Ian wrote:
I tend to have the opposite problem - tug pilots may not tow much wood, and often go rather fast. So whenever I can, I make a point of talking to the tuggy beforehand and letting them know my ideal speed range. I've had the same problem in a 1-26. At 75 MPH IAS the bird gets a little more sensitive in pitch than I like on tow, so prior to departure I have asked for a 65 MPH IAS max. 60 MPH IAS is not that easy for a Pawnee to do, but just letting them know that it makes a big difference to a 1-26 does help. Jack |
On 17 Nov, 20:48, Shawn wrote:
Ian wrote: On 17 Nov, 16:55, wrote: Hey, glider pilots, go back to your FARs Our ... whats? F@ckin' American Rules :-) Ah. An equivalent of the Campaign Against Aviation, then? Or the Every Action Stops Aviation lot ... Ian |
On 17 Nov, 19:31, Mike Lindsay wrote:
A lot of years ago I was towed at 80 KPH when the glider had a placard reading Ne jamais depasser 65KPH. Nobody seemed the least bothered. A lot of years ago I was given an aerotow retrieve in a Slingsby Swallow by a tug pilot who was the CFI of a club which shall remain nameless. Max aerotow speed: 61kt (or some pathetic number about that). Actual tow speed: 90kt. And the Swallow was twitchy enough on the elevator at the best of times. Still, I was poor(er) then, and the CFI knew I was paying by the minute for the retrieve. Ian |
On 17 Nov, 21:49, J a c k wrote:
Ian wrote: I tend to have the opposite problem - tug pilots may not tow much wood, and often go rather fast. So whenever I can, I make a point of talking to the tuggy beforehand and letting them know my ideal speed range. I've had the same problem in a 1-26. At 75 MPH IAS the bird gets a little more sensitive in pitch than I like on tow, so prior to departure I have asked for a 65 MPH IAS max. 60 MPH IAS is not that easy for a Pawnee to do, but just letting them know that it makes a big difference to a 1-26 does help. My standard speed compromise with the Sutton Bank tuggy was to go up with the CHT needles on the red line. Faster than I'd have liked, slower than he'd have liked, but both reasonably happy! Ian |
Ian wrote:
On 17 Nov, 20:48, Shawn wrote: Ian wrote: On 17 Nov, 16:55, wrote: Hey, glider pilots, go back to your FARs Our ... whats? F@ckin' American Rules :-) Ah. An equivalent of the Campaign Against Aviation, then? Or the Every Action Stops Aviation lot ... That would be the Feds Against Aviation's (who's motto is "We're not happy 'till you're not happy.") rule book. Shawn |
On Sat, 17 Nov 2007 13:48:43 -0700, Shawn wrote:
Ian wrote: On 17 Nov, 16:55, wrote: Hey, glider pilots, go back to your FARs Our ... whats? F@ckin' American Rules :-) Shawn I just snorted coffee all over my keyboard, thanks.... :-) Peter |
On Nov 16, 11:18 pm, Hal wrote:
On Nov 16, 8:44 pm, Steve Leonard wrote: If you are carrying water and the tow plane slows down below the stall speed what would happen. I felt things were close once and used the radio to request speeding up. Can't imagine rocking the wings when you are in that situation. Been there, done that. Unfortunately the &%#$% tow pilot was on a different frequency. This was during a contest, so briefing & radio check were implied, not done individually. Had OK speed to about 500', then we started slowing down, and still flying straight out, not yet on a crosswind. I'm in a fully loaded ASW-20B. I immediately started asking for more speed, but no response. I dropped through the wake with nearly full back elevator, and stayed in low tow with stick against aft stop, ailerons feeling like mush, so keeping wings as level as I could (actually, they were rocking quite a bit) with rudder, and my left hand HOLDING the release (no worries if I let go too soon) just in case I start spinning. Took about 20 minutes to calm down while working the start gaggle after release. Why didn't I just release and get another tow? Well, although I was quite worked up and not very happy, I was not in a safe position to release at first, so I had to hang on at least for another 30-40 seconds. By then, since we were climbing, and I understood my predicament, I was too busy dealing with a situation I now understood, instead of creating a new one. So I decided I could calm down much better in the sailplane in a thermal, than landing with water, on a hot airport, pushing back to the launch line, yelling at the tow pilot, etc, etc, etc. -Tom |
On Nov 17, 11:55 am, wrote:
Hey, glider pilots, go back to your FARs -- they require you to agree with the tow pilot on four points before taking off: "airspeed limitations, emergency procedures, signals, and maximum angles of bank." (FAR 61.69). Some of this is standardized, so you don't have to say you'll use specific signals, but speeds vary according to ballasting, etc. So not only is it a good idea to talk to the tow pilot, it is actually a requirement. When I'm towing I want to talk to the glider pilot prior to hookup anyway so I know he has a working radio and I know who will be billed. So to standardize, I like towpilots to establish radio contact as you are being hooked up and find out WHO the pilot is and Where he wants to go. A third item is obviously the radio check, but if you've passed the name and destination along, you've also established that your radio is working. And this is the time to pass on your required tow speed. Fred Its all much too complicated. I gave up on this getting towed business; much simpler now ;-) See ya, Dave "YO" |
