#41
Morgans wrote:
"Dudley Henriques" wrote The 51 was a fine airplane, and it worked well at all altitudes but it was nearing the end of its run at the end of the war. I loved the airplane and flew it often but for me, flying the F8F Bearcat one sunny afternoon in December, redefined the meaning of the term "prop fighter performance". In my opinion, if the war had lingered on and the Bear had been mass produced for both theaters, the F8F would have not seen its match anywhere. Interesting. I had never heard that expressed, before. Would the F8F had the legs to do the long range bomber escort missions? How about top speeds; was it as fast, or faster than the 51? The Bear had VERY short legs and even with the drop tank would never have made it as a long range fighter. In close, intercept, and shoot it down fast was the Bear's prime intended function. -- Dudley Henriques |
#42
On Sun, 16 Dec 2007 15:07:48 -0500, "Morgans" wrote:
Here's a pic of the Junior/Malmo http://en.wikipedia.org/wiki/Image:B...d-edna.arp.jpg I have often wondered why that configuration is not more popular. I've not flown one, but it would seem like the visibility while flying level, turning or anytime would be superior to high or low wings, than either upward or downward views, depending whether it is high or low wing. Cockpit access issues and CG, would be my guesses. Kind of an awkward clamber into the cockpit, without even a wing to stand on and nothing above you to grab onto. Imagine trying to get into the cockpit while wearing a skirt...that was a consideration, back in the '50s and '60s. Then again, I thought this was once produced in Scotland, too...:-) CG-wise, it lacks growth capacity. If you hang a bigger engine on the front, you can't balance it by shifting the cabin back slightly because the wing spar passes directly behind the pilot's shoulders. Years and years ago, I looked into a VW-powered homebuilt with a similar configuration, the HAPI Cygnet SF-2A. Geeze, I still even have the info pack. It says, "The Cygnet is designed to use a 60HP VW engine. Anything larger will weigh too much..." Of course, HAPI was also in the VW engine business. Back to my first point, the brochure show a woman...in jeans...climbing in. No way she could do it in a skirt; the cockpit side rails is pretty high. Ron Wanttaja |
#43
Ron Wanttaja schrieb:
Cockpit access issues and CG, would be my guesses. I don't think so. Cockpit access is no issue, and the pilot sits pretty near the CG. But if you take a closer look, the pilot's sight is not that great, either, at least if you believe that the pilot should be able to look over his shoulder before turning: http://de.wikipedia.org/wiki/Bild:Bo208C_HB-UPF_68.jpg The main disadvantage is the wing spar which prevents a reasonable and easy accessible luggage room behind the pilot and which limits the whole design to two seaters. |
#44
Well said...
The Mustang was (is) a fine mount, and while it shares the mantra as the "best" fighter with others, each fighter had to be flown in it's design environment. It was best (designed to be) long range fighter ESCORT, which it excelled at. Down low and in the dirt, many other planes could out gun, out turn, out climb and out dive it.. One of the best tactics for a P-51 pilot if caught down low was to get outta dodge.. Some of the enemy pilots called them "runstangs" (I forget the translation) But 15000 ft, while other planes started to wheeze.. the stang could still breathe, and , clearly in it's design element, was the ride to have...up at that alt.... As a "dogfighter" ? (within the definition) .. nope... Dave On Sun, 16 Dec 2007 15:44:56 +0000 (UTC), Bertie the Bunyip wrote: wrote in news:4a4b3843-18c7-4881-b8b8- : I don't know if there were any higher performance versions of the ME-109, There were. there were long wing variants built later in the war specificially for high altitude ops. but the TA-152 could outperform the Mustang. It was a souped up version of the FW-190. http://en.wikipedia.org/wiki/Focke-Wulf_Ta_152 Well, the figures don't tell the whole story. while speed and rate of clinmb certainly would have given an advantage, as a package, though, it's much harder to define what makes one airplane superior to another.Performance can be a lot more than numbers at the end of the day... For instance, there was