Airplane Pilot's As Physicists
Old October 26th 07, 11:28 PM posted to sci.physics,rec.aviation.piloting,alt.usenet.kooks
Bertie the Bunyip[_19_]
Default Airplane Pilot's As Physicists
jon wrote in
ups.com:
On 26 Okt, 08:24, Bertie the Bunyip wrote:
jon wrote
innews:1193336318.130848.213230@i13g2000pr
f.googlegroups.com:
On 17 Okt, 01:48, Le Chaud Lapin wrote:
On Oct 16, 3:31 pm, Thomas wrote:
On 16 Oct, 19:41, Jim Logajan wrote:
Thomas wrote:
You may want to check out my web pages
http://www.physicsmyths.org.uk/bernoulli.htmand
http://www.physicsmyths.org.uk/drag.htmforacloser examination
of
the physics behind the aerodynamicliftand drag.
You might want to actually _include_Bernoulli'stheorem
somewhere in y
our
pages. You talk aboutBernoulli'sequation,Bernoulli'sprinciple,
and
Bernoulli'slaw. And yet none of them are actually presented.
Are you
saying they all the same or all different? Why not use the
terminolog
y used
by the professionals and stick with "Bernoulli'stheorem"? How
about including references to relevant texts on your pages?
It's not like s
erious
texts and lab experiments haven't been done on the subject for
a zill
ion
years. It helps to show you know what you're talking about by
showing you've first read the professional literature on the
subject and done
your
own relevant research.
You might also want to redraw your figures so they include
vertical l
abeled
arrows. Then present the assumptions and math needed to show
your wor
k and
why you think the vertical magnitudes sum to zero. Just saying
they d
o, or
they only yield a torque, isn't good enough. It is more useful
to _sh
ow_ -
not pontificate and hand-wave.
P.S. Chapter section 40-3 in volume 2 of Feynman's Lectures on
Physic
s is
as good a place as any to start.
Bernoulli'stheorem is not a fundamental physical law and thus not
required to understand the principle behind the aerodynamiclift.
And its misinterpretation and misapplication quite evidently
leads to incorrect physical conclusions, like the claim that a
moving gas would inherently have a lower static pressure than a
stationary one. The net flow velocity of a gas has per se
nothing to do with the static pressure.
I so agree. The amout of hand-waving that goes on when
(presumably technically-inclined) individuals invokeBernoulliis
perplexing. Oddly, my college physics book is almost as guilty -
after chapters and chapters of Newtonian mechanics that are quite
clear, they seem to imply just that.
As a thought experiment, consider a large tank containing gas
with a pipe attached to it which leads into a vacuum space.
Assume first this pipe is closed at the end; then the flow
velocity in the pipe is zero because the molecules heading
outwards will be reflected at the end and reverse their velocity
(assume for simplicity that the molecules do not collide with
each other but only with the walls of the pipe and the tank). If
one now opens the pipe, the only thing that changes is that the
molecules heading outwards will not be reflected anymore at the
end but simply carry on heading into the vacuum space (with the
corresponding loss of molecules being replaced from the large
tank). So we now have a net flow velocity within the pipe
without that either the density nor the speed of the molecules
has changed in any way. This means that the pressure exerted on
the inside wall of the pipe is unchanged despite the fact that
we now have a net flow velocity within it. SoBernoulli'stheorem
would quite evidently give a wrong result here.
Hmmm...technically, someone could argue that, in the vicinity of
the exit hole of the tank, there would be resulting decrease in
pressure, which would be true.
The misapplication, I think, results from too much hand-waving and
not being very specific about what pressure decreases over what. A
venturi apparutus, for example, very clearly demonstrates a drop
in pressure, and that drop is real, but the points chosen to
measure the pressure in the apparutus is very specific.
-Le Chaud Lapin-- Dölj citerad text -
- Visa citerad text -- Dölj citerad text -
The venturi pipe is mostly misunderstood. To get through the
narrow section, the fluid must be pressed against the convergent
part with a higher pressure. The Coanda effect forces the fluid to
follow the walls in the divergent part.
All early speed sensors in 1920 used only the divergent part of the
venturi pipe.
Look att Bleriot and other planes. Look at Piper Colt 1953 model
with its backpart venturi. The front convergent part was not
needed.
Piper Colt 1953 model?
Unh unh. First flew in 1960 you fjukkwit.
Backpart Venturi?
Bwawhahwhahwhahwhahwhahwha!
Changing the airflow direction over and under the wing, creates the
local pressure gradients + or - .
Nope.
Bertie
You must be very stupid Bertie, when don´t even know when Piper Colt
was introduced:
Piper PA-22 Tri-Pacer
Nope, that's a Tripacer, different airplane, fjukkwit.
