Precurved mylar needed in the USA
Old November 16th 07, 05:06 AM posted to rec.aviation.soaring
Mike[_8_]
Default Precurved mylar needed in the USA
100" of 78mm precurved mylar needed.
or a method to curve mylar myself.
thanks,
Mike
Old November 16th 07, 05:15 AM posted to rec.aviation.soaring
thanks,
Mike
Wings and Wheels has it
Old November 16th 07, 05:34 AM posted to rec.aviation.soaring
Mike[_8_]
thanks,
Mike
In 15m lengths.
Old November 16th 07, 06:04 AM posted to rec.aviation.soaring
BT
thanks,
Mike
In 15m lengths.
That sounds like more than 100" to me,
granted it is more like 585"
so you can either save it for the next use
or find some friends that need some too
B
Old November 16th 07, 01:33 PM posted to rec.aviation.soaring
thanks,
Mike
In 15m lengths.
Why don't you call Tim and see if he has any partial rolls?
Old November 16th 07, 04:40 PM posted to rec.aviation.soaring
Mike[_8_]
Tim does have a two meter piece.
Someone has offered to share an order, so problem solved.
Mike
thanks,
Mike
In 15m lengths.
Old November 16th 07, 07:12 PM posted to rec.aviation.soaring
Bob Kuykendall
On Nov 15, 9:06 pm, Mike wrote:
100" of 78mm precurved mylar needed...
Eek, 78mm is over 3" wide. That's wicked huge. When I made a set of
Mylar seals that wide, they buzzed off on the first tow.
Thanks, Bob K.
Old November 16th 07, 08:51 PM posted to rec.aviation.soaring
"Bob Kuykendall" wrote in message
Thanks, Bob K.
Bob,
Was that on the ruddervators of the your old HP-11?
http://www.soaridaho.com/Schreder
Old November 16th 07, 09:14 PM posted to rec.aviation.soaring
Bob Kuykendall
Just so. After the mylars departed the formation I made another set
out of the traditional beryllium-copper but had a great deal of
trouble applying them. By the time I got them on and sort of straight
they were badly kinked. In action they seemed to add quite a bit of
friction and were scratching the paint on the ruddervator. I stripped
them off before even trying to fly with them.
Thanks, Bob K.
Old November 16th 07, 10:06 PM posted to rec.aviation.soaring
Thanks, Bob K.
Bob,
I have metal seals on my HP-14. I assume they are beryllium-copper. They
have a couple of kinks that scratch the control surfaces. They need to be
replaced. Any suggestions?
HP-14 "6F"
http://www.soaridaho.com/Schreder/HP-14/N990/N990.html
installing mylar mmartin via AviationKB.com Soaring 15 August 20th 07 08:48 PM
Mylar tape [email protected] Soaring 1 October 31st 06 10:37 AM
ZZ Mylar seals Mike Soaring 3 March 29th 04 03:45 PM
mylar seals D.A.L Soaring 1 February 23rd 04 07:15 PM
Mylar (again) JJ Sinclair Soaring 0 December 11th 03 10:40 PM
