IGC Google Earth Replay
Old December 8th 07, 09:11 PM posted to rec.aviation.soaring
tobi
Default IGC Google Earth Replay
On 4 Dez., 16:48, wrote:
On Nov 28, 12:32 pm, wrote:
may be someone is interested in a small programm (http://ywtw.de/igcsim.html
) that allows you to replay IGC-files in Google Earth. It's a replay,
without use of kml, best for flights in the mountains :-)
Tobi,
This is an absolutely brilliant add-on! Thanks so much for making it
available. Please keep us posted on upgrades.
Larry
thanks for the kind comments. There is an upgrade available ( full
time control, realtime drift eliminate for those who want to synch
with seeyou and more). Probably there will be further upgrades during
the winter, but not in spring and summer at all. You may take a fast
look from the Help-Menu.
Bye Tobias
  #32
Old December 11th 07, 06:16 PM posted to rec.aviation.soaring
jcarlyle
Tobias, this is an absolutely brilliant piece of work! Thank you so
much for writing it and offering it to the gliding community.
-John
  #33
Old December 12th 07, 02:15 PM posted to rec.aviation.soaring
Andy[_1_]
On Dec 4, 1:33 pm, "Roger Kelly" wrote:
Great tool! Will it accept any other file format as input? I have an old
Garmin unit which will produce mapsource files - either .gdb or tab
delimited text. I know Gps Visualizer will convert some file types but I
don't see .igc as an available output file type.
You can convert the *.gdb files to *.igc files with g7towin.exe. A
web search should find the source.
Andy
  #34
Old January 1st 08, 05:22 PM posted to rec.aviation.soaring
On Nov 28 2007, 9:41 pm, "
On Nov 28, 5:15 pm, "
On Nov 28, 2:18 wrote:
sorry, I should have mentioned, you need Google Earth 4.2 and the
current .NET installed
It falls over with an immediate null reference exception on Windows XP
SP2 on my ThinkPad. Anybody want the stack trace? email me.
No cigar.
I've got Google Earth 4.2 and the .NET 3.0 Framework with the very
latest updates. When you say the current .NET exactly what version and
update are you running against? On what OS platform? I'm on XP SP2 at
the very latest public release updates.
Anybody else got this to run?
Darryl
BTW a quick check with the debugger showed this apparently uses .NET
2.0, so you don't need to waste time downloading the NET 3.0
bloatware. I've emailedTobithe debug information.
Darryl
Tobias found the problem with his code and .NET strangeness on my
laptop, seems like it may have affect some other laptops as well.
Anyhow it is all working great on my ThinkPad now.
Thanks Tobias for this great utility!
Darryl Ramm
  #35
Old January 2nd 08, 04:15 AM posted to rec.aviation.soaring
On Jan 1, 9:22 am, "
No cigar.
Darryl
Darryl
Darryl Ramm
Darryl,
So does that mean there's an updated application to download from
Tobias' site? I've been using it with a thinkpad, too, still think
it's an absolutely great program but have noticed some strangeness,
too.
Thanks,
Larry
  #36
Old January 2nd 08, 05:25 PM posted to rec.aviation.soaring
No cigar.
Darryl
Darryl
Darryl Ramm
Darryl,
too.
Thanks,
Larry
There was an update recently, it at least fixed a .NET startup
problems on some laptops where the application would crash as I
described earlier. I am guessing that is very unlikely to be related
to any other problems - except Tobias told me that the left hand
control panel may size wrong on laptop displays but can just be
changed manually. I have no idea what other things if any changed. Why
don't you try the latest build anyhow and then email him a description
of the strangeness you are seeing. He is very responsive.
Darryl
  #37
Old January 2nd 08, 05:41 PM posted to rec.aviation.soaring
Tim Taylor
On Jan 2, 10:25 am, "
No cigar.
Darryl
Darryl
Darryl Ramm
Darryl,
too.
Thanks,
Larry
Darryl
The new update has speed and thermal indicators and a skip thermals
function. Continues to improve with each update. For future updates
a choice of units for speed and thermals would be great.
Tim
  #38
Old January 25th 08, 11:35 AM posted to rec.aviation.soaring
tobi
For future updates
Tim,
there is a new Build available with imperial units, diagrams and
more.
http://www.ywtw.de/igcsimen.html
Tobias
  #39
Old January 25th 08, 05:17 PM posted to rec.aviation.soaring
Tim Taylor
On Jan 25, 4:35 am, tobi wrote:
For future updates
Tim,
more.http://www.ywtw.de/igcsimen.html
Tobias
Tobias,
Thank you. The update is great.
Tim
  #40
Old January 25th 08, 10:08 PM posted to rec.aviation.soaring
Paul Remde
Agreed! Very cool! Thanks for creating it!
Paul Remde
"Tim Taylor" wrote in message
For future updates
Tim,
Tobias
Tobias,
Tim
Google Earth Frank Whiteley Soaring 3 November 16th 07 12:36 AM
Google Earth fun Al Denelsbeck Aviation Photos 4 January 11th 07 04:31 PM
Google Earth - Glider David Pye Soaring 1 June 8th 06 04:39 PM
SeeYou 3D and Google Earth [email protected] Soaring 4 May 23rd 06 04:24 AM
Google Earth ttaylor at cc.usu.edu Soaring 8 September 22nd 05 12:07 PM
