Trac Stick
Old October 21st 07, 06:50 AM posted to rec.aviation.soaring
Default Trac Stick
So, if this could be made to be "secure" could we use it as a contest,
record, or badge logger?
I sure like the price!
http://www.googleearthstore.com/Prod...uctCode=1-TSII
MM
Old October 21st 07, 09:32 PM posted to rec.aviation.soaring
BT
Default Trac Stick
I could not tell from the information on the web page if it could record
altitude.
If it did, it would be at least good enough for OLC.
B
MM
Old October 21st 07, 11:10 PM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Default Trac Stick
The Wintec WBT-201 is smaller, has a better and more accurate GPS
receiver, can store several times as many fixes in its memory, is
capable of logging at intervals down to as little as 250 milliseconds
(the Trackstick has a minimum 5 second interval), runs for up to 15
hours on its rechargeable battery (the Trackstick uses AAA batteries),
has Bluetooth capability, also comes with Google Earth compatible
software, and costs less then $100US:
http://www.semsons.com/wiwbmu3gpsre2.html
Here's a comparison of the Trackstick to another (even cheaper)
Bluetooth GPS unit similar to the WBT-201:
http://diydrones.ning.com/profiles/b...logPost%3A4989
Marc
Old October 21st 07, 11:37 PM posted to rec.aviation.soaring
BT
Default Trac Stick
Yea.. I read it.. and then looked at the "tech data" and forgot..
thanx
"harold" wrote in message
From the Link:
"The Trackstick records its own location, time, date, speed, heading
and ALTITUDE at preset intervals." (Caps used for emphasis.)
altitude.
B
roups.com...
MM
Old October 21st 07, 11:45 PM posted to rec.aviation.soaring
harold
Default Trac Stick
From the Link:
altitude.
B
MM
Old October 21st 07, 11:52 PM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Default Trac Stick
harold wrote:
On Sun, 21 Oct 2007 22:10:25 GMT, Marc Ramsey
Sure looks like a nice unit. However, unless I missed something it
does not record altitude.
It does record altitude (and speed) when configured to do so, the
description is not quite correct...
Marc
Old October 22nd 07, 12:48 AM posted to rec.aviation.soaring
harold
Default Trac Stick
Marc
Old October 22nd 07, 12:56 AM posted to rec.aviation.soaring
ContestID67
Default Trac Stick
It is always wise to review past rec.aviation.soaring articles as this
item was discussed earlier. The reviews of the Trackstick (one word,
not two) were not very good to say the least.
http://groups.google.com/group/rec.a...d84e0fa f964f
Old October 22nd 07, 01:23 AM posted to rec.aviation.soaring
harold
Default Trac Stick
On Sun, 21 Oct 2007 15:52:54 -0700, Marc Ramsey
Marc
Thanks for the info! This is worth taking a closer look at.
Big Stick R. J. \(Bob\) Van Horn Piloting 5 September 4th 07 06:54 PM
Convince me to stick with it . . . Gary G Piloting 22 December 8th 05 03:45 PM
Stick on Bi-focals MC Soaring 0 December 6th 04 03:24 AM
Joy stick or wheel? Wally Samuelson Simulators 9 November 5th 03 12:27 AM
The F-16 control stick? Christopher Military Aviation 13 September 22nd 03 10:18 AM
