I am new to glider ownership an am about to disassemble the interior
to get to all the cables etc. for inspection and lubrication. Any advice on what is the best lubricant to use for cables etc.? |
Yes. You don't lubricate cables in the first place.
Bert "Steve Freeman" wrote in message ... I am new to glider ownership an am about to disassemble the interior to get to all the cables etc. for inspection and lubrication. Any advice on what is the best lubricant to use for cables etc.? |
On Nov 27, 1:25 am, "Bert Willing" bw_no_spam_ple...@tango-
whisky.com wrote: Yes. You don't lubricate cables in the first place. Interesting!. Why not? I use LPS2 to lubricate the rudder cable runs on my ASW-28 and did the same on my ASW-19b. Andy |
Why would you do that ?
In places where the cable runs along a pulley, there is no friction. In places where the cable runs in teflon hoses, lubrication will attract dust, and make the cable more abrasive. Same goes with the roller guides of control tubes. If you lubricate them, they'll attract dust and you will end up with intends in the tube. "Andy" wrote in message ... On Nov 27, 1:25 am, "Bert Willing" bw_no_spam_ple...@tango- whisky.com wrote: Yes. You don't lubricate cables in the first place. Interesting!. Why not? I use LPS2 to lubricate the rudder cable runs on my ASW-28 and did the same on my ASW-19b. Andy |
Bert,
I beg to disagree. When wire rope or cables flex over a pulley or sheave, the strands rub against one another. Some larger cables are lubricated as part of the manufacturing process. I think the smaller aircraft cable we're talking about is not. Lubricating the cables, where they flex or rub, will greatly enhance their service life. A good penetrating lubricant, one with a carrier that evaporates, is best (Tri-Flow or Super Lube spray come to mind). bumper zz Minden "Bert Willing" wrote in message ... Yes. You don't lubricate cables in the first place. Bert "Steve Freeman" wrote in message ... I am new to glider ownership an am about to disassemble the interior to get to all the cables etc. for inspection and lubrication. Any advice on what is the best lubricant to use for cables etc.? |
Andy wrote:
On Nov 27, 1:25 am, "Bert Willing" bw_no_spam_ple...@tango- whisky.com wrote: Yes. You don't lubricate cables in the first place. Interesting!. Why not? I use LPS2 to lubricate the rudder cable runs on my ASW-28 and did the same on my ASW-19b. I never lubricated the rudder cables on my ASW 20 (I flew it for 11 years), and I've never lubricated the cables on my ASH 26 E (13 years so far). The maintenance manuals on these gliders did not call for lubrication of the cables, nor did the friction increase while I owned the gliders, and there was never any corrosion. So, without a problem to cure, I never tried to fix one. Did you have a problem that required a cure? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
On Nov 27, 12:25 am, "Bert Willing" bw_no_spam_ple...@tango-
whisky.com wrote: Yes. You don't lubricate cables in the first place. If you're like me, you remember reading that advice in an old copy of AC43.13, complete with references to long-obsolete lubricants like "Par-L-Ketone." From memory, 43.13 said to not oil cables because lubricants thin enough to get to the cable core will just displace the factory lubricant and make them more, not less, susceptible to internal friction and internal corrosion. However, in the 1998 edition of AC43.13, Chapter 7 seems to have been revamped, and makes several reasonable recommendations about inspecting and lubing cables and what to lube them with (MIL-C-16173, grade 4, or MIL-C-11796, Class I, if you can find them). It also describes nylon-jacketed cables, which I believe is a newish development. My own recommendation would be to avoid thinned oils like tri-flow for unsheathed cables. As much as I like Tri-Flow as a general lubricant, it tends to leave a sticky surface, and its solvents might tend to wash away more of the internal lubricant than it applies. Those waxy dry lubricants now available for bicycles might be a good bet, since they tend to leave a dry, tack-free surface that does not attract abrasive particles. I use that stuff on the cables and pivots of my climbing gear, and it seems to work a treat. Thanks, Bob K. |
"Doug Hoffman" wrote in message ... The following relates the actual experience an HP-14 owner had with lubricants and dirt. Source is Wayne Paul's HP web site. It supports Bob Kuykendall's assertion that careful selection of lubricant is important, if one chooses to lubricate at all. "I have had to replace all of the cables, the previous owner had greased them at the fairleads, and they picked up dirt and got badly worn very fast. I also replaced the aileron pushrods, as they also had been greased at the guides, and ended up with wear marks. " -- At the time of cable/push-rod replacement, the HP-14 was 27 years old; however, only had 167 hours of flight time. I thought I had purchased an inexpensive sailplane, but in fact I had purchased a cheap sailplane. (http://www.soaridaho.com/Schreder/HP-14/N990/N990.html) Wayne HP-14 "6F" http://www.soaridaho.com/Schreder/ |
with lubricants and dirt. Source is Wayne Paul's HP web site. It supports Bob Kuykendall's assertion that careful selection of lubricant is important, if one chooses to lubricate at all. "I have had to replace all of the cables, the previous owner had greased them at the fairleads, and they picked up dirt and got badly worn very fast. I also replaced the aileron pushrods, as they also had been greased at the guides, and ended up with wear marks. " -- Regards, Doug -- Posted via a free Usenet account from http://www.teranews.com |
| SZD55 Maintenance | icsonka | Soaring | 6 | October 13th 06 06:13 AM |
| Maintenance and Insurance | AceHyflyer | Owning | 12 | July 27th 06 06:01 AM |
| What do you do about maintenance? | Andrew Gideon | Owning | 5 | July 2nd 06 05:00 PM |
| Maintenance Personel | Charles Talleyrand | Naval Aviation | 6 | August 6th 03 12:35 AM |
| B-25 Maintenance | Randy | Military Aviation | 1 | July 11th 03 04:37 AM |
