#41
On 19 Dec, 21:59, Marc Ramsey wrote:
Ian wrote: My glider does all sorts of things as it approaches stall. It gets awful quiet. The stick starts shaking. The vario plummets. If I manage to miss all these clear signs, why would a small flashing red light grab my attention? Because, unless you're offering an open invitation for me to fly your glider, I've flown a number that don't give such clear signs, particularly in landing flap. Fair point. Assuming you are current and can cope with wood, you are welcome to fly the Pirat! And can you imagine what would happen with a stall warning sounder? Pilots used to flying with gear-down warnings would anxiously check he undercarriage lever ... subconsciously pulling back to give themselves a bit more time ... Did I say anything about a sounder? Did I say you did? There has, though, been plenty of discussion of stall warning devices here in the past. Ian |
#42
On 19 Dec, 21:56, "kirk.stant" wrote:
The solution is simple: Just don't get slow on your turn to final. This has been hammered into my head since my very first flight, and it works for me. I don't see what an AoA instrument could add to this. If you are distracted enough to get slow with an ASI, then I see no reason why you wouldn't be distracted enough to get slow with an AoAI. ARGGG you just do not understand the concept. Oh well, fun discussion anyway. Could you explain a little more. The situation at the moment seems to be "every glider (bar a few primaries) has an instrument, which if given attention, will alert the pilot if s/he is flying too slowly on approach. Despite this, a few pilots manage to fly too slow and crash". If that started off ""every glider (bar a few primaries) has an instrument, which if given attention, will alert the pilot if s/he is flying at too high an AoA on approach", can you explain why it would not end "Despite this, a few pilots manage to fly at too high an AoA and crash". In short, why would pilots who ignore the ASI pay attention for an AoA meter? Ian |
#43
On 20 Dec, 01:55, J a c k wrote:
John Smith wrote: The solution is simple: Just don't get slow on your turn to final. Thank you, John. Go to the head of the class. Now, what is "slow"? That depends on the day. If wind shear is likely it will be significantly higher than on a calm day. Which means, of course, that on a windy day the safe AoA for the final turn will be significantly lower than on a calm day ... Ian |
#44
On 20 Dec, 02:09, J a c k wrote:
Ian wrote: Now, if all gliders had AoA gauges, you could jump from one glider to another and not worry about what the right approach speed is for the glider you happen to be in. Wouldn't I have to worry about what the right approach AoA was instead? The stalling angle of attack for a given class of airfoils is very nearly the same for each. So what? The right AoA for approach is determined by more than the stalling AoA... Ian |
#45
On 19 Dec, 23:33, Scott wrote:
I generally find that my attention is fully occupied while landing. If I had an AoA indicator, I would have to take attention away from something else to look at it (I always have the audio vario and radio off for the final approach). Would an AoA also indicator free up some of my attention, and if so, from what? If you are too busy on landing to watch an AoA indicator you must therefore be too busy to watch an airspeed indicator. How on earth do you get that? The ASI is one of the things which occupies my time on the approach. If I have to watch an AoA indicator it will have to be instead of something else. I don't have much time in gliders but in my powered plane, I usually glance at the ASI as I level the wings on final, then I just use visual (and wind noise) references to make the landing with an occasional glance at ASI as I start the roundout and flare. Yes, that's how I do it. What would you not do in order to watch an AoA indicator? Ian |
#46
On 20 Dec, 01:51, J a c k wrote:
Ian wrote: I generally find that my attention is fully occupied while landing. When isn't it? I always find myself falling behind somehow whenever I begin to merely enjoy the scenery. Oh, hard luck. Enjoying the scenery is one of the reasons I go flying. If I had an AoA indicator, I would have to take attention away from something else to look at it... There is a thing we in the game call a cross-check: look into it. Are you saying that I could look at another indicator without spending any less time on anything else? What do these things do - relativistic time distortion? (I always have the audio vario and radio off for the final approach). Now I get it, Ian: you are really a troll/FAA Inspector, here to roil the waters on r.a.s. We can play that game. FAA? What's that, left-hand-side-of-the-Atlantic boy? The vario-off mode is OK, if you must reduce the aural clutter, but please tell us how you believe that turning off a major link (radio) you have with one of the greatest hazards in flying (other traffic) is going to improve your longevity: and in the pattern, no less? Horrified minds want to know. "for the final approach" != "in the pattern" Any thing which reduces potential distraction during the most hazardous phase of flying is a Good Thing, in my book. Hearing gliders isn't nearly as important as seeing them. Ian |