The Pacer was originally designed as a tailwheel aircraft and thus had
somewhat limited forward visibility on the ground and more demanding
ground-handling characteristics. To help introduce more pilots to
easier, safer flying, in 1953 the PA-20 was redesigned and offered as
the PA-22 Tri-Pacer with a nosewheel in place of the tailwheel landing
gear. Additionally, the Tri-Pacer offered higher-powered engine
options in the form of 150 hp (112 kW) and 160 HP (120 kW) engines,
whereas the largest engine available to the original Pacer had an
output of 135 hp (100 kW).[1] At the time the tricycle undercarriage
became a popular preference and 1953 saw the PA-22 Tri-Pacer outsell
the Pacer by a ratio of six to one.
btw, I';ve flown the pacer, Tr-pacer and colt Fjukkwit.
The colt has an O-235, not an O-290 or O-320, so you're tlaking out your
ass, just like when you talk aerodynamics.
Haven;'t heard you 'splain th efog on the top wing in that foto yet,
either fjukkwit.
Man you're dumb.
Bertie
P.S., do tell th eboys and gurls what you do for a living.
It's jus plain scary.
  #212
Old October 27th 07, 03:44 PM posted to sci.physics,rec.aviation.piloting
jon
jon wrote groups.com:
of
You might want to actually _include_Bernoulli'stheorem somewhere
in y
our
and
Bernoulli'slaw. And yet none of them are actually presented. Are
you
terminolog
y used
about including references to relevant texts on your pages? It's
not like s
erious
texts and lab experiments haven't been done on the subject for a
zill
ion
subject and done
your
vertical l
abeled
arrows. Then present the assumptions and math needed to show your
wor
k and
they d
o, or
they only yield a torque, isn't good enough. It is more useful to
_sh
ow_ -
Physic
s is
And its misinterpretation and misapplication quite evidently leads
to incorrect physical conclusions, like the claim that a moving gas
would inherently have a lower static pressure than a stationary
one. The net flow velocity of a gas has per se nothing to do with
I so agree. The amout of hand-waving that goes on when (presumably
technically-inclined) individuals invokeBernoulliis perplexing.
Oddly, my college physics book is almost as guilty - after chapters
and chapters of Newtonian mechanics that are quite clear, they seem
to imply just that.
As a thought experiment, consider a large tank containing gas with
a pipe attached to it which leads into a vacuum space. Assume first
this pipe is closed at the end; then the flow velocity in the pipe
is zero because the molecules heading outwards will be reflected at
the end and reverse their velocity (assume for simplicity that the
molecules do not collide with each other but only with the walls of
the pipe and the tank). If one now opens the pipe, the only thing
that changes is that the molecules heading outwards will not be
reflected anymore at the end but simply carry on heading into the
vacuum space (with the corresponding loss of molecules being
replaced from the large tank). So we now have a net flow velocity
within the pipe without that either the density nor the speed of
the molecules has changed in any way. This means that the pressure
exerted on the inside wall of the pipe is unchanged despite the
fact that we now have a net flow velocity within it.
SoBernoulli'stheorem would quite evidently give a wrong result
here.
Hmmm...technically, someone could argue that, in the vicinity of the
exit hole of the tank, there would be resulting decrease in pressure,
venturi apparutus, for example, very clearly demonstrates a drop in
pressure, and that drop is real, but the points chosen to measure the
The venturi pipe is mostly misunderstood. To get through the narrow
section, the fluid must be pressed against the convergent part with a
higher pressure. The Coanda effect forces the fluid to follow the
venturi pipe.
Look att Bleriot and other planes. Look at Piper Colt 1953 model with
its backpart venturi. The front convergent part was not needed.
Backpart Venturi?
Nope.
Bertie
The backpart of a venturi is sitting also on the Piper Colt 1960-64
models, like it does on the 1953 TriPacer of the same family.
One does not need the convergent entrance part, to measure the
airspeed.
  #213
Old October 27th 07, 05:10 PM posted to sci.physics,rec.aviation.piloting
jon wrote in
oups.com:
f.googlegroups.com:
of
somewhere in y
our
and
Are you
terminolog
y used
It's not like s
erious
a zill
ion
subject and done
your
vertical l
abeled
your wor
k and
they d
o, or
to _sh
ow_ -
Physic
s is
venturi pipe.
needed.
Backpart Venturi?
Nope.
Bertie
They didn't make the colt from 60-64, fjukkwit.
airspeed.
One doesn't need a venturi to measure airspeed either, fjukkktard.
OH, BTW, we met real life once. the other pilots in the room nearly
****ed their pants laughing about you in the bar afterwards.
Why don't you tell he bois and gurls here what you do for a living?
Bertie
  #214
Old October 27th 07, 05:11 PM posted to sci.physics,rec.aviation.piloting
jon wrote in
oups.com:
f.googlegroups.com:
airspeed.
Oh, almost forgot.
Bwawhahwhawhahwhahwhahwhahwhhahwhahwhahwhahhwhahwh ahwhahwhhahwhahwhahwhahwh
ha!
God I love usenet.
Bertie
  #215
Old October 28th 07, 04:39 AM posted to sci.physics,rec.aviation.piloting
Dave[_5_]
If you will be satisfied with empirical evidence, stick your hand out
the window of the car while going 50-60 MPH. Experiment with different
angles of attack. You will no doubt experience lift when your hand has
a positive angle of attack. Poor man's wind tunnel - but illustrates
that just about anything relatively flat will fly
given enough speed and a positive angle of attack.
