Full procedure versu vectors
Old November 8th 07, 06:36 PM posted to rec.aviation.piloting
Wyatt Emmerich[_2_]
Default Full procedure versu vectors
Can you elaborate on why you feel the full precure is easier than
vectors
It is more predictable because it's published. No chance of miscommunication
on vectors. No constantly adjusting the heading bug. No chance of the
controller bringing you around too close for an automatic glideslope couple.
Vectors is very easy. But letting the GPS steering do the full approach and
autocouple the WAAS glideslope is even easier.
Wyatt Emmerich
President, Emmerich Newspapers
601-977-0470
PO Box 16709, Jackson MS 39236
Shipping: 246 Briarwood Drive, Suite 101, Jackson MS 39206
"Andrew Sarangan" wrote in message
On Nov 7, 11:58 am, "Wyatt Emmerich" wrote:
With my 530 upgraded to WAAS, I think it's easier to fly full procedure
GPS
approaches rather than take vectors. Does it complicate life for
controllers
when you request the full procedure? I get the feeling that they would
rather vector me on the ILS than have me shoot a GPS full approach.
I like the GPS full approach but I don't want to be irritating
controllers
and mucking up things by doing so.
vectors?
Old November 8th 07, 06:42 PM posted to rec.aviation.piloting
Wyatt Emmerich[_2_]
vectors?
Some other points: My S-tec flies a coupled GPSS WAAS approach quite a bit
smoother than a coupled ILS approach. Not sure why. Probably for the same
reason GPSS (GPS steering) is a lot smoother than HSI deviation autopilot
navigation. So I'd rather shoot the GPS. In addition, by shooting the GPS I
can use the ILS localizer and glideslope (if available on the same runway)
as a totally independent backup source of vertical and lateral guidance. So
I am shooting the GPS and monitoring using a second CDI getting the
localizer/glideslope data. (For technical reasons, I cannot do the
reverse--shoot the ILS and use my old CDI linked to the GPS as a backup.)
Wyatt Emmerich
601-977-0470
GPS
controllers
controllers
vectors?
Old November 8th 07, 08:48 PM posted to rec.aviation.piloting
Denny
If you are making routine instrument approaches, sitting there
watching the magic box move the little airplane on the screen and
drive the autopilot and your prime job in life is to control the
throttle as you whistle and tap in time to the music, you are not
current (in reality) and will be in a load of crap the day the
autopilot goes off line in real crud...
Far better you accept the vectors for every other flight and hand fly
the airplane on the steam gauges as you drip sweat in time to the
flopping of the indicator needles... Then someday when it actually
becomes life or death you will be ready...
denny
Old November 8th 07, 08:50 PM posted to rec.aviation.piloting
Brian[_1_]
On Nov 7, 12:29 pm, "Wyatt Emmerich" wrote:
So what should I say: "Request full GPS 16 approach if you're not too busy?"
Yes, I use that a lot. The one I use around his " If you can fit me in
I would like the ILS 10 Right with the Procedure turn."
Brian
Old November 8th 07, 09:04 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Brian wrote in
oups.com:
busy?"
Xactly.
Bertie
Old November 8th 07, 11:44 PM posted to rec.aviation.piloting
Steven P. McNicoll
"Wyatt Emmerich" wrote in message
By full approach, I mean flying it as published. Usually a T approach, but
sometimes there's a hold as part of the approach. Flying the full approach
is easier with the WAAS. You don't have to input headings on the heading
bug. It is more predictable because it's published. No chance of
miscommunication on vectors. No constantly adjusting the heading bug. No
chance of the controller bringing you around to close of an automatic
glideslope couples.
What specific approaches are you referring to?
Old November 8th 07, 11:55 PM posted to rec.aviation.piloting
Stefan
Wyatt Emmerich schrieb:
With my 530 upgraded to WAAS, I think it's easier to fly full procedure GPS
If you care about this, you're neither current nor safe.
Old November 9th 07, 02:40 PM posted to rec.aviation.piloting
Ron Natalie
procedure GPS approaches rather than take vectors.
I was told by an Air Force buddy:
Ask for what you want.
Fly what you get.
Log what you need.
Old November 11th 07, 09:58 PM posted to rec.aviation.piloting
denny
I am quite current, thank you, and often hand fly approaches for
precisely that reason. Knowing the ins and outs of the autopilot and
its capabilities is an important part of flying. A pilot needs to be
able to do both. They are not mutually exclusive. When I use the
autopilot, I want to use it to its fullest capability. With the new
Garmin 500W, that means a GPS approach. It is proving to be smoother
and more precise than an ILS.
Old November 11th 07, 10:00 PM posted to rec.aviation.piloting
bad vectors, no hand off Lurker Instrument Flight Rules 23 February 13th 07 10:03 PM
RNAV vectors Dan Luke Instrument Flight Rules 74 December 26th 06 10:31 PM
Vectors over water paul kgyy Instrument Flight Rules 22 May 4th 05 09:15 PM
Radio protocol regarding full stops on full stop only nights Ben Hallert Piloting 33 February 9th 05 07:52 PM
Approach to an LOM/IAF with PT (not vectors to final) O. Sami Saydjari Instrument Flight Rules 35 April 13th 04 09:54 PM