a loonie Swedish count in the 1960s who symathised with the Biafrans in their war of secession from Nigeria ( the short story here is that oil was discovered in Biafra and they diecided to take the money and run, having been a seperate nation inthe first place, only paired up with the rest of Nigeria by arbitrary colonialist redefintion of nations) Anyhoo. this guy and some of his buds gathered up the best airplanes available to the, the Bolkow Junior, manufactured in Sweden as the Malmö a midget little box of a thing with a Cont A75 in the nose,put some hard points on it and off to Biafra they went. They proceeded to decimate the Nigerian Air Force, which at that time had the very latest Russian stuff, Mig 21s, 17s, etc by flying at treetop level to their bases and launching their little match head missiles at them while they were still on the grond. they'd then race back to their own lines at treetop level at 75 knots and any Migs that got airborne found it impossible to get a bead on them. Eventaully, all of these mercenaries were killed (IIRC, there were another half dozen airplanes and pilots brought it over time, also lost) but the damage they inflicted on the vastly superior forces of the other side were astonishing. Just as well the NAF didn't have 150s, eh? OK, this is an odd example, but it goes to show in a bizarre kind of way that numbers in a performance column don't tell the whole story. Bertie |
#45
Dave wrote in
: Well said... The Mustang was (is) a fine mount, and while it shares the mantra as the "best" fighter with others, each fighter had to be flown in it's design environment. It was best (designed to be) long range fighter ESCORT, which it excelled at. Down low and in the dirt, many other planes could out gun, out turn, out climb and out dive it.. One of the best tactics for a P-51 pilot if caught down low was to get outta dodge.. Some of the enemy pilots called them "runstangs" (I forget the translation) But 15000 ft, while other planes started to wheeze.. the stang could still breathe, and , clearly in it's design element, was the ride to have...up at that alt.... As a "dogfighter" ? (within the definition) .. nope... I'd love to find out, but basically we're arguing about which supermodel we'd sleep with, of course. Bertie |
#46
On Sun, 16 Dec 2007 17:16:28 -0500, Dudley Henriques
wrote: Morgans wrote: "Dudley Henriques" wrote The 51 was a fine airplane, and it worked well at all altitudes but it was nearing the end of its run at the end of the war. I loved the airplane and flew it often but for me, flying the F8F Bearcat one sunny afternoon in December, redefined the meaning of the term "prop fighter performance". In my opinion, if the war had lingered on and the Bear had been mass produced for both theaters, the F8F would have not seen its match anywhere. Interesting. I had never heard that expressed, before. Would the F8F had the legs to do the long range bomber escort missions? As I recall the F8F had the most powerful piston engine ever used in a fighter. Then later the same engine was used in the Skyraider. Now there is one BIG airplane! Not very fast, but BIG! Roger (K8RI) How about top speeds; was it as fast, or faster than the 51? The Bear had VERY short legs and even with the drop tank would never have made it as a long range fighter. In close, intercept, and shoot it down fast was the Bear's prime intended function. |
#47
"Roger (K8RI)" wrote in
: On Sun, 16 Dec 2007 17:16:28 -0500, Dudley Henriques wrote: Morgans wrote: "Dudley Henriques" wrote The 51 was a fine airplane, and it worked well at all altitudes but it was nearing the end of its run at the end of the war. I loved the airplane and flew it often but for me, flying the F8F Bearcat one sunny afternoon in December, redefined the meaning of the term "prop fighter performance". In my opinion, if the war had lingered on and the Bear had been mass produced for both theaters, the F8F would have not seen its match anywhere. Interesting. I had never heard that expressed, before. Would the F8F had the legs to do the long range bomber escort missions? As I recall the F8F had the most powerful piston engine ever used in a fighter. Then later the same engine was used in the Skyraider. Now there is one BIG airplane! Not very fast, but BIG! Nah, it only had a R2800 and not a very powerful variant at that. The P47 used a more powerful version of the same engine and there were other more powerful airplanes out there like the later Griffon powered Spitfires and the Hawker Sea Fury. I don't think any of them went any better than the Bearcat, though. Bertie |
