#41
Matt Whiting wrote in
: J.Kahn wrote: It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... What about the aluminum piston in the steel cylinder? That can happen too! But the clearances are cgrater ther than it would be in a valve stem or head to cylinder seat. Bertie |
#42
Steve Hix wrote:
In article , Matt Whiting wrote: Steve Hix wrote: In article , Matt Whiting wrote: Steve Hix wrote: So they went out one morning, got plenty of cushion between themselves and the ground, set the 172 into a landing configuration with full flaps, and slipped it. It shook a bit and then went inverted on them. They recovered and came back home. Got to love those urban legends! I was sitting at the FBO front desk when Lynn and Fred went out to see what would happen, and was there when they returned about a half hour later. They told me then what had happened, and agreed that they weren't inclined to try it again with our 172. They weren't sufficiently interested to see if it was affected one way or another by changing payload, CG location, etc. Not an urban legend, sorry if that disappoints you. I don't for a second believe that a slip with flaps turned them over. I suspect they STALLED it and went inverted, but that wasn't due to a slip with flaps. Kewl. Believe whatever floats your boat. They were both experienced CFIs, one with a good deal of A-26 and T-28 time. If they'd stalled it, I would think they'd said so. Likewise, believe all of the urban legends you want. Matt |
#43
On Fri, 19 Oct 2007 11:05:32 +0000 (UTC), Bertie the Bunyip
wrote: Matt Whiting wrote in : J.Kahn wrote: It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... What about the aluminum piston in the steel cylinder? That can happen too! But the clearances are cgrater ther than it would be in a valve stem or head to cylinder seat. If we had that kind of piston to cylinder clearance in an automotive engine we'd think it was worn out. :-)) At least in the "old days". Roger (K8RI) Bertie |
#44
"Roger (K8RI)" wrote in
: On Fri, 19 Oct 2007 11:05:32 +0000 (UTC), Bertie the Bunyip wrote: Matt Whiting wrote in : J.Kahn wrote: It's not a problem when heating because the head expands faster than the steel parts so the stress effects are reversed. This is why the manufacturers have no problem with going from idle to full power as soon as the engine will take it without stumbling. There is no such thing as shock heating... What about the aluminum piston in the steel cylinder? That can happen too! But the clearances are cgrater ther than it would be in a valve stem or head to cylinder seat. If we had that kind of piston to cylinder clearance in an automotive engine we'd think it was worn out. :-)) At least in the "old days". Yes, some air cooled engines have tapered bores (when cold) to allow for different rates of expansion in cylinder base-to-head so that it's perfectly cylindrical when up to temp, but i don't know of any aircraft engines that have that feature. Bertie |
#45
Steve Hix wrote:
Kewl. Believe whatever floats your boat. They were both experienced CFIs, one with a good deal of A-26 and T-28 time. If they'd stalled it, I would think they'd said so. Why belabor the painfully obvious? |
#46
Matt Whiting wrote: Steve Hix wrote: In article , Matt Whiting wrote: Steve Hix wrote: In article , Matt Whiting wrote: Steve Hix wrote: So they went out one morning, got plenty of cushion between themselves and the ground, set the 172 into a landing configuration with full flaps, and slipped it. It shook a bit and then went inverted on them. They recovered and came back home. Got to love those urban legends! I was sitting at the FBO front desk when Lynn and Fred went out to see what would happen, and was there when they returned about a half hour later. They told me then what had happened, and agreed that they weren't inclined to try it again with our 172. They weren't sufficiently interested to see if it was affected one way or another by changing payload, CG location, etc. Not an urban legend, sorry if that disappoints you. I don't for a second believe that a slip with flaps turned them over. On second take, agreed. I suspect they STALLED it and went inverted, but that wasn't due to a slip with flaps. Or a stall, alone. On first pass, I read it as either/or, rather than combination. Kewl. Believe whatever floats your