Charging system failure cuts short a long X-Country
Old November 15th 07, 11:04 PM posted to rec.aviation.piloting
Dana M. Hague
Default Charging system failure cuts short a long X-Country
On Sun, 11 Nov 2007 20:36:36 -0600, SockPuppet
I have to say I'm pretty surprised to hear that aircraft alternators
don't have permanent magnets. Wow. Of all places not to have permanent
magnets: an aircraft, where so much is usually done for redundancy. I
find it kind of amazing.
All the alternators I've ever seen had permanent magnets...
Huh? I can't think of an alternator that DOES have permanent magnets,
unless you count the "lighting coils" on 2-strokes.
I missed the start of this discussion, but the reason NOT to use
permanent magnets in an alternator is that the output voltage will
vary with the rpm. This means that the alternator has to have
permanent magnets strong enough to produce sufficient 12V current even
at idle, and regulator has to be able to regulate the full rpm voltage
down to 12V while handling the full load current... which, just after
the engine starts and the battery's charging, can be a lot. This
means a big heavy regulator that needs to dissapate a lot of heat.
The field current is a lot less than the alternator's output current,
OTOH, so a fairly small, light regulator can handle the job, and no
regulation is needed on the alternator's output.
And, of course, an aircraft engine DOES have redundancy: Even if the
alternator or regulator fails, the magnetos keep the fan turning.
-Dana
If replying by email, please make the obvious changes.
What has four legs and an arm? A happy pit bull.
Another Long Cross Country: HPN to PAO in 6 Days (long) Journeyman Piloting 19 June 15th 06 11:47 PM
Charging System Gremlin [email protected] Owning 9 May 8th 06 08:41 PM
"System Failure Is Blamed In U.S. Downing Of British Jet" Mike Military Aviation 20 May 21st 04 06:39 PM
LONG DEPLOYMENTS, BENEFIT CUTS ERODE SUPPORT FOR PRESIDENT Ewe n0 who Naval Aviation 0 March 17th 04 07:57 PM
LONG DEPLOYMENTS, BENEFIT CUTS ERODE SUPPORT FOR PRESIDENT Ewe n0 who Military Aviation 0 March 17th 04 07:57 PM
