#31
On 28 Oct, 05:51, Marc Ramsey wrote:
wrote: Position and velocity vector is not sufficient information for a smart collision alert, What more information are you using besides position, pressure altitude, and GPS-derived velocity vector to calculate a trajectory prediction? If adequate information and processing power is available, than it should not matter in the least whether the prediction is made by the transmitter or receiver... If his system is using aircraft performance as well, then for the trajectory to be calculated by the receiver would either requi 1) aircraft type to be transmitted, and the receiver to have a database of all possible performance parameters or 2) performance parameters to be transmitted with the other data Both these have obvious (I think) disadvantages - it makes sense to me to have th etransmitting aircraft say where it thinks it's going. Ian |
#32
On Oct 27, 11:40 pm, Ian wrote:
On 26 Oct, 18:18, Ramy wrote: On Oct 26, 9:07 am, Ian wrote: SNIP Anyway, my human eyes have successfully detected /all/ threats in time to avoid them so far. How common are midair glider collisions? Ian How do you know what you have detected *all* threats in time. What margin of safety is that down to? How do you know other aircraft (and/ or ATC) did not take action to avoid you and you were never aware of them? I personally do not use logic like "my past landing attempt did not kill me so my landings are great" but I look at what you are saying as "I've not run into anything sofar therefore my visual lookouts are perfectly adequate" - it is not a high threshold for fidelity in this discussion, especially when you appreciate how much the big sky is actually part of being responsible for you still being alive. Do you routinely do clearing turns while cruising along to clear all those large blind spots we have? How clear of clouds do you really stay? How do you see fast traffic about to come out the cloud? Have you ever seen how really hard it is to see a white glider closing at over 100 knots head on against snow laden white mountainous background? Go fly in an aircraft with a TCAS or PCAS or similar and see how much general traffic you don't spot until the system warns you to really look or (carefully) turn the aircraft so you can see traffic. Flying with a PCAS in my gliders has warned me a few times to start looking intensely for traffic (much more than you would be able to do continuously as a part of standard traffic scanning). The few closest ones have been power traffic, in uncontrolled but high density traffic areas some close and very oblivious to my glider being there at all. From what I've seen the adoption of PCAS units like the Zaon MRX are very viral. Lots of non believers until one or two glider pilots start using them and then start reporting they really work, especially all the traffic they otherwise would not notice... Oh yes I've deliberately not stuck to Flarm, and I think Flarm would be a very bad move for the USA. We need gliders in high traffic areas with Transponders and PCAS today and ADS-B in future. Too many of us fly in very high traffic areas, we need to be visible to and communicating with power traffic and ATC as well as worrying about glider-glider conflicts. Politically I am much more worried about a glider taking out a passenger jet than I am about glider-glider collisions. The last person who wanted to argue with me strongly that mid-air collisions do not happen was flying with me in a Duo Discus near Minden when not far away the ASG-29 met with a Hawker. Hell of a way to win an argument. Darryl |
#33
Is there any chance that you could adapt your FLARM system to conform to the
ADS-B specs in the US so that it would fit into the overall US airspace strategy? That would make your device very interesting, not only to the glider community, but also to the power aircraft market. Mike Schumann wrote in message ups.com... We should be able to attend the SSA convention in February. If you wish we can make a presentation about FLARM. We have no reservation whatsoever to sell FLARM in the US, legal questions can be solved, but we would like to get positive feedback from the US soaring community before doing so. Some comments about the recent r.a.s. posts: The frequency in all FLARM units can be set by software, therefore all units work worldwide. The transceiver is designed to meet FCC rules, but we have not yet fully verified this. It transmits at less than 1% duty cycle and (currently) 10mW. "Nuisance alarms" versus "real alarms" will always be a hot topic for any collision warning device in soaring. 1) We can and will further reduce "nuisance alarms" based on pilot feedback and our own continuing research. 