C-130 rocket assisted takeoff length
Old October 18th 03, 03:58 PM
George
Default C-130 rocket assisted takeoff length
Hi all.
Does anyone know C-130 rocket assisted takeoff length?
Is it possible that it can be 30 meters (100 ft)?
Thanks.
Old October 18th 03, 04:21 PM
Thomas Schoene
"George" wrote in message
om
Hi all.
I think normal JATO take off distance would be in the range of 800-1000 ft.
depending on load.
The CREDIBLE SPORT aircraft modifed for a second Iranian hostage rescue
attempt were supposed to take off with about a 100-ft ground roll. They
used a massive amount of rocket assist, far more that the usual RATO units.
A couple of descriptions of Credible Sport:
http://home.earthlink.net/~quade/crediblesport.html
http://www.spectrumwd.com/c130/artic...ible_Sport.htm
and pictures:
http://www.spectrumwd.com/c130/new-pics/dec.htm
Tom Schoene Replace "invalid" with "net" to e-mail
"If brave men and women never died, there would be nothing
special about bravery." -- Andy Rooney (attributed)
Old October 18th 03, 07:49 PM
Guy Alcala
George wrote:
Hi all.
Thanks.
The SAC for the Navy C-130G (equivalent to the C-130E IIRR)
is online. Normal vs. Jato (8 x 1,000 lb. thrust ATO
rockets) t/o runs (in feet) at weights of 155,000 (normal
max., 2.5g) and 175,000 lb (overload, 2.25g):
Calm, ISA @ SL, Military rated power and 50% flaps. 155,000
lb: 4,125/3,565 feet. 175,000 lb: 5,390/4,750 feet.
The C-130H values should be somewhat less, as it had more
powerful engines but the same max. weights. I don't know
how the C-130J stacks up for t/o.
Guy
Old October 18th 03, 11:32 PM
Steve R.
The 130J isn't set up for Jato. Those Dowty props and RR engines really toss
it in the air without it though!
Steve
"Guy Alcala" wrote in message
George wrote:
Hi all.
Thanks.
Guy
Old October 19th 03, 12:33 AM
Les Matheson
Credible Sport actually got airborne in much less than 100ft. More like 2
1/2 - 5 tire revolutions.
Les
units.
and pictures:
Old October 19th 03, 07:48 PM
Michael Williamson
Peter, what did they do to the Herc that they flew off of the
Forrestal(?) ? (without JATO at that!)
Well, it does help with ground run if you can guarantee a 30 kt
wind down the runway every time...
Mike
That's true isn't it?...one tends to forget that ~30 knots is a
LOT of airspeed gain, especially at the top of the take-off roll
range, takes a comparatevly long time to gather that extra speed.
An a/c that you normally rotate at 105 you now rotate at 75
(well, not really but you get my drift)
-Gord.
Old October 19th 03, 08:19 PM
Guy Alcala
" wrote:
Michael Williamson
Mike
There's also the advantage that you don't have to pull G off the end of
the deck, in order to leave the 'ground' and climb over obstacles.
Indeed, you can even sink a bit. And of course, the a/c was almost
certainly nowhere near MTOW -- max. landing weight (8fps) is only
130,000 lb., vice the 155,000 or 175,000 lb. MTOW, and I imagine the
a/c was well under max. landing weight when it landed. The Herc's
power-on stall speeds (100% flaps) at landing weights are under 100
knots. For instance, at a landing weight of 110,459 lb. it has power
off/on stall speeds (100% flaps) of 80/65 kts. At 122,586 lb. they're
91/75 kts. 50% flaps would be used for takeoff, but even with no wind,
at a t/o weight of 100,000 lb. the a/c has a ground run of only 1,500
ft. at sea level. Add 30 kts or more of wind over deck and the Herc's
ability to land or takeoff from a large deck carrier isn't a surprise.
Guy
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
U.S. Air Force award of four rocket launches this year is likely to be delayed Larry Dighera Military Aviation 15 May 14th 04 01:58 PM
Air Force launches rocket with secret military payload from Cape Canaveral Otis Willie Military Aviation 0 September 9th 03 09:07 PM
