I've heard some discussion that there is a national number to call for
a void time on filed IFR flight plans. True? And if so, what's the number? |
"paul kgyy" wrote in message oups.com... I've heard some discussion that there is a national number to call for a void time on filed IFR flight plans. True? And if so, what's the number? False. |
On Nov 2, 12:45 pm, paul kgyy wrote:
I've heard some discussion that there is a national number to call for a void time on filed IFR flight plans. True? And if so, what's the number? I saw (I think it was here) that there is a nationwide clearance delivery number, 1-888-766-8267. Have not tried it yet... Cheers, John Clonts Temple, Texas N7NZ |
John Clonts wrote:
On Nov 2, 12:45 pm, paul kgyy wrote: I've heard some discussion that there is a national number to call for a void time on filed IFR flight plans. True? And if so, what's the number? I saw (I think it was here) that there is a nationwide clearance delivery number, 1-888-766-8267. Have not tried it yet... http://groups.google.com/group/rec.a...65d4248984dd78 |
Bill Watson wrote:
paul kgyy wrote: I've heard some discussion that there is a national number to call for a void time on filed IFR flight plans. True? And if so, what's the number? Current issue of AOPA mag has a good writeup and a tear-out reference card for FSS services. It includes the Clearance number. I guess you can get clearances but not a void time clearance which presumably requires local ATC contact. FSS should be able to contact ATC. Was this lost in the transition to LockMart? Matt |
"Bill Zaleski" wrote I use this number all the time, and get void times regularily. Hi Bill, I can't get my clearance by radio at my home airport. I've been taking off VFR and remaining VMC until I can get enough altitude to get my IFR clearance on the radio. However, sooner or later, the weather will be too bad for that. So I'll start practicing for getting a void time from the 800 number. How long is the void time that you usually get? I'm trying to decide if I have to be at the end of the runway, ready to go, or can I call and get the void time, then start the engine, taxi out, etc.? Thanks, Dennis |
Dennis Johnson wrote:
"Bill Zaleski" wrote I use this number all the time, and get void times regularily. Hi Bill, I can't get my clearance by radio at my home airport. I've been taking off VFR and remaining VMC until I can get enough altitude to get my IFR clearance on the radio. However, sooner or later, the weather will be too bad for that. So I'll start practicing for getting a void time from the 800 number. How long is the void time that you usually get? I'm trying to decide if I have to be at the end of the runway, ready to go, or can I call and get the void time, then start the engine, taxi out, etc.? Thanks, Dennis When I get a void time clearance at an uncontrolled field, I tell the briefer that I need say 10 minutes to get ready for takeoff and then they give you a clearance that has both a valid time and a void time. It won't be valid until say 10 minutes in the future and then void 10 minutes after that. Matt |
I used it about a month ago to depart Cynthiana, Kentucky into IFR.
Worked fine. They actually gave me a longer void time than I requested. Lexington approach was all ready for me. David Dave Butler wrote: John Clonts wrote: On Nov 2, 12:45 pm, paul kgyy wrote: I've heard some discussion that there is a national number to call for a void time on filed IFR flight plans. True? And if so, what's the number? I saw (I think it was here) that there is a nationwide clearance delivery number, 1-888-766-8267. Have not tried it yet... http://groups.google.com/group/rec.a...65d4248984dd78 |
"Matt Whiting" wrote When I get a void time clearance at an uncontrolled field, I tell the briefer that I need say 10 minutes to get ready for takeoff and then they give you a clearance that has both a valid time and a void time. It won't be valid until say 10 minutes in the future and then void 10 minutes after that. Matt Thanks, Matt. That would work fine for me. I'll give that a try next time I'm going IFR. Dennis |
"Matt Whiting" wrote When I get a void time clearance at an uncontrolled field, I tell the briefer that I need say 10 minutes to get ready for takeoff and then they give you a clearance that has both a valid time and a void time. It won't be valid until say 10 minutes in the future and then void 10 minutes after that. Matt Thanks, Matt. That would work fine for me. I'll give that a try next time I'm going IFR. I haven't obtained my clearance this way since LockMart took over, in fact I haven't even obtained a briefing since LockMart took over. DUATS is just too easy to use compared to calling a briefer who may be 3 states away. However, this technique worked fine with the old FSS. Matt |
| Can a failed Glide Slope also void the Localizer approach? | Jim Carter | Instrument Flight Rules | 17 | August 24th 06 10:01 PM |
| Have you guys ever noticed the void? | Stealth Pilot | Home Built | 32 | January 16th 06 01:19 AM |
| Pitts Number 1 registration number | Mirco | Aerobatics | 3 | December 4th 04 12:50 PM |
| First Time Buyer - High Time Turbo Arrow | [email protected] | Owning | 21 | July 6th 04 08:30 PM |
| they took me back in time and the nsa or japan wired my head and now they know the idea came from me so if your back in time and wounder what happen they change tim liverance history for good. I work at rts wright industries and it a time travel trap | tim liverance | Military Aviation | 0 | August 18th 03 01:18 AM |
