Can I check something with you guys
Old November 23rd 07, 06:54 PM posted to alt.binaries.pictures.aviation
rustyknuckle
Default Can I check something with you guys
Glenn; I downloaded the pic from the newsgroup then the website.
The website pic was 96 dpi and the newsgroup came in at 72 dpi.
Viewing @ 300%, strangely enough the 72 dpi was a mite sharper.
I couldn't see any difference at the normal 100% view.
For what that may be worth.......
RK
Old November 23rd 07, 07:38 PM posted to alt.binaries.pictures.aviation
Glenn[_2_]
"Tom Callahan" wrote in message
I don't know the technical terms but this is what it looks like to me:
when I see the image in Outlook Express it's smaller (27x15 cm or so)
because I have the folders column on the left hand side of the screen. If
I open it then I get a full screen image of about 33x22 cms). Going to the
Warbirdz site it opens as a 32 x 20 cm image. The Warbirdz image is the
better of the three from a viewer's perspective. Does the dpi change? I
dunno. I just know what looks good. Maybe the key is that on thw Warbirdz
site it's a largepic and for the newsgroup it's downsized to save
bandwidth.
That's why we visit both locations. Show us a good photo in the newsgroup
and we know it's better on Warbirdz.
It's not something that jumps out to people. You are trying to make us
think.......
Not at all. On my monitor it is so different it's not funny. The sky is just
a series of pastel lines basically.
I've noticed that compression is more visible since I got this monitor but
this image is by far the worst.
Old November 23rd 07, 07:44 PM posted to alt.binaries.pictures.aviation
Glenn[_2_]
"rustyknuckle" wrote in message
. net...
RK
OK thanks guys.
I'm going to show all these replies to the webmaster now and ask her to
explain why my images
look different. If you could just see the difference I am seeing it would
amaze you. I don't understand why it looks
that way. All the work was done on this computer. Both images are the same,
as most of you agree (although some see some
minor differences)
Oh that's weird. I just went back to the image on the website and it's
normal again ????????????????????????? WTF
God I hate computers.
Old November 23rd 07, 08:21 PM posted to alt.binaries.pictures.aviation
Jon Woellhaf
Glenn,
If this happens again, consider taking a photo of the poorer quality image
on your monitor. From your description, it sounded like it was obviously
different. They looked virtually the same to me.
Jon
"Glenn" wrote in message
. net...
RK
OK thanks guys.
same, as most of you agree (although some see some
minor differences)
Old November 23rd 07, 08:36 PM posted to alt.binaries.pictures.aviation
John Meyer
bandwidth.
think.......
That sounds like your monitor is set to display thousands of colors
rather than millions.
Is God willing to prevent evil, but not able? Then he is not omnipotent.
Is he able, but not willing? Then he is malevolent.
Is he both able and willing? Then whence cometh evil?
Is he neither able nor willing? Then why call him God?
- Epicurus (341- 270 BC)
Old November 23rd 07, 09:39 PM posted to alt.binaries.pictures.aviation
Glenn[_2_]
"John Meyer" wrote in message
message
If
I
Warbirdz
bandwidth.
newsgroup
think.......
just
but
It does, or did. It resolved itself. But picture me looking at the same
image. one in my saved folder on my D Drive and the one on my webpage.
Both are identical files but one displays differently.
Old November 23rd 07, 10:22 PM posted to alt.binaries.pictures.aviation
CWO4 Dave Mann
Glenn wrote:
http://www.warbirdz.net/largepic.php?ID=12327
The above link, when you view it, does it look identical to the image
below.
reason why I ask is on my monitor, the link above is obviously
compressed but the image below
is the same image, just not uploaded onto my website. The image i post
below, looks good and the compression is nowhere near as evident.
Yet it is the same image.
Is this glaringly obvious to you guys as well.
In the upper left corner --- that's a Connie, right?
I looked at both images using my 21" Dell flat LCD with an NVidia
GEFORCE 6800 video card, running at maximum speed and resolution and
size on a Linux AMD64 CPU with 4GB of RAM, and using The GIMP graphics
application.
One image looked a slight bit less "full" than the other, but I think my
results are probably subjective .. No preference over either image.
