indiscriminate killing, and where you should focus your attention
sometime.
  #28
Old October 21st 07, 11:16 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
David E. Powell
On Oct 16, 7:35 pm, Vince wrote:
David Lesher wrote:
Mike writes:
aircraft.
Strange no one is discussing how much such weighs; in an airframe already
short of payload...
and balance
its a side to side prop-rotor configuration
hang a thousand pounds on the chin and see what happens
There could weight to play with in the tail, or a way to
counterbalance by moving some equipment inside. They modified the
B-17 OK, but they had a lot more relative weight to play with.
Also, a turreted MG doesnt have to weaigh 1000 lbs. (Even including
ammo.)
Wonder what they will hang on there? A .50 or twin .50 could work.
7.62 minigun?
Vince-
  #29
Old October 21st 07, 11:19 AM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
David E. Powell
[snip]
cluster bombs?
- Brad Guth -
Google Mi-24 Hind, or in Iran, Cobra Gunship.
(Drivel snipped.)
  #30
Old October 21st 07, 03:06 PM posted to rec.aviation.military,rec.aviation.military.naval,sci.military.naval
Vince
David Lesher wrote:
Mike writes:
aircraft.
short of payload...
and balance
ammo.)
IIRC that was the weight of the 30 mm turret + ammo + structural
reinforcement and all control equipment
Vince
Desktop Wallpaper - "Osprey Out for a spin". T. & D. Gregor, Sr. Simulators 0 August 31st 07 02:48 PM
"Seeking Foreign Buyers For Osprey" Mike[_7_] Naval Aviation 72 July 4th 07 05:26 AM
Desktop Wallpaper - "A covey of Osprey". T. & D. Gregor, Sr. Simulators 0 June 1st 07 08:41 PM
"Marine Corps Grounds V-22 Osprey Aircraft" Mike[_1_] Naval Aviation 0 February 18th 07 03:40 PM
V-22 Osprey "ground effect" question Robert Naval Aviation 6 January 2nd 07 03:44 PM
