aerobatic kit planes
Old December 16th 07, 10:39 PM posted to rec.aviation.piloting
Default aerobatic kit planes
What are the kit or plans built planes that people use for aerobatics?
Old December 17th 07, 03:12 AM posted to rec.aviation.piloting
On Dec 16, 4:42 pm, Bertie the Bunyip wrote:
wrote in news:44ab21c3-d16f-4704-8d5e-
lots of 'em. You want to go to rec.aviation.homebuilt for some real info,
but it depends on how much $ you got and what you want to do with he
aiplane (sport competition, one or two seat, etc)
Probably the best beginners aerobatic airplane is the EAAs own Acrosport II
Bertie.
Thanks will check out both.
Old December 17th 07, 12:39 PM posted to rec.aviation.piloting
Lou
I see a lot of Acrosport IIs on Barnstormers for not a lot of money.
A low performance bipe like that makes a good first aerobatic trainer
because it will be easy enough to do the manuevers, yet difficult enough to
do them well, and a well built one should be just about unbreakable.
Bertie
Wow Bertie,
You actually gave helpful information without cussing and
making an ass out of yourself. Are you back on the meds?
Lou
Old December 17th 07, 03:37 PM posted to rec.aviation.piloting
F. Baum
Bertie- Hide quoted text -
How does it compare to the ACA Decathelon ?
Old December 17th 07, 06:09 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
The choice of a bipe aerobatic airplane that you can build and the
ramifications involved with the decision on which aircraft to pick is a
subject way too complicated for a simple thread here on the forum.
Without knowing your skill levels both flying wise and as a builder, and
assuming you might be at the novice end of the scale (no offense
implied; just picking the best scenario from which to advise you)
A Pitts can be a real handful for a novice and some others like the
Skybolt can be a handful for a novice builder.
My recommendation would be to consult with EAA initially and possibly
consider building an AcroSport. Paul Poberezny designed this plane and
he did that with the novice builder in mind. The plans are written in
plain English and in easy to understand terms. A lot of beginning
builders have built the AcroSport and were happy with its performance.
I believe you can now build it with either the M6 or a symmetrical wing
if you like inverted stuff.
There are several engine choices as well depending on your pocketbook.
This is just a general answer for you of course, and my suggestion to
contact EAA is a sound one. For someone considering building a plane of
any kind, EAA is a priceless resource whose value can't be calculated.
Lots of luck whatever you do.
Dudley Henriques
Old December 17th 07, 06:22 PM posted to rec.aviation.piloting
Stefan
Lou schrieb:
Wow Bertie,
Now if he only would learn how to properly trim a message...
Old December 17th 07, 09:14 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Lou wrote in
enough to do them well, and a well built one should be just about
unbreakable.
Bertie
Wow Bertie,
No-ope, always like this you're just too ****ing stupid to see through to
my sensitive side, asshole.
Bertie
Old December 17th 07, 09:15 PM posted to rec.aviation.piloting
Stefan wrote in news:1bcf7$4766be6e$d9a270c7
Lou schrieb:
Wow Bertie,
Sorry, that's against my code of ethics..
You should just be grateful i'm not still using my old sig file.
Bertie
My first aerobatic lesson Marco Rispoli Piloting 6 April 13th 05 02:21 PM
US Aerobatic Team MuscleBiplane Aerobatics 0 March 19th 05 10:28 PM
Aerobatic club Klein Aerobatics 1 February 9th 05 05:53 PM
Air-to-air aerobatic photos Daniel Karlsson Piloting 0 October 29th 04 11:51 AM
Air-to-air aerobatic photos Daniel Karlsson Aerobatics 0 October 29th 04 11:50 AM