2) If the pilot "behaves well" in a gaggle he is much less likely to suffer from "nuisance alarms" as the predicted trajectory will not cross someone else's. 3) One of the unique features of FLARM is that each aircraft performs and transmits its own trajectory prediction based on aircraft type, flight path history and other parameters. This results in superior system performance, especially in high density or heterogeneous traffic environments. It also safes a lot of processing power as each unit only needs to do one sophisticated prediction and then just compares all received trajectories to it. Position and velocity vector is not sufficient information for a smart collision alert, and don't get me started on the cheap "transponder sniffer" devices... ;-) Urs --- FLARM -- Posted via a free Usenet account from http://www.teranews.com |
#34
On 28 Oct, 07:18, "
wrote: On Oct 27, 11:40 pm, Ian wrote: On 26 Oct, 18:18, Ramy wrote: On Oct 26, 9:07 am, Ian wrote: SNIP Anyway, my human eyes have successfully detected /all/ threats in time to avoid them so far. How common are midair glider collisions? How do you know what you have detected *all* threats in time. Because nobody has ever hit me. Therefore I and/or the other pilots have /always/ managed to detect and deal with threats successfully. What margin of safety is that down to? Can you define "margin of safety" in this case, please? How do you know other aircraft (and/ or ATC) did not take action to avoid you and you were never aware of them? It doesn't really matter to me whether I successfully avoided them or they successfully avoided me (that will almost certainly have happened a lot, as I fly wood) - but I can say that "looking out" has always worked for me. That's not to get complacent, of course, but I would feel a lot happier if I knew that other pilots were not, to some inevitable extent, relying on a magic gadget to lookout for them. I personally do not use logic like "my past landing attempt did not kill me so my landings are great" but I look at what you are saying as "I've not run into anything sofar therefore my visual lookouts are perfectly adequate" How about "unless you buy a radio altimeter you will never be able to plan an outlanding properly?" Lots of non believers until one or two glider pilots start using them and then start reporting they really work, especially all the traffic they otherwise would not notice... This is where I am sceptical. Yes, I am sure these things will give lots of extra alerts - they'd hardly be worth buying if they didn't. But we are not exactly plagued, world wide, by glider-glider collisions, are we? So what this means is that pilots will spend a lot more time reacting to false alarms (they must be false, because if they weren't they'd end in a collision without the magic gadgets). Do pilots have time available to do that? What are they not going to do instead? I can see a far stronger argument for using these things in areas where other aircraft will not be looking out - Class A airspace, say, or cloud flying, or scud running. But for normal flying ... colour me unconvinced. That's only unconvinced yet, though. I'm not a complete luddite. GPS sets are great - they may distract pilots' attention from more important stuff, but not nearly as much as maps do. If flarm and the like lead to a statistically significant reduction in the number of midair collisions I'll be all for 'em. Ian |
#35
Hi,
So what this means is that pilots will spend a lot more time reacting to false alarms (they must be false, because if they weren't they'd end in a collision without the magic gadgets). I have been flying FLARM-equipped aircraft from my first introductory flight. My reaction to a FLARM-alarm is simple: Check the direction (a quick glance at the display mounted on the top of the glare shield) and map the target to what I know is out there. In many more cases than I'd like to admit I find an aircraft on a conflicting course that I simply had not seen before. I MIGHT have found it myself once it got closer or manoevered, most propably still in time to avoid a collision (If I did not believe that, I would not be flying at all) but FLARM notified me earlier and so I reactions typically are more relaxed. I do not consider FLARM firing in that situation a false alarm, it is exactly what the gadget is intended for. I also do not mind alarms when thermalling. When sharing a thermal with well-matched aircraft and well-behaved pilots FLARM generally stays quiet. If there is a repeated alarm from my six I tend to leave as this means someone is flying behind me in a way that bothers the device and that in turn bothers me. Never mind wether the threat is real or not. The same is true in other alarm-situations. I have never had to mute the thing because of an annoying repeated alarm from some target I