On Nov 7, 10:32 am, "
wrote: On Nov 7, 9:52 am, "Bill Daniels" bildan@comcast-dot-net wrote: Actually several of the LX series have a fluxgate compass input for just this reason. I have no experience using them. I have the compass on my LX 7000. It is a pain to get aligned and even a small alignment error seems to affect the wind estimates, so I have stuck with the circling mode. Without good heading data I think it is impossible to estimate wind direction and speed in straight flight - you can estimate headwind component based on true airspeed versus ground speed if you have altitude (and temperature?) inputs, though I am unsure as to which systems offer this. I also run WinPilot and have found the two are generally pretty close on winds - though not always, which make you wonder on those long final glides... 9B |
Bill Daniels wrote:
Well, having flown over the mountains and plains while listening to other pilots reporting wind from all points of the compass, I've jotted down their readings, my data and the time. Later I compared that to the data collected by a real-time NOAA wind profiler 16NM away. Using the wind profiler as a reference, all of our calculated winds aloft data were highly unreliable. No one was better than the others and all were way off. The only useful data was collected while circling and then only if the circles were perfect, otherwise it's is a rough approximation.. To get accurate real-time wind data in flight you need four input variables, ground track, ground speed, trufe airspeed, and true heading. The last is because winds aloft data are referenced to true north. To date, all glide software omits heading input. Bill Daniels Another local pilot and I have compared wind calculations when flying in the same area. He has an L-NAV, and I use SeeYou. Both units are using airspeed data. Often the wind speeds are within a knot or two of each other, and wind direction often is the same within a few degrees. Either both units have amazingly similar errors, or both are quite accurate. |
On Nov 7, 11:45 pm, "Bill Daniels" bildan@comcast-dot-net wrote:
So how do you know for sure that a particular software produces accurate wind data? It seems that any test would require accurate wind data determined by some highly trusted independent method to compare with the software output. Bildan Exactly. Creating an accurate algorithm requires testing against known data. In our case, the algorithms were developed testing against carefully measured datasets, and stress tested against common instrumentation errors such as static errors common in our toys. In addition, I have tested our as-implemented algorithms against data derived with the addition of heading sensors. Other algorithms may not have been so tested. Hope this is helpful, Best Regards, Dave "YO" PS: Compasses don't work so good. Don't ask me how we know. PPS: These algorithms do not work well when wind changes rapidly (flying into a seabreeze etc), or in extended straight flight... |
On Nov 7, 4:44 am, wrote:
On Nov 6, 10:30 pm, Richard wrote: Software is what calculates the wind not the instrument. More than 98% of the engineering content of a flight computer is software. The instrument is in fact mostly software. And the software is completely different in the different instruments. Most instruments have pitot and temperature inputs and I beleive all use calculation of wind from circling drift in a theraml, course change, True Airspeed and GPS info. Incorrect. ILEC SN10 certainly does not require circling to calculate wind; you'll often get a wind indication on tow. They all probably use slightly different combinations of the inputs and use a different formula. Right. So, talk to experienced XC pilots who have *really* flown with these instruments, and find out which ones are considered to produce reliable wind info. Your mileage will vary. A lot. Hope that's helpful, Best Regards, Dave "YO" Dave, I have flown will all the instruments mention in my post. I am sorry for being slightly incorrect on my paragraph about wind calculation. It should have said: Most calculate wind from some of the following inputs circling drift in a theraml, course change, True Airspeed and GPS info. I have **really** flown with all the instruments and software mentioned. Even the SN10 for an entire summer (approx 200 hours). I found the SN10 just as good as the other instruments. Last year I flew approx 250 hours with B500, B2000 and WinPilot and for several months the LX1600 with SeeYou Mobile running on an embedded computer in the panel with a large color screen 6" diagonal. There is a small picture on the top of my home page of this setup. More will follow on my web as I work on this system. Thanks for correcting my mistakes. Richard www.craggyaero.com |
Richard wrote:
Last year I flew approx 250 hours with B500, B2000 and WinPilot and for several months the LX1600 with SeeYou Mobile running on an embedded computer in the panel with a large color screen 6" diagonal. There is a small picture on the top of my home page of this setup. More will follow on my web as I work on this system. I'm guessing by the left-handed flying and the trackball on the right that the system doesn't have touch screen! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Nov 8, 5:15 pm, Eric Greenwell wrote:
Richard wrote: Last year I flew approx 250 hours with B500, B2000 and WinPilot and for several months the LX1600 with SeeYou Mobile running on an embedded computer in the panel with a large color screen 6" diagonal. There is a small picture on the top of my home page of this setup. More will follow on my web as I work on this system. I'm guessing by the left-handed flying and the trackball on the right that the system doesn't have touch screen! -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org Eric, It does also have a touch screen, but I found that the ball track was easier to use. I also moved the ball track and strapped it on my leg. Got any ideas for a small ball track? or a different input device. Richard www.craggyaero.com |
![]() "Richard" wrote in message Got any ideas for a small ball track? or a different input device. Richard www.craggyaero.com This work? http://www.youtube.com/watch?v=M2x-UDka4pU Bill Daniels |
Richard wrote:
It does also have a touch screen, but I found that the ball track was easier to use. Would moving the screen a few inches towards the rear from the panel make the touch screen acceptable? I really like the touch screen input when using GNII or SeeYou Mobile. I also moved the ball track and strapped it on my leg. Got any ideas for a small ball track? or a different input device. These look interesting: No trackball to fall out... http://www.logitech.com/index.cfm/mi...s/407&cl=us,en Small and ambidextrous... http://www.logitech.com/index.cfm/mi...s/156&cl=us,en -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Nov 9, 4:26 pm, Eric Greenwell wrote:
Richard wrote: It does also have a touch screen, but I found that the ball track was easier to use. Would moving the screen a few inches towards the rear from the panel make the touch screen acceptable? I really like the touch screen input when using GNII or SeeYou Mobile. I also moved the ball track and strapped it on my leg. Got any ideas for a small ball track? or a different input device. These look interesting: No trackball to fall out... http://www.logitech.com/index.cfm/mi...controller/dev... Small and ambidextrous... http://www.logitech.com/index.cfm/mi...lls/devices/15... -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org I tried the second mice but the bigger one was easier to use. I may order that first ambidextrous one and see how it works. I would have to make a case for the display and computer to more the panel closer to me,but it would probably be better. I found that the touch was not as positive as one on an ipaq. Thanks, Richard www.craggyaero.com |
Antique Flight Computer | James Hamilton | Soaring | 0 | January 5th 06 06:04 PM |
Antique Flight Computer | James Hamilton | Soaring | 0 | January 5th 06 06:03 PM |
Flight computer for Sale | [email protected] | Piloting | 0 | August 20th 05 06:12 PM |
flight computer calculation | Tim | General Aviation | 1 | April 26th 05 10:40 AM |
TAERO 4000? | Al E. Kat | Home Built | 0 | September 28th 03 03:58 AM |
