#71
John Mazor writes:
Then they must get a lot of cases that go to court because that's bad science. They get a lot of cases because some people still cannot prevent themselves from drinking and driving. Those people often go to jail. There's nothing wrong with the science. You can get a non-zero reading without consuming alcohol, even with lab-grade equipment. All you have to do is prove that it's not alcohol. That's why the FAA allows up to a .02% BAC reading before flying. It should be zero. |
#72
nobody writes:
Which is it, cigarettes or alcohol? Both addictions can cost hundreds of dollars a month. One could easily spend several hundered dollars on one bottle of wine per month. I don't wouldn't consider that addicted. That's not what the addicts do. They spend their money on cheaper beverages, often with more alcohol content. A pack-a-day smoker spends more then 'several hunderd dollars' a month on cigarettes. Yes. Drug addiction has many common traits irrespective of the drug being abused. You should stay far away from these people. They're likely to burn down their home smoking while they're sleeping I do, or at least I try. Unfortunately, I still must breathe their second-hand smoke on occasion. A large percentage of home fires are due to smoking. |
#73
Wolfgang Schwanke writes:
The withdrawal of the drug. What unavoidable biological mechanism cause mental pain? What gives you that idea? Sorry, I misunderstood. |
#74
John Mazor writes:
Did you specify "daily" in your sweeping statement? Answer my question first. |
#75
Mxsmanic wrote in
: John Mazor writes: Then they must get a lot of cases that go to court because that's bad science. They get a lot of cases because some people still cannot prevent themselves from drinking and driving. Those people often go to jail. There's nothing wrong with the science. You can get a non-zero reading without consuming alcohol, even with lab-grade equipment. All you have to do is prove that it's not alcohol. That's why the FAA allows up to a .02% BAC reading before flying. It should be zero. no it souldn't moron. Besides, you don't fly so it's none of your business Bertie |
#76
Mxsmanic wrote in
: nobody writes: Which is it, cigarettes or alcohol? Both addictions can cost hundreds of dollars a month. One could easily spend several hundered dollars on one bottle of wine per month. I don't wouldn't consider that addicted. That's not what the addicts do. They spend their money on cheaper beverages, often with more alcohol content. No, they don't, proving once again that there isn't an area under the sun that you have even the remotest grasp of. I do, or at least I try. More likely they stay away from you. Bertie |
#77
Mxsmanic wrote in
: Wolfgang Schwanke writes: The withdrawal of the drug. What unavoidable biological mechanism cause mental pain? What gives you that idea? Sorry, I misunderstood. Because you're an idiot. Bertie |
#78
Mxsmanic wrote in
: John Mazor writes: Did you specify "daily" in your sweeping statement? Answer my question first. You didn't ask one moron, that's th epoint. Bertie |
#79
Stefan wrote in
: Neil Gould schrieb: Aside from countries where consumption of alcohol may be illegal, which countries have a zero tolerance for drinking and driving? An overview of the Situation in Europe: http://www.tcs.ch/etc/medialib/main/...0002.File.tmp/ EUR_alcoolemie_carte.gif Actually, in Poland and Lithuania, I think those are the minimums.. Bertie |
#80
You keep talking about drugs. What drugs are you talking about?
Alcohol, in this case. Why, what are you on? The question should be, "what drugs are you _not_ on, that you should be taking? That says volumes. -- Jim in NC |
An Unexpected Treat | Jay Beckman | Piloting | 14 | March 13th 07 03:01 PM |
Glider in an unexpected place... | Capt. Geoffrey Thorpe | Soaring | 3 | September 15th 06 03:56 AM |
Headset: Unexpected safety bonus | Vaughn | Owning | 16 | January 18th 06 02:27 AM |
ATTN: Commercial or military pilots- Boy Scout needs a favor | [email protected] | Piloting | 1 | March 18th 05 03:49 AM |
Did commercial glider pilots used to give instruction? | Mark James Boyd | Soaring | 7 | December 19th 03 07:51 AM |