knew about. I simply avoid them by a wide enough margin. Not just to silence the alarm, it feels like the right thing to do anyway and the FLARM-software seems to think the same and shuts up. There is no fiddling with FLARM as with other gadgets. It turns on when the battery is connected and that's it. Sure you can toggle different modes, mute it etc.. I never do. And if you do there just the single button to press. The only thing I really don't like about it is when I'm down on the ground and stopped and get a shrieking "impending death"-alarm because someone else comes in over to land further down the field :-). Yes, if there were to be a collision in that situation I might get out and dive for cover or something :-), but still that is the one thing I would change about the softwa Do not go off after the aircraft has come to a complete stop. If flarm and the like lead to a statistically significant reduction in the number of midair collisions I'll be all for 'em. I firmly believe it does. I would prefer a solution that would also target power traffic both commercial and recreational more than FLARM does (our tow-plane has one of course :-)), but that does not mean I am not going to use what's there. I have not ever felt distracted by FLARM and think if there is any influence on my lookout then it actually improves it. Ciao, MM -- Marian Aldenhövel, Rosenhain 23, 53123 Bonn http://www.marian-aldenhoevel.de "Success is the happy feeling you get between the time you do something and the time you tell a woman what you did." |
#36
![]() Ian wrote: On 28 Oct, 07:18, " wrote: On Oct 27, 11:40 pm, Ian wrote: On 26 Oct, 18:18, Ramy wrote: On Oct 26, 9:07 am, Ian wrote: SNIP Anyway, my human eyes have successfully detected /all/ threats in time to avoid them so far. How common are midair glider collisions? How do you know what you have detected *all* threats in time. Because nobody has ever hit me. Therefore I and/or the other pilots have /always/ managed to detect and deal with threats successfully. What margin of safety is that down to? Can you define "margin of safety" in this case, please? How do you know other aircraft (and/ or ATC) did not take action to avoid you and you were never aware of them? It doesn't really matter to me whether I successfully avoided them or they successfully avoided me (that will almost certainly have happened a lot, as I fly wood) - but I can say that "looking out" has always worked for me. That's not to get complacent, of course, but I would feel a lot happier if I knew that other pilots were not, to some inevitable extent, relying on a magic gadget to lookout for them. I personally do not use logic like "my past landing attempt did not kill me so my landings are great" but I look at what you are saying as "I've not run into anything sofar therefore my visual lookouts are perfectly adequate" How about "unless you buy a radio altimeter you will never be able to plan an outlanding properly?" Lots of non believers until one or two glider pilots start using them and then start reporting they really work, especially all the traffic they otherwise would not notice... This is where I am sceptical. Yes, I am sure these things will give lots of extra alerts - they'd hardly be worth buying if they didn't. But we are not exactly plagued, world wide, by glider-glider collisions, are we? So what this means is that pilots will spend a lot more time reacting to false alarms (they must be false, because if they weren't they'd end in a collision without the magic gadgets). Don't let the fact that you have not had or realised that you have had a near miss to date blind you to the risks. Even when everyone is being careful things can, and do, go wrong. It is generally not the aircraft we saw that represent the highest risk we have encountered. It is the ones we failed to observe. In at least one situation I avoided a collision more by luck than judgement. Regional contest - lots (20)of different performance gliders in the same thermal. Me being the novice slowly getting the last out of the top of the thermal - waiting for the gate to open. Fortunately someone on the other side of the thermal saw an ASW20 flying perfectly synchronised, directly below me getting way too close. The ASW20 pilot did not see me around the brim of his hat. I could not see him, even after the call. ('xxx' above you!) When he saw what he was doing he dived away and left the thermal. I only realised it was me they were talking about later - When we looked at the traces afterwards it was less than 5m vertical separation... If we had Flarm we would not have been in the situation of not knowing about each other. Do pilots have time available to do that? What are they not going to do instead? I can see a far stronger argument for