Seems to be a common thing at contests or any other time you are flying something different than what the pilot is use to pulling. How about the next time it happens to you, have your radio call be 'Towplane pulling Glider (Insert your callsign here), please speed up 5 MPH' or some such if you aren't clearly able to identify the towplane. Most of those guys know what glider they are pulling at the time. They keep track so they have a record of how many tows they made. Or better yet, spend a little time talking with the towpilots and getting to know them. When it is your turn, watch and see who comes by to pull you into the sky. If you are being pulled too slow or too fast, call the towpilot by name with your request. But do it very nicely, please. As John pointed out, these guys work hard so we can go play. And sometimes, they even get to go play, too. Thanks again to all that have towed me! Steve Leonard Wichita, KS I've been thinking about this and here is my simple minded non-expert, but merely intuitive explanation. Experts please tell me if I'm all wet. Even though you are tied to the towplane and get pulled along at what looks like from the ground to be the same speed, the glider is actually experiencing a reduced indicated airspeed and a relative wind at a different and unfavorable angle compared to the towplane due to the disturbance to the air from the towplane that the glider is flying through. Check out this picture of what is happening to the air behind an airplane not much bigger than many of our towplanes. http://upload.wikimedia.org/wikipedi...ortex_edit.jpg Anybody who has been in a sailboat race and in the wind shadow of another sailboat and been "blanketed" will recognize the loss of energy and sluggish performance of his boat relative to the one ahead in the "clear air". On tow, you're flying your glider between two large contrarotating tornadoes right in the area of maximum downwash. Even in high tow, you are still greatly affected by this downward component of the airflow behind the towplane, because the circulation extends well above the towplane's wing. Relative to the angle of attack he is experiencing, at the same tow speed, your effective angle of attack is not the same as his, as some of the air you are flying in behind him is actually being dragged along in the same direction as he is, so the indicated airspeed your glider feels is less than what he feels. It's a bit like a continuous wind gradient. The friction from the passage of the towplane causes the air to be pulled along behind him and that's what your flying in. Also there may also be some effects of being towed on longitudinal and roll stability some of which were studied by NASA when towing an QF-106 behind a C-141 Starlifter. Incidently, the Starlifter towplane took off first at about 132 mph, while the QF-106 was still on the ground. The QF-106 didn't lift off until they accelerated to 189 mph. Maybe this same technique of towplane taking off first could be used at some of the contests to pull those really heavy gliders (only with good pre-flight briefing between tow pilot and glider pilot, of course). http://www.nasa.gov/centers/dryden/a...4-02-DFRC.html Another interesting study involved some F-18's cruising in formation in the upward part of the leader's vortexes and gaining as much as 100 mile of range by using that energy. Maybe if your glider is real heavy, you should move way out to the side of the towplane, and try to get into the upward going part of the vortex. You might be able to get some of the opposite effects seen right behind the towplane where the downwash is maximal. Has anyone ever experienced a boost in glider tow behavior out to the side like that? Perhaps on a double tow or something like that? Has anything like that been formally studied and written up somewhere? |
Ben wrote:
On tow, you're flying your glider between two large contrarotating tornadoes right in the area of maximum downwash. Even in high tow, you I know people who did the comparison themselves. Here's what they told me: E.g. a Fox behind a "conventional" tug requires at least 65, better 70 knots to be safe. But the same Fox flyes perfectly happy at 55 knots behind an ultra light (or very light or light sport or whatever it's called in your country). I think this illustrates the effect of downwash as well as any picture or NASA research. |
Gear Up, pt 6 - p-47-being-towed.jpg (1/1) | Mitchell Holman | Aviation Photos | 1 | April 19th 07 03:34 PM |
towed aerial target at Cabeza Prieta NWR | Dave Kearton | Aviation Photos | 6 | January 8th 07 10:13 AM |
4 Gliders towed by one towplane -picture- | [email protected] | Soaring | 25 | January 4th 06 07:09 AM |
why so slow??!! | Heino & Deanne Weisberg | Home Built | 6 | November 6th 05 06:22 PM |
Dallas westbound NE-1 need something towed? | [email protected] | Soaring | 0 | October 29th 05 11:38 PM |