boat. They were both experienced CFIs, one with a good deal of A-26 and T-28 time. If they'd stalled it, I would think they'd said so. Likewise, believe all of the urban legends you want. Look, it was 30+ years ago. I was barely paying attention at the time, and not knowing where either are today, I can't very well ask them for more information. Did whatever happen result solely from slipping with full flaps? I really doubt it, unless they were at some extreme weight/CG limit (both of them being average size, probably not). So yeah, they likely did something else at the time that carried things further. Stall alone? Doubt it. Slip with full flaps alone. Doubt it. I still wouldn't want to play with something against which the aircraft is placarded, not without a lot of cushion. As for urban legend, you looking at the wrong guy. Spent too much time studying physics/chemistry, and working in systems engineering for that. (And doubly skeptical of conspiracy nonsense.) And I apologize for blowing you off earlier; it's been a series of bad months at work (I avoided the layoff, not everyone else in the group did), and working 6 1/2 day weeks for 10 to 14 hrs/day for the last month hasn't helped. Mea culpa. Meanwhile, in Dec. I take off for what's going to turn out to be the better part of four weeks vacation (else I start losing what's accumulated), and after 31 years, get back into flying. I may end up being civil by then. |
#47
![]() "Bertie the Bunyip" wrote Yes, some air cooled engines have tapered bores (when cold) to allow for different rates of expansion in cylinder base-to-head so that it's perfectly cylindrical when up to temp, but i don't know of any aircraft engines that have that feature. Really? I thought that they did have a tighter bore at the top. I guess I read wrong, or remember wrong. -- Jim in NC |
#48
"Morgans" wrote in
: "Bertie the Bunyip" wrote Yes, some air cooled engines have tapered bores (when cold) to allow for different rates of expansion in cylinder base-to-head so that it's perfectly cylindrical when up to temp, but i don't know of any aircraft engines that have that feature. Really? I thought that they did have a tighter bore at the top. I guess I read wrong, or remember wrong. Maybe. I didn't know that they did. It would make sense if they did, all right. I don't do machining. I just run my fingers over the pretty parts when they come out of the machine shop! Bertie |
#49
Steve Hix wrote:
And I apologize for blowing you off earlier; it's been a series of bad months at work (I avoided the layoff, not everyone else in the group did), and working 6 1/2 day weeks for 10 to 14 hrs/day for the last month hasn't helped. Mea culpa. Meanwhile, in Dec. I take off for what's going to turn out to be the better part of four weeks vacation (else I start losing what's accumulated), and after 31 years, get back into flying. I may end up being civil by then. Steve, don't sweat it. I enjoy a good debate and rarely take offense at anything and certainly took no offense at your comments as they were quite civil. Cheers, Matt |
#50
![]() Yes, some air cooled engines have tapered bores (when cold) to allow for different rates of expansion in cylinder base-to-head so that it's perfectly cylindrical when up to temp, but i don't know of any aircraft engines that have that feature. Really? I thought that they did have a tighter bore at the top. I guess I read wrong, or remember wrong. Maybe. I didn't know that they did. It would make sense if they did, all right. I don't do machining. I just run my fingers over the pretty parts when they come out of the machine shop! This ought to be an easy question for someone in the group. Surely, there is someone that does do machining on engines that hangs out here, that would know for sure. Anyone? -- Jim in NC |
Engine out practice | Jay Honeck | Piloting | 155 | November 9th 07 03:07 AM |
Topi - Mig29 engine failure during practice - "topi.wmv" (11/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Topi - Mig29 engine failure during practice - "topi.wmv" (09/26) 6.0 MBytes yEnc | Immaterial | Aviation Photos | 0 | January 6th 07 09:15 PM |
Practice Engine-Out Landings | Jay Honeck | Piloting | 52 | July 14th 05 10:13 PM |
A PIREP: engine-out turn-back - some practice in the haze | Nathan Young | Piloting | 15 | June 17th 05 04:06 PM |