using these things in areas where other aircraft will not be looking out - Class A airspace, say, or cloud flying, or scud running. But for normal flying ... colour me unconvinced. That's only unconvinced yet, though. I'm not a complete luddite. GPS sets are great - they may distract pilots' attention from more important stuff, but not nearly as much as maps do. If flarm and the like lead to a statistically significant reduction in the number of midair collisions I'll be all for 'em. Ian Flarm is a tool - like all tools it is only as useful as the person using it makes it. I have met at least one pilot who's over dependence on it makes him dangerous - Most reasonable people will use it for what it is designed to be. An aid to optimising their lookout. It is becoming steadily more common in South African gliders and for that reason is becoming worth having. |
#37
Ian wrote:
On 26 Oct, 18:18, Ramy wrote: On Oct 26, 9:07 am, Ian wrote: SNIP [1] and have no intention of doing so: I'm profoundly sceptical about a further increase in the number of things to fiddle with and focus on inside the glider. Why not just look out? Because your human eyes can't detect most threats on time to avoid it, especially gliders and especially if they are comming from behind or the side. The pilots of these gliders should be able to see me - if they are not busy concentrating on yet another electronic gadget in the cockpit. You haven't flown with a FLARM, yet you keep saying this. Why do you think they are "concentrating" on FLARM? From what I've read about it, and from what users say, there is no "concentrating": you go about your flying until it alerts you. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#38
There are ca 9 000 FLARM units in use in Europe, and all who use them
seems to be in favour of it. There seems to be no FLARMs in the US, but a lot of people who is against it. When I bought my ASW 28-18E last winter it was already equipped with a FLARM. I used to be against FLARM for all the reasons listed in this thread, now that I have flown with it I am in favour of it. Robert Danewid ASW 28-18E RD |
#39
Ian wrote:
On 27 Oct, 17:08, pascal wrote: It's always a shock when you pass a glider coming from the front without having the warning (because it is not equipped with flarm); and despite looking out you surprise yourself not having noticed that particular glider. I wonder how well you look (ie one looks) out when a little part of the brain assumes that flarm would have reacted to anything that mattered? There is always the problem of adverse compensation when a safety device is introduced. Monitoring of the situation should continue after the introduction to ensure the desired increase in safety occurrs. I believe this is the case with FLARM. What puzzles me is how skeptical you are about a widely accepted device you have not used. FLARM has sold 9000 units. 9000! When 9000 pilots voluntarily equip their aircraft with an $800 device, I am inclined to think there may be something quite useful there and to look forward to an opportunity to use one. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#40
Ian wrote:
On 28 Oct, 05:51, Marc Ramsey wrote: wrote: Position and velocity vector is not sufficient information for a smart collision alert, What more information are you using besides position, pressure altitude, and GPS-derived velocity vector to calculate a trajectory prediction? If adequate information and processing power is available, than it should not matter in the least whether the prediction is made by the transmitter or receiver... If his system is using aircraft performance as well, then for the trajectory to be calculated by the receiver would either requi 1) aircraft type to be transmitted, and the receiver to have a database of all possible performance parameters or 2) performance parameters to be transmitted with the other data Both these have obvious (I think) disadvantages - it makes sense to me to have th etransmitting aircraft say where it thinks it's going. I can't see the need to transmit anything more than the aircraft category and 3D velocity vector (which are both transmitted in the ADS-B message), as what matters is what the aircraft is likely to be doing in the next few seconds, not what it could do given a longer period of time. Marc |
General Janis Karpinski/Karen Kwiatkowski discuss war for Israel in Iraq and beyond... | [email protected] | Naval Aviation | 0 | April 23rd 06 11:44 AM |
FLARM | Robert Hart | Soaring | 50 | March 16th 06 11:20 PM |
Flarm | Mal | Soaring | 4 | October 19th 05 08:44 AM |
FLARM | John Galloway | Soaring | 9 | November 27th 04 07:16 AM |
Roadable aircraft group please join and discuss with us in our forum | Strafi | Home Built | 0 | October 22nd 03 01:37 AM |
