SeeYou Mobile Question (units)
Old November 10th 07, 01:59 AM posted to rec.aviation.soaring
Default SeeYou Mobile Question (units)
On Nov 9, 5:46 pm, Greg Arnold wrote:
Marc Ramsey wrote:
Greg Arnold wrote:
Paul Remde wrote:
Hi Dave,
Yes. SeeYou gets airspeed and wind data from the 302. The 302
calculates
the wind - not SeeYou.
So the 302A not only is a logger, but also has a computer that
calculates wind?
No, the 302 flight computer calculates wind. The 302A flight recorder
does not...
Marc
The 303 manual says that the 303 calculates the wind. Why would it do
that if the 302 does the same thing?
I don't understand why Cambridge would go to the expense of putting a
wind calculation computer in the 302 when the 302 always will be
connected to another instrument (303 or PDA) that can calculate the
wind. Basically, wind calculation in the 302 would serve no purpose, it
seems.
The 302 definitely calculates the wind. The 303 is a pretty dumb I2C
serial display, the "computer" is the 302. The *cost* of calculating
the wind in the 302 is likely dominated by the instrumentation
hardware used to measure air temp, pitot pressure and calculate TAS
etc. Since there is already a processor there the additional cost is
just software
Darryl
Old November 10th 07, 02:19 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Greg Arnold wrote:
Marc Ramsey wrote:
Greg Arnold wrote:
Paul Remde wrote:
Hi Dave,
calculates
calculates wind?
does not...
Marc
I've never actually used a 303, but there are several things it will do
when connected to a 302, that it simply doesn't do when connected to a
302A. Displaying wind may be one of them.
seems.
I wrote my own PDA software, and have used it with both a 302 and a
302A. The 302 data stream contains wind speed and direction (which is
pretty close to what I calculate using my own TAS/GS based circling wind
calculation) and headwind component (along with a bunch of other data),
the 302A does not. Make of that what you will...
Marc
Old November 10th 07, 02:47 AM posted to rec.aviation.soaring
Greg Arnold
Interesting -- they must have given the 302 that capacity so it could
output to the 303.
Old November 10th 07, 04:15 AM posted to rec.aviation.soaring
"Greg Arnold" wrote in message
Marc Ramsey wrote:
I wrote my own PDA software, and have used it with both a 302 and a 302A.
The 302 data stream contains wind speed and direction (which is pretty
output to the 303.
Greg,
They gave the 302 that capacity so it could talk to the Compaq 15xx PDA
software and the 303.
Back in the mid 1990s, Cambridge to distribute Pocket Nav PDA software. It
was very simular to Glide Navigator (same author.) The "Standard" version
was/is free. The standard verson works well with a generic GPS like the
Garmin 12XL. The "Plus" version, which wasn't free, provided an interface
with both the Model 20 data recorder and L-Nav/S-Nav. The characteristics of
Pocket Nav Standard/Plus can be seen at
http://www.cambridge-aero.com/pocketNAV.htm.
The 302 interface provides enhanced capabilities of both the old flight
Locally we have two glider still running the Standard version in combination
with a Garmin 12XL and EW Model D. Two pilots have 302s. One runs the
Cambridge software and the other Glide Navigator II. Two pilots have the new
microRecorder and run Glider Navigator II on their PDAs. I run Glide
Navigator II in combination with a Garmin 12XL and EW Model D.
Old November 10th 07, 01:36 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I stand corrected. Andrej at SeeYou confirmed that SeeYou uses the airspeed
information from the 302 and calculates the wind independently. It does not
use the 302 supplied wind calculation. The 302 calculates only a single
wind number (if I remember correctly). SeeYou calculates winds at several
altitudes (if I remember correctly).
That would explain why some pilots see different numbers in SeeYou than they
do on their 303 display.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
http://www.cumulus-soaring.com
On Nov 9, 3:05 pm, "Paul Remde" wrote:
Hi Dave,
calculates
the wind - not SeeYou. If SeeYou does not get wind data from the flight
computer it can calculate wind while circling, but the 302 also
calculates
wind while cruising.
Let me know if you ever want some one-on-one phone support for SeeYou. I
do
that quite often and my customers tell me it is worth every penny.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.http://www.cumulus-soaring.com
[snip]
Paul - ah are you sure? SeeYou Mobile also gets true airspeed and
other data from the 302. SeeYou Mobile is quite capable of using those
to guestimate non-circling winds. And it was my impression that it did
this and does not directly use the calculated wind data (that is also
passed from the 302). It certainly appears to behave that way to me.
Dave FYI the Cambridge dataport reference manual is an interesting
read, and SeeYou has a terminal mode (MenuSettingsHardwareTerminal)
you can look at what is going over the wire. That has helped me in the
past at least understand some behavior of SeeYou (and file a bug :-))
- SeeYou support is pretty darn good, check out their Forums. See
http://www.cambridge-aero.com/manual...v517_rev21.pdf
Cheers
Darryl
Old November 10th 07, 10:29 PM posted to rec.aviation.soaring
Mike125
Paul,
Is your instructional CD for CU Mobile still in the works?
Mike
Old November 11th 07, 03:02 AM posted to rec.aviation.soaring
Paul Remde
Hi Mike,
Thanks for asking. I have the best intentions, but I have not started it
yet. The SeeYou for PC training CDs have sold very well. I hope to get to
it soon.
Good Soaring,
Paul Remde
"Mike125" wrote in message
Paul,
Mike
Using mobile SeeYou Robert Hart Soaring 3 May 10th 06 09:42 PM
SeeYou MOBILE v2.0! Roy McMaster Soaring 10 July 12th 04 12:25 AM
SeeYou Mobile Robert Fidler Soaring 0 March 17th 04 04:18 PM
SeeYou Mobile question Greg Arnold Soaring 1 February 19th 04 04:24 PM
SeeYou mobile questions Andy Durbin Soaring 5 February 19th 04 12:16 AM
