CNN article on problems in Air Travel, as seen by FAA
Old October 30th 07, 01:57 AM posted to rec.aviation.piloting,rec.travel.air
JerryLewis
Default CNN article on problems in Air Travel, as seen by FAA
John Kulp wrote:
On Mon, 29 Oct 2007 20:21:51 -0400, "Morgans"
"John Kulp" wrote
Gates can be a problem sometime but not runways. The GPS system would
handle about 25% more flights on the same runways. Aren't you paying
enough all ready for flights? Want to pay more when the politicos are
stealing what money is already being paid for?
So you are saying, at peak rush times, there is 25% extra time for
separation to be maintained?
Jim in NC
GPS allows for closer spacing and straighter flight paths allowing
more flights to be handled in the same time span. About 25% more.
Not if the FAA ****es off all the controllers and runs them
off!! GPS is useless without controllers
The FAA is ****ing off all their controllers so GPS don't
mean **** in the big picture.
  #172
Old October 30th 07, 02:15 AM posted to rec.aviation.piloting,rec.travel.air
Newps
Jim in NC
GPS does neither.
  #173
Old October 30th 07, 02:27 AM posted to rec.aviation.piloting,rec.travel.air
Morgans[_2_]
If they are heavies, the separation for wake turbulence is what the limiting
factor for separation, isn't it?
Jim in NC
  #174
Old October 30th 07, 02:32 AM posted to rec.aviation.piloting,rec.travel.air
John Kulp
On Mon, 29 Oct 2007 21:57:20 -0400, JerryLewis
Jim in NC
Just like your stupid racist rants. Don't mean ****. In any picture.
  #175
Old October 30th 07, 03:02 AM posted to rec.aviation.piloting,rec.travel.air
John Kulp
On Mon, 29 Oct 2007 22:27:34 -0400, "Morgans"
Well, wake turbulence is certainly a factor, particularly for the A380
which may slow down things even further. Which raises the question as
to whether it should be penalized more than others if they start to
use penalties.
  #176
Old October 30th 07, 03:10 AM posted to rec.aviation.piloting,rec.travel.air
JerryLewis
Jim in NC
Your opinion about me being "racist" is just like an
asshole. Everyone has one at it stinks. Including yours.
  #177
Old October 30th 07, 01:26 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
What makes you think that GPS could decrease the needed separation?
I didn't say anything about paying more. What I suggested in this forum a
month or so ago was the same net cost just make it cheaper off peak and more
expensive on-peak. That's how economics should work. Things should cost more
when they are in higher demand and less when they are in lower demand.
  #178
Old October 30th 07, 01:28 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
use penalties.
If it takes up more of a scarce asset then of course it should pay more.
  #179
Old October 30th 07, 03:58 PM posted to rec.aviation.piloting,rec.travel.air
Newps
You need up to six miles behind a heavy. Your spamcan needs four miles
behind a large, such as a B737. To say GPS increases available capacity
25% is ludicrous.
  #180
Old October 30th 07, 06:50 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
Frank F. Matthews wrote:
Gig 601XL Builder wrote:
would handle about 25% more flights on the same runways. Aren't
you paying enough all ready for flights? Want to pay more when the
politicos are stealing what money is already being paid for?
forum a month or so ago was the same net cost just make it cheaper
off peak and more expensive on-peak. That's how economics should
work. Things should cost more when they are in higher demand and
Then again it should also be that an increased use of resources should
cost more. Thus 747s should cost more than 737s and 380s more than
737s. The only serious issue should be how much more.
The difference in resource use between a 737 and a 747 both wanting to land
around the same time is insignificant as compared to the difference in use
of resources between and aircraft landing at 8:00 am and one at 2:00am.
Travel aid [email protected] Soaring 0 February 7th 06 12:25 PM
Travel aid [email protected] Restoration 0 February 7th 06 12:25 PM
Travel aid [email protected] General Aviation 0 February 7th 06 12:25 PM
Travel aid [email protected] Aviation Marketplace 0 February 7th 06 12:25 PM
Travel Supplements Jetnw Aviation Marketplace 0 September 15th 04 07:50 AM
