Garmin 396 battery question
Old November 11th 07, 04:51 AM posted to rec.aviation.piloting,rec.aviation.owning
Paul kgyy
Default Garmin 396 battery question
I bought a 396 at Osh this summer and the battery never shows more
than half charge on the meter. However, if I just let it run, it runs
to its full time, so apparently the internal meter needs to be reset.
Anybody know how to do that? Yep, I did read the manual, couldn't
find anything.
Old November 11th 07, 09:04 PM posted to rec.aviation.piloting,rec.aviation.owning
Woody
Might try Garmin support. They are usually helpful.
http://www.garmin.com/garmin/cms/sit...upportcontacts
"Paul kgyy" wrote in message
ps.com...
find anything.
Old November 16th 07, 06:13 PM posted to rec.aviation.piloting, rec.aviation.owning
Paul kgyy
I found that I deep cycle the battery by running the gps until it
dies, then recharge, each recharge is a little better. After 3
cycles, it's now up to about 95%. It also helped to download new
firmware from garmin.
Old November 16th 07, 10:08 PM posted to rec.aviation.owning
JGalban via AviationKB.com
Paul has the right idea. I know several people with the same problem.
Originally, Garmin was sending them new batteries, but that didn't help.
It's some kind of bug in the software. As you continue cycling the battery,
the display should get a little better each time.
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200711/1
Garmin 396 battery question Paul kgyy Piloting 2 November 16th 07 06:13 PM
Garmin 196 battery connection? RNR[_2_] Piloting 8 February 20th 07 08:05 PM
Garmin 430 Memory Battery smf Owning 2 January 4th 07 12:56 PM
Battery Question mbremer216 Owning 7 October 6th 06 11:16 PM
Battery Question [email protected] Soaring 19 September 15th 05 02:38 AM
