Spinner strobing as a "Bird Strike Countermeasure"
Old December 3rd 07, 11:48 AM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default Spinner strobing as a "Bird Strike Countermeasure"
Mxsmanic wrote in
Maxwell writes:
Seems I have heard the 16 cps is all that is required for movies to
appear continuous.
Motion pictures use 24 ips, repeated once,
Blah blah, cut and paste boi does it again.
Boring.
Bring out a sockpuppet again! That was fuuuun!
Bertie
Old December 3rd 07, 11:49 AM posted to rec.aviation.piloting
Mxsmanic wrote in
Roger (K8RI) writes:
At cruise RPM that effect would be completely lost. There's not a
bird or human alive that can discern stroboscopic effects of more
than a couple hundred cycles let alone over a 1000. Most of us can't
even discern 60 cps.
Birds have much better vision than human beings, and I don't believe
anyone has tested their ability to discern stroboscopic effects.
What using your parakeet as a wing man now in combat sim games?
Bertie
Old December 3rd 07, 01:18 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Yes - I have a name[_2_]
"Mxsmanic" wrote in message
And the front fan on a turbofan is turning at around 40-50 revolutions per
second, not
thousands.
My phonograph turns at either 33-1/3 or 45 RPM, which is just as relevant to
this conversation as your mention of turbofans.
Old December 3rd 07, 04:01 PM posted to rec.aviation.piloting, rec.aviation.homebuilt
soaringpilot2
I wonder about doing the candy stripe spiral on them, or painting the blades different colors...
The candy stripe spiral on the spinner was a recognition thing, the
Germans started doing that in the summer of '44. The Japanese did
something similar thru the war years by painting the inboard leading
edge of the wing yellow. Quick recognition by your comrades in a
dogfight when head on...
This is the first I've heard of the 1/3 and 2/3's strobe effect, I
thought it was also for recognition...Maybe I'll try it on my 172...
-Ryan
Old December 3rd 07, 06:19 PM posted to rec.aviation.piloting, rec.aviation.homebuilt
U.S. TV is 60 fields/second, European is 50/second.
And it takes two interlaced fields to make a frame, therefore US
broadcast TV standard (NTSC) is actually only 30 frames per second.
Europe's PAL and SECAM standards are both 50 interlaced fields per
second, yielding 25 actual frames per second.
Saturday 072807 in Oshkosh Pt 6 - Warbird show pix I forgot to post earlier [10/33] - "Bird Dog.jpg" yEnc (1/1) Just Plane Noise[_2_] Aviation Photos 0 July 31st 07 10:48 PM
"British trace missile in copter strike to Iran" Mike[_7_] Naval Aviation 8 March 10th 07 08:20 PM
Bird strike(s) Jay Honeck Piloting 45 November 30th 05 04:39 AM
Bird strike Jase Vanover Piloting 16 May 17th 05 11:44 AM
