best way across the continental divide
Old November 3rd 07, 03:41 AM posted to rec.aviation.piloting
sashley
Default best way across the continental divide
I'll be ferrying a 152 from Austin to Tucson in a couple of weeks.
I'm looking for the lower route over the continental divide. Can I do
better that V66 from El Paso to Tucson?
Old November 3rd 07, 07:12 PM posted to rec.aviation.piloting
Bob Fry
"s" == sashley writes:
s I'll be ferrying a 152 from Austin to Tucson in a couple of
s weeks. I'm looking for the lower route over the continental
s divide. Can I do better that V66 from El Paso to Tucson?
Maybe but why not V94 to Deming and San Simon, thence Cochise and
Tucson. A friend and I brought his 90hp Aircoupe back that way. Not
much out there, but no high altitudes required either, whereas V66 has
a higher altitude and longer passage. Because of the same-looking
desert and the restricted airspace I advise having a moving-map GPS to
assist navigation.
If you pray for rain long enough, it eventually does fall. If you pray
for floodwaters to abate, they eventually do. The same happens in the
absence of prayers.
~ Steve Allen
Old November 6th 07, 03:01 AM posted to rec.aviation.piloting
GeorgeC[_2_]
If you are AOPA member, you might check out "Suggested Western Mountain Routes"
http://www.aopa.org/asf/wx/mountain.html#western Route 9 of the Southern, East
to West could be adapter and they use V94. It is the same thing that Bob Fry
said.
If it were me I'd take I10. West Texas is petty desolate and if you had an off
airport landing you would be near a road and help.
On Fri, 02 Nov 2007 20:41:42 -0700, sashley
GeorgeC
Old November 6th 07, 04:04 PM posted to rec.aviation.piloting
RST Engineering
I gotta hot flash. If I'm over west Texas, my off-airport landing is going
to be ON I-10. None of this "near a road" stuff.
"If you think you can, or think you can't, you're right."
--Henry Ford
"GeorgeC" wrote in message
news
Routes"
East
Fry
said.
an off
Old November 8th 07, 10:33 PM posted to rec.aviation.piloting
GeorgeC[_2_]
Good, that will make an easy rescue. I hate hiking in west Texas
On Tue, 6 Nov 2007 08:04:55 -0800, "RST Engineering"
GeorgeC
Old November 9th 07, 12:05 AM posted to rec.aviation.piloting
Veeduber
Funny Story (sorta)
About fifty years ago I was ferrying a thing with round engines that
was afraid of heights. Old Timer at La Junta tells me to just follow
the railroad; that I won't have any trouble.
The only thing he failed to mention was that you'd need a Pitts to
literally 'follow the railroad' through that section of the
mountains :-)
Old November 10th 07, 01:49 AM posted to rec.aviation.piloting
GeorgeC[_2_]
LOL
Funny Story (sorta)
mountains :-)
GeorgeC
Citizen stuns congresswoman: "Why should we divide Iraq for israel?" [email protected] Naval Aviation 0 October 24th 07 10:12 AM
FAA On User Fees: "The piston thing is not going to happen." Divide And Conquer? Larry Dighera Piloting 42 May 24th 07 04:59 PM
Continental 757 18R @ MCO Glen in Orlando Aviation Photos 4 November 30th 06 03:15 AM
Sidewinder engineering stoy/divide by zero leadfoot Naval Aviation 21 June 4th 05 01:25 PM
USAFE commander: 86th Airlift Wing will divide for combat, support operations Otis Willie Military Aviation 0 November 27th 03 11:31 PM