David Johnson
  #216
Old October 28th 07, 09:24 AM posted to sci.physics,rec.aviation.piloting
jon
f.googlegroups.com:
http://www.physicsmyths.org.uk/drag....serexamination
of
somewhere in y
our
and
Are you
terminolog
y used
It's not like s
erious
a zill
ion
subject and done
your
vertical l
abeled
your wor
k and
they d
o, or
to _sh
ow_ -
Physic
s is
venturi pipe.
needed.
Backpart Venturi?
Nope.
Bertie
airspeed.
Bertie- Dölj citerad text -
Since you are such a superexpert Bertie, Bombardier needs your help to
fix the landinggear problem!
Now 9 incidents happened with failed landinggear!
We can not block more runways with Q400 anymore and we need your help
Bertie, since you know everything in the
aviation world.
And you still believe the aircrafts are sucked up in the sky, like
Apollo went to the moon?
  #217
Old October 28th 07, 11:29 AM posted to sci.physics,rec.aviation.piloting
jon
angles of attack. You will no doubt experienceliftwhen your hand has
David Johnson
The problem is probably, that Bertie does have a car, so the simple
experiment is not possible for him.
He might find a bus, where he can open the window and try.
The risk is that he does not understand the physical effects on his
hand.
Since he does not understand how to see the vertical airflow from the
wings at AOA in this picture, he has a big problem:
http://www.efluids.com/efluids/galle...s/Morris_4.jsp
  #218
Old October 28th 07, 12:20 PM posted to sci.physics,rec.aviation.piloting
jon wrote in news:1193570966.513645.238920
@o38g2000hse.googlegroups.com:
different
David Johnson
Yep, I do have a car. an airplane too.
hand.
http://www.efluids.com/efluids/galle...s/Morris_3.jsp
Look again, fjukkwit.
You have yet to explain th elow on top of the wing..
Bertie
  #219
Old October 28th 07, 12:21 PM posted to sci.physics,rec.aviation.piloting
jon wrote in
ups.com:
jon wrote
innews:1193496270.442636.260090@d55g2000hs
g.googlegroups.com:
f.googlegroups.com:
http://www.physicsmyths.org.uk/drag....oserexaminatio
n of
somewhere in y
our
pages. You talk
and
Are you
terminolog
y used
How about including references to relevant texts on your
pages? It's not like s
erious
for a zill
ion
by showing you've first read the professional literature on
the subject and done
your
vertical l
abeled
show your wor
k and
saying they d
o, or
useful to _sh
ow_ -
on Physic
s is
not
aerodynamiclift. And its misinterpretation and misapplication
quite evidently leads to incorrect physical conclusions, like
the claim that a moving gas would inherently have a lower
static pressure than a stationary one. The net flow velocity
of a gas has per se nothing to do with the static pressure.
- after chapters and chapters of Newtonian mechanics that are
quite clear, they seem to imply just that.
velocity (assume for simplicity that the molecules do not
collide with each other but only with the walls of the pipe
and the tank). If one now opens the pipe, the only thing that
the vacuum space (with the corresponding loss of molecules
being replaced from the large tank). So we now have a net
flow velocity within the pipe without that either the density
nor the speed of the molecules has changed in any way. This
means that the pressure exerted on the inside wall of the
pipe is unchanged despite the fact that we now have a net
flow velocity within it. SoBernoulli'stheorem would quite
of the exit hole of the tank, there would be resulting decrease
in pressure, which would be true.
and not being very specific about what pressure decreases over
what. A venturi apparutus, for example, very clearly
demonstrates a drop in pressure, and that drop is real, but the
points chosen to measure the pressure in the apparutus is very
specific.
to follow the walls in the divergent part.
the venturi pipe.
needed.
Backpart Venturi?
the local pressure gradients + or - .
Nope.
Bertie
airspeed.
So?
aviation world.
Well, they need to make the gear stronger and more reliable.
happy?
God I love usenet.
Bertie
  #220
Old October 29th 07, 03:05 PM posted to sci.physics,rec.aviation.piloting
Gatt
"Dave" wrote in message
That's why wings have camber. 'Cause they don't need 'em.
Bertie's a shill for the Alcoa Camber Conspiracy. ...they've sold more
metal by convincing every successful aircraft designer and manufacturer in
the history of aviation that upper camber is necessary, when all they need
are two simple deflection plates.
Fortunately, the wizards at sci.physics have busted the conspiracy and we
all see now how the designers of all aircraft were grievously wrong.
-c
Pilot's Assistant V1.6.7 released AirToob Simulators 2 July 7th 07 10:43 AM
A GA pilot's worst nightmare? Kingfish Piloting 49 February 1st 07 02:51 PM
Pilot's Political Orientation Chicken Bone Piloting 533 June 29th 04 12:47 AM
Update on pilot's condition? Stewart Kissel Soaring 11 April 13th 04 09:25 PM
Pilot's Funeral/Memorial TEW Piloting 6 March 17th 04 03:12 AM