#47
On Thu, 20 Dec 2007 01:55:25 GMT, J a c k
wrote: Now, what is "slow"? The simple fact that you arre still able to write this proves that you know what "slow" is... ![]() Bye Andreas |
#48
![]() Could you explain a little more. The situation at the moment seems to be "every glider (bar a few primaries) has an instrument, which if given attention, will alert the pilot if s/he is flying too slowly on approach. Despite this, a few pilots manage to fly too slow and crash". If that started off ""every glider (bar a few primaries) has an instrument, which if given attention, will alert the pilot if s/he is flying at too high an AoA on approach", can you explain why it would not end "Despite this, a few pilots manage to fly at too high an AoA and crash". In short, why would pilots who ignore the ASI pay attention for an AoA meter? Ian Ian, we appear to be comparing apples and oranges - you are talking about not stalling on final, while I am talking about being able to accurately thermal, and incidentally have a better instrument for flying accurate approaches. You are absolutely correct that anyone who ignores all the indications of an approaching stall will likely do the same when an AOA indicator is installed. That is a different issue altogether. What we AOA proponents are saying is that the cherished airspeed indicator is really a poor substitute for an AOA indicator in certain phases of flight - mainly low speed ones such as thermalling and approaches - where accurate flying is important. The fact that we do so well with airspeed just proves that gliders are really easy to fly, and pilots quickly learn the characteristics of their glider. Will an AOA guage make you a safer pilot, in a modern glider? Maybe a little; its funny how all power planes have to have an AOA (not airspeed) controlled stall warning device to be certified. In my experience, light power planes not really more susceptible to approach stalls than gliders, but there are more distractions - including that noisy thing in the front just waiting to quit! Yet they mandate stall warnings. Again, in my perfect glider, I would have a nice unambiguous AOA indication of Clmax (for thermalling), Approach Cl (say at 1.3 Vstall) - maybe change to this when the gear is down; and L/D max (flaps up). I don't need to know the specific stall AOA - there is no reason to be slower than Cl max so by definition I need to reduce AOA if I'm above that. But I do want to be able - regardless of my ballast load and bank angle - to slow to the most efficient AOA when pulling into a thermal. When faster than L/D max, I'm probably flying a McCready speed, which is not affected by AOA, and needs to be set using the airspeed indicator. Obviously, my opinion is colored by having actually flown airplanes with excellent AOA systems, and by my wish to optimise my soaring for XC and racing. I really think that within a few years someone will come up with a simple, low drag, accurate AOA system that will be adopted by the same group of pilots who eagerly adopted radios, TE, audio varios, glide computers, GPS, PDA moving maps, transponders, ELTs, traffic detection devices - all those "unecessary" gadgets that clutter up our cockpits but, in my opinion, make soaring safer, more efficient, and more fun. Cheers, Kirk |
#49
On Dec 20, 9:42 am, "kirk.stant" wrote:
....snip... Obviously, my opinion is colored by having actually flown airplanes with excellent AOA systems, and by my wish to optimise my soaring for XC and racing. ....snip... Cheers, Kirk Kirk, Could you summarize for me _how_ you used the AOA indicator in those aircraft, which aircraft and under what conditions ? I am curious to the actual use(s). Thanks Todd Smith 3S |
#50
On 20 Dec, 14:42, "kirk.stant" wrote:
Ian, we appear to be comparing apples and oranges - you are talking about not stalling on final, while I am talking about being able to accurately thermal, and incidentally have a better instrument for flying accurate approaches. I wonder how much "flying at Clmax" matters in good thermalling compared with "being in the right bit of the thermal"? Obviously, my opinion is colored by having actually flown airplanes with excellent AOA systems, and by my wish to optimise my soaring for XC and racing. I really think that within a few years someone will come up with a simple, low drag, accurate AOA system that will be adopted by the same group of pilots who eagerly adopted radios, TE, audio varios, glide computers, GPS, PDA moving maps, transponders, ELTs, traffic detection devices - all those "unecessary" gadgets that clutter up our cockpits but, in my opinion, make soaring safer, more efficient, and more fun. If it does these things I'll be all for it. If it costs less than twenty quid I may even buy one. As a matter of interest, how do you define "efficient" here? Ian |
