Broken fuel selector linkage
Old October 20th 07, 10:17 PM posted to rec.aviation.owning
J McKernan
Default Broken fuel selector linkage
During the preflight of my '66 172G last night, the fuel selector linkage
broke where the upper shaft connects to the mid shaft at the knuckle. One of
the 'ears' that are riveted to the upper shaft broke completely and the
fastener that holds the other to the knuckle became unattached.
I have a couple of questions:
1. Can the 'ears' be replaced and reattached to the upper shaft and knuckle
via rivets?
2. If not, does the Cessna part 0513382-12 come with the 'ears' that can be
reattached?
3. Do I have to buy the entire shaft assembly?
Thanks,
Jake
Old October 21st 07, 04:12 PM posted to rec.aviation.owning
via rivets?
reattached?
Thanks,
Jake
Cessna will require you to purchase a "NEW" firewall rearward
replacement, ya get to keep your old engine though. G Actually,
yours is a good question and I can't wait to read the correct answer.
My gut feeling is behind door #3...
Old October 21st 07, 11:32 PM posted to rec.aviation.owning
Dave[_1_]
Door # 3.. the whole shaft as I recall...
Mine was worn out all through the uiniversals....
At least when I replaced mine in my "Pre Piper" days..
I got one from Wentworth, was almost new..
Even new it is a poor solution, wobbily and not very precise...
Dave
On Sat, 20 Oct 2007 13:17:39 -0700, "J McKernan"
via rivets?
reattached?
Thanks,
Jake
Old October 22nd 07, 03:58 AM posted to rec.aviation.owning
J McKernan
Doing some further research shows that the upper shaft is more readily
available than the entire assembly, so I am hoping that it can be repaired
(with a new upper shaft). I plan to chat with an A&P tomorrow to get some
further guidance.
Jake
"Dave" wrote in message
news
Dave
of
knuckle
via rivets?
be
reattached?
Thanks,
Jake
Old October 22nd 07, 10:29 PM posted to rec.aviation.owning
Robert M. Gary
via rivets?
reattached?
Thanks,
Jake
Dang, I hope that doesn't happen in flight. Last year I had the fuel
selector on my Mooney overhauled. There was nothing wrong with it but
I figured after 30 years in use it could use an overhaul. The thought
of not being able to get at fuel in flight is a bit distressing.
-Robert
Fuel selector question es330td Piloting 36 October 8th 07 10:05 AM
Fuel selector or two check valves? Rob Turk Home Built 13 July 1st 05 01:21 AM
Fuel Selector Valve Tom Cummings Owning 1 March 7th 04 03:44 PM
Piper nosewheel steering linkage Jeremy Lew Piloting 2 November 19th 03 04:17 PM
Fuel Selector Valve Jay Home Built 5 November 16th 03 12:16 AM
