#61
"Keith Willshaw" wrote in message
"guy wastiaux" wrote in message ... well Italy is doing so by using F-16As for Air Defence, replacing Tornados F3s, as the air force is waiting for the Typhoon. If Italy is doing it, then why not Singapour ? Actually Italy are a development partner for Typhoon and have ordered 120 aircraft. No contradiction here. Yes, Italy is buying Typhoons. But until they show up, they're leasing ex-USAF F-16s to replace leased ex-RAF Tornado F.3s, which in turn replaced F-104s. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
#62
On Thu, 16 Oct 2003 18:16:22 GMT, William Wright wrote:
It's for the same reason that people shouldn't use Microsoft software while they continue to attempt to lock-in their customers: because every purchase carries a hidden cost of forcing the customer to purchase again from the same supplier. Yep! No technology lock-in using say Sun Solaris or HP/UX is there? Your argument, as I understand it, is that because Microsoft uses vendor lock-in, Sun and HP can't do. That's frankly a silly argument. A more sophisticated version is that you beleive I beleive that. That's equally absurd. So I conclude I have no idea what you are trying to get at. -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
#63
On Thu, 16 Oct 2003 19:17:55 +0100, Ian Craig wrote:
Thats the same as the Harrier ziff (sp?) manoeuvre? You mean VIFF ("Vectoring in forward flight"). BTW, can resepct usenet convention and post new comments below what you're replying to, please? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
#64
On Thu, 16 Oct 2003 13:10:30 -0700, Harry Andreas wrote:
In article , wrote: Postulating a South Asia Typhoon v F-35 engagement, what makes you think the more stealthy F-35 won't use NCTR then shoot the Typhoon in the face BVR with an AIM-120? I don't know what NCTR is, so I won't discuss that. If the F-35 is switching its radar on to detect the Typhoon, then the Typhoon will presumably be able to detect this (the signal will be billions of times stronger at the Typhoon than what's received back at the F-35), so I am doubtful of the possibility of the F-35 sneaking up on the Typhoon undetected. NCTR - Non Cooperative Target Recognition Umm, that's sound bizare to me -- isn't it normal for the target to not co-operate in being recognised? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
#65
On Thu, 16 Oct 2003 13:03:32 -0700, Harry Andreas wrote:
In article , wrote: They'd be well advised not to fire on a Typhoon either, since it's better than anything the USN is likely to have for some time (and I think the F-35C falls in that category). Is it better than an Amraam? Would the F-35 even get close enough to fire an AMRAAM? Meteor is longer range, and since the Typhoon is faster it could (depending on the tactical situation) decide whether to break contact. Speed doesn't matter as much when the opposing platform is stealthy. If you can't "see" it you can't shoot it, so speed does not dictate the engagement anymore. According to http://www.eurofighter.starstreak.net/Eurofighter/sensors.html, Typhoon can use infra-red to detect aircraft at a range of 30-50 nm (48-90 km), and possibly up to 80 nm (148 km). By comparison, AMRAAM has an estimated range of "17+ nm" (32 km). (From http://www.af.mil/factsheets/factsheet.asp?fsID=79). -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
#66
On Thu, 16 Oct 2003 13:14:32 -0600, Scott Ferrin wrote:
[regarding the F-35] Weight and apparently they think the big wing isn't necessary. Weight is the main issue for the STOVL version. That makes sense. You have to keep stealth in mind. The Typhoon likely wouldn't get to USE it's superior manueverability (assuming it will have it). If the F-35 is using its radar, the Typhoon will probably be able to detect it. If neither plane is using radar, there is no advantage to stealth. That's assuming the Typhoon can detect an LPI radar. What's that, and how is it different from other radars? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
#67
"phil hunt" wrote in message
On Thu, 16 Oct 2003 13:10:30 -0700, Harry Andreas wrote: NCTR - Non Cooperative Target Recognition Umm, that's sound bizare to me -- isn't it normal for the target to not co-operate in being recognised? Depends. Civilian aircraft are supposed to squawk a transponder code, but sometimes don't. So are friendly aircraft (unless the enemy can spoof your IFF). An aircraft not squawking could be hostile, or it could be a neutral airliner or friendly aircraft with a failed or inactive transponder. NCTR gives you a way to identify an aircraft type by specific characterisitcs of the radar return. Various different techniques are used; I won't even try to go into details of how they do it. KNowing the typer of aircraft, you can then make a more informed decision about the contact's status. IN Gulf War 1, two positive forms of ID were required to authorize a shoot. AWACS track from an Iraqi point of origin was good for one. NCTR or Visual ID was good for another. Lack of IFF did not count. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
#68
On Thu, 16 Oct 2003 13:14:32 -0600, Scott Ferrin wrote: That's assuming the Typhoon can detect an LPI radar. What's that, and how is it different from other radars? LPI = Low probability of intercept. Usually a psuedo-random spread-spectum signal that looks like random noise to a typical radar warning receiver. -- Tom Schoene Replace "invalid" with "net" to e-mail "If brave men and women never died, there would be nothing special about bravery." -- Andy Rooney (attributed) |
#69
Ian Craig wrote:
Excuse my ignornance, but whats an LPI radar? ( I only work with missiles) Low Probability of Intercept. An LPI radar uses various techniques to lower the probability that an enemy will detect and identify the signal as being a radar system. Mike |
#70
On Fri, 17 Oct 2003 23:49:37 GMT, Thomas Schoene wrote:
"phil hunt" wrote in message rg On Thu, 16 Oct 2003 13:14:32 -0600, Scott Ferrin wrote: That's assuming the Typhoon can detect an LPI radar. What's that, and how is it different from other radars? LPI = Low probability of intercept. Usually a psuedo-random spread-spectum signal that looks like random noise to a typical radar warning receiver. Do you (or anyone else) have any estimate on how effective this is? -- "It's easier to find people online who openly support the KKK than people who openly support the RIAA" -- comment on Wikipedia (My real email address would be if you added 275 to it and reversed the last two letters). |
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In | zeno | Instrument Flight Rules | 0 | October 30th 04 06:20 PM |
B-17s Debut, RAF Wellingtons Bomb & Fighters Sweep at Zeno's Video Drive-In | zeno | Home Built | 0 | October 30th 04 06:19 PM |
Why don't all fighters have low Wing Loading? | Chad Irby | Military Aviation | 6 | September 22nd 03 10:52 PM |
US (Brit/Japanese/German/USSR) Use of Gun Cameras in Fighters?? | ArtKramr | Military Aviation | 3 | July 17th 03 06:02 AM |
Scrambling fighters | John Doe | Military Aviation | 7 | July 2nd 03 09:26 PM |
