Cleveland Wheel Shims
Old November 27th 07, 12:55 PM posted to rec.aviation.homebuilt
Stealth Pilot[_2_]
Default Cleveland Wheel Shims
On Mon, 26 Nov 2007 07:37:03 -0800, Ron Wanttaja
On Mon, 26 Nov 2007 22:54:12 +0900, Stealth Pilot
On Sun, 25 Nov 2007 16:59:20 -0800, Ron Wanttaja
On Sun, 25 Nov 2007 16:33:17 -0800 (PST), stol wrote:
On Nov 24, 12:00 pm, Ron Wanttaja wrote:
I need to add some shims to the axles of my Fly Baby to reduce the side-to-side
movement of my wheels (the axles aren't threaded at the end, the wheels are held
on with a cross-bolt through a bushing).
I think you've got something wrong there ron.
the shims need to bear on the inner races and when tightened by the
split pinned nut the taper roller bearings need to have no slop but
also no preload.
Check my description...there *is* no nut to tighten. The wheel slides on, then
a short piece of tubing (which I called a "bushing" but have been corrected to
term a "collar") slides onto the axle as a retainer. There's a cross-hole
drilled through the collar and axle, and an AN-3 bolt goes through to hold them.
There's no threads on the axle, and nothing to tighten. See:
http://www.bowersflybaby.com/wheel.jpg
the solution is not to add shims but to put in another cross drilling
for the bolt through the outer tube to move it in snug again. say at
30 degrees to the existing cross drilling.
make a little jig to position the drill. looks like an easy task.
Stealth Pilot
Old November 30th 07, 03:05 AM posted to rec.aviation.homebuilt
John[_9_]
I basically need some thin metal washers with a 1.5" inside diameter. �I'm
suspecting the "Ring-Grease Seal" items on Cleveland 600x6 wheels is what I'm
looking for. �However, there are multiple part numbers for the same item
(153-00300, 153-00400, etc.). �I'm suspecting these are differing
thickness...anybody got a table that shows the thickness by part number?
The 153-xxxxx Ring-Grease Seal is designed to back up the wheel
bearing. In effect it is a cupped washer. It might serve for what you
want if you grind the rubber cup off of the flat washer it is bonded
to. It is not a typical axle spacer though.
John Dupre'
Old November 30th 07, 06:22 AM posted to rec.aviation.homebuilt
I basically need some thin metal washers with a 1.5" inside diameter. ?I'm
looking for. ?However, there are multiple part numbers for the same item
(153-00300, 153-00400, etc.). ?I'm suspecting these are differing
Thanks, John, exactly the kind of info I needed. One of our fellow RAHers has
some shim stock and it cutting me the kind of washers I need.
Cleveland Nat Air Show Woody Aviation Photos 0 September 2nd 07 12:18 AM
Cleveland Air Show.. what if... Dave S Piloting 5 September 3rd 04 01:59 AM
IFR Through Cleveland Bartscher Instrument Flight Rules 2 June 2nd 04 04:22 PM
Wheel pants for 6.00 x 6 wheel/tire Wallace Berry Home Built 2 January 23rd 04 04:22 AM
Decent into Cleveland john cop Instrument Flight Rules 19 October 19th 03 06:09 PM