#48
Roger (K8RI) wrote:
On Sun, 16 Dec 2007 17:16:28 -0500, Dudley Henriques wrote: Morgans wrote: "Dudley Henriques" wrote The 51 was a fine airplane, and it worked well at all altitudes but it was nearing the end of its run at the end of the war. I loved the airplane and flew it often but for me, flying the F8F Bearcat one sunny afternoon in December, redefined the meaning of the term "prop fighter performance". In my opinion, if the war had lingered on and the Bear had been mass produced for both theaters, the F8F would have not seen its match anywhere. Interesting. I had never heard that expressed, before. Would the F8F had the legs to do the long range bomber escort missions? As I recall the F8F had the most powerful piston engine ever used in a fighter. Then later the same engine was used in the Skyraider. Now there is one BIG airplane! Not very fast, but BIG! Roger (K8RI) How about top speeds; was it as fast, or faster than the 51? The Bear had VERY short legs and even with the drop tank would never have made it as a long range fighter. In close, intercept, and shoot it down fast was the Bear's prime intended function. Hi Rog; The Bear can an R2800 in it. The -2 that I flew I believe had a 2800-30 in it. The entire airplane was just a frame to support the engine. One of the things I liked about the Bear was that Grumman drooped the nose a bit (they did this on all their prop fighters) so you could actually see where the hell you were going. It was an awesome airplane. The prop at rest (had a huge Aero Products on the nose) looked like the diameter spanned the wing tips :-)) On takeoff, it broke ground before you could get the throttle up. Unlike the 51, you couldn't allow the stick to come forward a bit on the takeoff roll because of the severe lack of tip clearance on the prop. You took off 3 point and you landed 3 point in the Bearcat. It was and still is a wonderful airplane! I think I can say with some degree of certainty that Streak wouldn't **** on the tires of the Bear, it was THAT pretty!! D -- Dudley Henriques |
#49
![]() "Dudley Henriques" wrote in message news ![]() Morgans wrote: "Dudley Henriques" wrote The 51 was a fine airplane, and it worked well at all altitudes but it was nearing the end of its run at the end of the war. I loved the airplane and flew it often but for me, flying the F8F Bearcat one sunny afternoon in December, redefined the meaning of the term "prop fighter performance". In my opinion, if the war had lingered on and the Bear had been mass produced for both theaters, the F8F would have not seen its match anywhere. Interesting. I had never heard that expressed, before. Would the F8F had the legs to do the long range bomber escort missions? How about top speeds; was it as fast, or faster than the 51? The Bear had VERY short legs and even with the drop tank would never have made it as a long range fighter. In close, intercept, and shoot it down fast was the Bear's prime intended function. Designed to defeat Kamikazes' at a distance, no? |
#50
![]() "Bertie the Bunyip" wrote You don't mean the little Macchis from the fifties, do you? They were high wing but kind of swept forwards. Nope, and I'll be darned if I could find it, even with a while searching for it. I remember it from an article in AOPA, I think. It was probably 5-7 years ago. On the cover, as I recall. It looked a lot like this, but it was not this one: http://www.ldap.cz/en/mfi.htm I could be all wrong, but I thought it was an Italian design, that had been certified for a while in like form, anyway. I thought it had a name like Cappra, or something. -- Jim in NC |
ac_DemelleTodd-Dogfight.jpg | [email protected] | Aviation Photos | 0 | December 15th 07 02:36 PM |
The Old Ones Are The Best Ones - dogfight.jpg (1/1) | Mitchell Holman | Aviation Photos | 0 | June 10th 07 01:30 PM |
Best dogfight gun? | Bjørnar Bolsøy | Military Aviation | 317 | January 24th 04 06:24 PM |
Could technology bring back the Red Baron dogfight? | Ed Rasimus | Military Aviation | 24 | January 17th 04 09:45 PM |
