On Sat, 15 Dec 2007 08:33:20 -0800 (PST), "
wrote: On Dec 15, 9:18 am, "LWG" wrote: Al, I liked your video. I have a '78. Les We may not get there very fast, but we do get there in comfort :-) I affectionately call mine a "Slowdowner" You got it! G Are you a BAC member? |
On Dec 15, 10:51 am, B A R R Y
wrote: You got it! G Are you a BAC member? No, trying to keep my aviation subscription costs to a bare bones minimum. If I joined everything that was presented to me, I'd be in the poor house for that alone. $50 can buy me quite a bit of av gas. While my past annual was a little pricey, my A&P has done everything he can to make my plane the safest on the ramp :-) and he has a lot of resources to tap into for the Beech parts thankfully. Allen |
On Dec 14, 4:10 pm, " wrote:
Went up to touch some clouds today. http://www.youtube.com/watch?v=RHC-s9cl8cE Using the same technique in creating my last video, put the camera on the glareshield and pretty much set it and forgot it. While I was VMC, I did capture some "forward" scenery. Great day for flying, tops were between 1800 and 2000, ceilings at KMBO was 700 and 600 ceilings at KHKS. Video is comprised of taxiing, takeoff, 2 ILS (I actually did three), one VOR Alpha and landing back at home. I edited most of the IMC part since just how much viewing pleasure can someone get out of a grey screen beside me being there in the action. Where there is an extended amount of IMC in the beginning, I subtitled the page to break the monotony. Hope people enjoy the video! Allen hmm, I noticed your markers were on "high". Any reason for this? Doesn't doing that kind of defeat the purpose of markers in the first place? |
On Dec 15, 1:18 pm, buttman wrote:
hmm, I noticed your markers were on "high". Any reason for this? Doesn't doing that kind of defeat the purpose of markers in the first place? Yes, actual reason was for "video purposes". Marker beacon comes in louder over the external speaker which of course has to be louder then the roar of the engine. If I am not videoing, then of course, marker would be set on low and over the headphones rather then external speaker as the high setting does get rather annoying. It's not so annoying on high over the external speaker. For my own analytical "post flight briefing" I listen for any power changes in my videos. The less power changes there are, the more stabler the approach is. This is one of the reasons I haven't really actively looked into getting the ATC audio fed into my videos, as I want to hear in the video what the plane is doing based on my inputs. My IFR briefingI use is below my name. I put this on a laminated knee board size piece of paper. I have the approach on a yoke clip. For me, it's as "bullet proof" as it gets as it includes my descent and before landing check list from the POH. It keeps me well ahead of the plane. Allen IFR briefing Side one IFR Field Elevation Type of Approach Nav / Course - check Nav1 and Nav2 GS Intercept or FAF Altitude Minimums / Missed approach Nav 1 SET - Check ACTIVE frequency and IDENT Nav 2 SET and IDENT Com 1 SET Com 2 SET Reset Timer to zero APPROACH (15 miles from Airport) Approach Briefing (COMPLETE) ATIS - SET Altimeter - SET Mixture - ENRICH AS REQUIRED Landing Light - AS REQUIRED Activate Approach on GPS Side two (I flip it over after completing the above) THREE MILES BEFORE FINAL APPROACH FIX Push CDI button to select VLOC for NON GPS approaches Slow to 90 knots - 2100 RPM and 10 degree flaps for level flight. Seatbacks UPRIGHT, Seat belts and Shoulder Harness SECURE Fuel Selector Valve - SELECT TANK MORE NEARLY FULL (Feel for detent and check visually) Mixture - FULL RICH (or as required by field elevation) Fuel Boost Pump - ON Landing Light - AS REQUIRED Marker - SET volume to speaker Carburetor Heat - ON at FINAL APPROACH FIX Start timer started at Final Approach Fix CROSSING any fix Turn - DG Header Bug Time - Verify Timer Started Twist - Nav1 Throttle - Reduce power Talk Track MISSED approach Cram (Carb heat off, Full Power) Climb Clean (Flaps) Correct turn to assigned heading Call = Tower 43L missed approach |
On Sat, 15 Dec 2007 12:02:57 -0800 (PST), "
wrote: It's not so annoying on high over the external speaker. I like the beacon on the speaker. I also listen to ATIS, ASOS, and nav station ID's on the speaker. This makes it easier to hear actual radio calls, vs. the background "noise". I can hear the speaker perfectly over the noise through my Bose X. |
We did this years ago at one airline. When the training department
found out what we were doing they wanted copies for training purposes. We used a half-empty tissue box on the glrare shield, and a patch cord plugged into the Oberserver's (jump seat) mixer box for ATC and cockpit audio. Neat stuff. Have a great one! Bush On Fri, 14 Dec 2007 16:10:33 -0800 (PST), " wrote: Went up to touch some clouds today. http://www.youtube.com/watch?v=RHC-s9cl8cE Using the same technique in creating my last video, put the camera on the glareshield and pretty much set it and forgot it. While I was VMC, I did capture some "forward" scenery. Great day for flying, tops were between 1800 and 2000, ceilings at KMBO was 700 and 600 ceilings at KHKS. Video is comprised of taxiing, takeoff, 2 ILS (I actually did three), one VOR Alpha and landing back at home. I edited most of the IMC part since just how much viewing pleasure can someone get out of a grey screen beside me being there in the action. Where there is an extended amount of IMC in the beginning, I subtitled the page to break the monotony. Hope people enjoy the video! Allen |
On Dec 15, 4:39 pm, B A R R Y wrote:
I also listen to ATIS, ASOS, and nav station ID's on the speaker. This makes it easier to hear actual radio calls, vs. the background "noise". I can hear the speaker perfectly over the noise through my Bose X. I need to try this in flight. As you can see in the beginning of the video, I did this for the ASOS to be recorded on the video. I never really thought to listen to ASOS/ATIS over the speaker but it does make perfect sense as you say, don't have to struggle to listen to actual calls over the weather. Allen |
Yeah, I've heard them all before. We have to worry about bird strikes ...
