resettable fuses - US source?
Old November 9th 07, 03:06 PM posted to rec.aviation.soaring
Richard[_1_]
Default resettable fuses - US source?
On Nov 7, 4:25 am, Gary Emerson wrote:
Has anyone located a source in the US for the neat little "resettable
fuses" that SH is using?
Also, I'd also like to get my hands on the protected blade terminal
strip that SH also uses. Male blade terminals that are protected by a
rectangular clear plastic shield that is in a terminal strip
configuration. I just don't know what the correct name is??
Thanks in advance!
Gary,
I have an assortment of Klixon circuit breaker on my web site. Also
other installation supplies including Tezfel wire.
http://www.craggyaero.com/installation_supplies.htm
Thanks,
Richard
www.craggyaero.com
Old November 9th 07, 09:09 PM posted to rec.aviation.soaring
raulb
On Nov 8, 4:47 pm, ContestID67 wrote:
- Tefzel wire is absoultely the best way to go.
In a glider why is 149-392 degree F wire "the best way to go"? If
your electronic device has a connection that gets to 65 C (149 F) the
device is going to be burned up anyway.
Old November 9th 07, 10:09 PM posted to rec.aviation.soaring
01-- Zero One
"raulb" wrote in message
oups.com:
Raul,
I, and I believe John, was speaking primarily about the power wiring,
especially from batteries to the front panel, fuses, switches, etc. In
those areas, a profound short will cause the wiring to get extremely
hotter almost instantly (if you do not have the system fused properly at
the battery terminals).
Once it heats up, most wire other than Tefzel style wire starts to melt,
smolder, and/or burn with acrid (and many times toxic) smoke and fumes.
Non electrical fires can also occur in gliders, ie, sun reflected in
canopies, etc. Again, if the fire is in a place where the 'low temp'
power wiring is, when it melts, it can short together, adding additional
heating to the fire and possibly causing an additional point of
combustion.
There is _so_ little wire in a glider, even expensive wire is cheap.
Larry "the _real_ cable guy" Goddard
01 "zero one" USA
Bussman Fuses kevmor Piloting 10 May 25th 07 03:25 AM
Bussman Fuses kevmor Piloting 2 May 22nd 07 09:28 PM
Fuses versus Breakers ContestID67 Soaring 14 March 14th 05 01:47 PM
Cortec source KEITH B SHOAPS Home Built 0 August 16th 04 10:51 PM
Source for Bolts Dave Home Built 2 May 20th 04 08:09 PM