HTH, YMMV, LSMFT
Dave
Old November 23rd 07, 11:01 PM posted to alt.binaries.pictures.aviation
Martin Helms
"Glenn" schrieb im Newsbeitrag
below.
reason why I ask is on my monitor, the link above is obviously compressed
but the image below
Having downloaded both pics, I ran a quick and dirty per-pixel comparison of
both using Adobe Photoshop.
The result can be seen in the attached file.
Dark areas (preferably true black) mark pixels that are absolutely
identical, bright (preferably true white) areas mark pixels that are 100%
different (directly contrary, eg black and white).
Shades of grey thereby indicate how much similar or different each pixel of
both images is.
As you can see, the image is mostly black, hence indicating little
difference in both versions.
There is, however, a slight one and it is indeed visible, though it requires
both a good monitor as well as good eyes and expertise to spot it (I'll
therefore claim I posses all of them ).
Anyway, since both images already have a difference in size (byte-wise), and
are also using a lossy compression (JPEG), one can definately conclude they
WILL be different, no matter what.
The true question is rather how much and does it matter
The comparison image is hence saved in the lossless, albeit big, PNG format
to not falsify any of the differences.
I hereby also want to apologize for the somewhat big size.
If you brighten up the image (or better yet, enhance contrast and/or gamma),
you will see the difference even better.
I just didn't do that because it could qualify as cheating (making it stick
out more than it actually does).
As a sidenote:
As you can see, the white spots are arranged in a quadratic shape, so-called
macro blocks, each 8x8 pixels in dimension.
That is because of the JPEG compression that will subdivide each image to
such 8x8 pxs blocks and compress each independantly.
This is also the cause for bad image quality on higher compression rating on
high-contrast areas in the picture.
A wavelet compression, such as featured by JPEG2000 will harvest much better
results with such complicated image material.
This is also the reason why JPEG isn't very well-suited for screenshots or
text images, btw.
PS: Since some of you wrote about the DPI differencies:
That does not matter at all when viewing the image on your computer screen.
DPI are only involved in analogue-digital or digital-analogue conversion
(i.e. scanning the picture or printing it).
If you are using IrfanView (a free and great image viewer for Windows,
http://www.irfanview.net ), you can freely adjust the DPI of an image, with
no results at all to the display on your screen.
Size (as on the screen) is only determined by the pixel dimensions.
Of course, it depends on the size and resolution of your minotr, too, which
is why you cannot ultimately say "This image is 15*10cm large!" - it may be,
but only for you on your current screen.
Once again me meet the DPI, this time, of the monitor.
The smaller the actual dimensions of it are and the more pixels it can
display (= higer resoltuion), the higher its DPI will be, and the smaller
(if meausered by a ruler put on the screen) the image will appear.
Also, when scanning and printing, using the same DPI setting for both (e.g.
300 DPI, which should be good enough for ordinary prints on normal paper),
the copy image will appear just as large as it was in reality.
Print with twice the DPI of the scan and it will be half as large (per
dimension, hence 1/4th in area) or half the amount for the vice versa.
Sincerely hoping to have cleared up more confusion than caused,
Martin
Old November 24th 07, 01:49 AM posted to alt.binaries.pictures.aviation
Rex[_2_]
Glenn
I cannot differentiate between the two.
Using an nvidia 8600GT card and a Proview 19" wide screen monitor.
Regards
Rex
below.
but the image below
Old November 24th 07, 05:39 AM posted to alt.binaries.pictures.aviation
Jon Woellhaf
"CWO4 Dave Mann" wrote
... HTH, YMMV, LSMFT
How many people under 60 know what LSMFT means? (Without cheating)
SSA: Good Guys & Bad Guys [email protected] Soaring 1 October 5th 06 04:11 AM
Guys, guys, guys -- the party is TOMORROW night! Jay Honeck Piloting 3 July 24th 05 05:26 AM
Guys Dummy Owning 2 August 26th 04 01:01 AM
Guys Dummy General Aviation 1 August 23rd 04 11:42 PM
You guys were right -- thanks! Jay Honeck Piloting 27 July 28th 03 10:50 PM