from behind! I am a BAC member. What a fantastic group! When I had to land quite a distance from home because of an electrical problem, I was able to download a wiring schematic for the local shop and get first-rate A&P assistance within a half-hour. Just amazing. You'd have to be crazy to have a Sport, Sundowner or Sierra and not be a member of that group. "B A R R Y" wrote in message ... On Sat, 15 Dec 2007 08:33:20 -0800 (PST), " wrote: On Dec 15, 9:18 am, "LWG" wrote: Al, I liked your video. I have a '78. Les We may not get there very fast, but we do get there in comfort :-) I affectionately call mine a "Slowdowner" You got it! G Are you a BAC member? |
On Dec 15, 8:29 pm, "LWG" wrote:
Yeah, I've heard them all before. We have to worry about bird strikes ... from behind! Bad time of the year to fly around here as well, migratory birds are on the move. Not unusual to get advisories from KJAN for radar identified flocks of birds. Big ones too, geese and pelicans. KMBO next to a very large reservoir where these things like to gather. In a month or two, starlings move through, and lines ranging in the miles for these birds, amazing clouds of these things not to be reckoned with. Fully understood on what you say about BAC, but after my overhaul (happened after an in flight cylinder failure) 5 years ago, pretty much the maintenance on my bird has been fluids and normal wear and tear. This year, all hoses got replaced (5 year old from overhaul), 30 year brake lines got replaced on my annual, so this year, just a little more pricey at 5K, but ooooh so worth it. Still cheaper to own, since I have flown 123.5 hours this year, and 145.9 last year. Next big project will be interior. Allen |
I'm still trying to get the cabin warm in the winter. I have door seals on
order. I have already replaced (and learned alot about) the SCAT tubes in the cabin. You will probably want to do that as part of your interior. wrote in message ... On Dec 15, 8:29 pm, "LWG" wrote: Yeah, I've heard them all before. We have to worry about bird strikes ... from behind! Bad time of the year to fly around here as well, migratory birds are on the move. Not unusual to get advisories from KJAN for radar identified flocks of birds. Big ones too, geese and pelicans. KMBO next to a very large reservoir where these things like to gather. In a month or two, starlings move through, and lines ranging in the miles for these birds, amazing clouds of these things not to be reckoned with. Fully understood on what you say about BAC, but after my overhaul (happened after an in flight cylinder failure) 5 years ago, pretty much the maintenance on my bird has been fluids and normal wear and tear. This year, all hoses got replaced (5 year old from overhaul), 30 year brake lines got replaced on my annual, so this year, just a little more pricey at 5K, but ooooh so worth it. Still cheaper to own, since I have flown 123.5 hours this year, and 145.9 last year. Next big project will be interior. Allen |
VIDEO: Frecce Tricolore collides over Ramstein - a new head on video | Montblack | Piloting | 1 | February 12th 05 04:03 AM |
My First GPS Approaches | john smith | Instrument Flight Rules | 10 | November 9th 04 09:14 PM |
ILS PRM approaches | Riddler | Instrument Flight Rules | 2 | October 28th 04 12:37 PM |
Vancouver IFR approaches? | Robert M. Gary | Piloting | 7 | June 24th 04 08:51 PM |
RNAV approaches | Kevin Chandler | Piloting | 3 | September 18th 03 06:00 PM |
