#91
Cats wrote:
On Dec 21, 10:42 pm, Ian wrote: On 21 Dec, 09:58, J a c k wrote: Ian wrote: Seeing other aircraft is often aided by hearing radio transmissions. Have you literally heard an aircraft you didn't first see? Are you remembering that in the UK we have a very limited range of frequencies, and that it is quite possible to be able to hear calls from gliders at several different airfields at once? I have on occasion wasted time trying to see the glider which has just called downwind at an airfield ten miles from the one I am about to land at. Ian Gliders at our airfield prefix their downwind call with 'XXX Traffic' so there is no doubt who they are addressing. OK. sometimes we get 'XXX Base' but it's still unambiguous. Snap. We make blind calls to "xxx radio" giving approach direction before joining the circuit and on downwind to give circuit direction and intended runway. This is in accordance with CAP 413, as all glider pilots using a radio should know. Anybody not prefixing the call to a typical glider field with "xxx radio" is in violation, so a light bollocking would be entirely in order. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#92
Mike Lindsay wrote:
Eric, Just a short observation. If you had an AOA you would notice an AOA increase as you open your spoilers while maintaining a constant speed and a decrease as you closed them. Wayne Why not? Surely the glider would be sinking quicker so the AoA would increase when you open your spoilers? I agree that, once stabilized at the original airspeed with brakes open the AOA will be a bit higher to compensate for loss of lift, but the AOA variation during the transition may depend on the glider type. Some gliders pitch down automatically and accelerate when the brakes are opened (G103). Others raise the nose slightly and decelerate as the brakes are opened, so require a good shove on the stick to hold the airspeed constant (Puchacz). Ditto an ASW-20 as you select landing flap. The waggling of the AOA needle may be quite different in these cases. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#93
Wayne Paul wrote:
"Eric Greenwell" wrote in message news:gi2bj.303$pi7.43@trndny02... Nyal Williams wrote: No one seems to have observed that the AoA is instantaneous whereas the ASI indicates what the aircraft was doing moments ago. I don't think this is true: all the ASI I've had or checked seemed to respond in less than a second. Surely that's fast enough to keep up with the glider? Just try blowing gently into a pitot and see how quick the needle is. If takes "moments" to respond, you should check the indicator and the pitot line. The reason we are told to "fly attitude and don't chase the airspeed" is it takes the glider a while settle down to a steady speed, not because the ASI is slow. Eric, Just a short observation. If you had an AOA you would notice an AOA increase as you open your spoilers while maintaining a constant speed and a decrease as you closed them. True, but the ASI is still indicating correctly, not lagging as Nyal seemed to suggest. So, do we fly the same AOA with the spoilers open as when they are closed? Supposed they are just "cracked" open, half open, fully open - do I need to know a different AOA for each spoiler position? And if I use landing flaps for the landing instead of the thermal flap setting, do I need to yet another list of AOA for different spoiler settings? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#94
On Sat, 22 Dec 2007 06:39:08 GMT, Eric Greenwell
wrote: Nyal Williams wrote: The inside wing; it travels a lesser distance while sinking the same amount as the outside wing. No one seems to have observed that the AoA is instantaneous whereas the ASI indicates what the aircraft was doing moments ago. I don't think this is true: all the ASI I've had or checked seemed to respond in less than a second. Surely that's fast enough to keep up with the glider? Just try blowing gently into a pitot and see how quick the needle is. If takes "moments" to respond, you should check the indicator and the pitot line. The reason we are told to "fly attitude and don't chase the airspeed" is it takes the glider a while settle down to a steady speed, not because the ASI is slow. That's precisely his point. Change the AoA, and the drag changes. Change the drag, and the glider accelerates (positively or negatively). Then the airspeed changes, and only then does the ASI get a chance to tell you about it. "Fly attitude and don't chase the airspeed" really means "fly AoA and don't chase the airspeed", but if you don't have an AoA indicator, you have to use the attitude as a substitute for AoA. And it's a second-rate substitute. rj |
#95
Ralph Jones wrote:
"Fly attitude and don't chase the airspeed" really means "fly AoA and don't chase the airspeed", but if you don't have an AoA indicator, you have to use the attitude as a substitute for AoA. And it's a second-rate substitute. Please pardon me if I sound a bit cranky, but how can attitude be a "second-rate substitute" for something that we don't even have? And what would a "first-rate substitute" be? Not a single poster here has flown with an AOA meter in their glider, except a few using yarn taped to the side of their canopy. Is that what we should be using instead of attitude and airspeed? "Show me the money". -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#96
Eric Greenwell wrote:
Not a single poster here has flown with an AOA meter in their glider, except a few using yarn taped to the side of their canopy. Is that what we should be using instead of attitude and airspeed? Actually, I have flown with the factory supplied AoA meter (differential pressure) in my DG-600, but I could never get the darn thing calibrated properly... Marc |
#97
Marc Ramsey wrote:
Eric Greenwell wrote: Not a single poster here has flown with an AOA meter in their glider, except a few using yarn taped to the side of their canopy. Is that what we should be using instead of attitude and airspeed? Actually, I have flown with the factory supplied AoA meter (differential pressure) in my DG-600, but I could never get the darn thing calibrated properly... Bummer. I'm still hoping we'll hear from some pilots with the newest DG 80x gliders, which has it as standard equipment (I think that's right...). -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#98
Marc Ramsey wrote:
Eric Greenwell wrote: Not a single poster here has flown with an AOA meter in their glider, except a few using yarn taped to the side of their canopy. Is that what we should be using instead of attitude and airspeed? Actually, I have flown with the factory supplied AoA meter (differential pressure) in my DG-600, but I could never get the darn thing calibrated properly... Marc One common problem with many arguments (not just on RAS!) is that people compare the status quo with an idealized world, and conclude that the status quo is flawed and must be changed. It seems to me this may be occurring in the AoA discussion -- many posters have compared a perfectly functioning AoA indicator with our slow and inaccurate ASIs, and concluded that AoA indicators are better. But perhaps in the real world AoA indicators on gliders would be even less accurate than ASIs? |
#99
Greg Arnold wrote:
Marc Ramsey wrote: Eric Greenwell wrote: Not a single poster here has flown with an AOA meter in their glider, except a few using yarn taped to the side of their canopy. Is that what we should be using instead of attitude and airspeed? Actually, I have flown with the factory supplied AoA meter (differential pressure) in my DG-600, but I could never get the darn thing calibrated properly... Marc One common problem with many arguments (not just on RAS!) is that people compare the status quo with an idealized world, and conclude that the status quo is flawed and must be changed. It seems to me this may be occurring in the AoA discussion -- many posters have compared a perfectly functioning AoA indicator with our slow and inaccurate ASIs, and concluded that AoA indicators are better. But perhaps in the real world AoA indicators on gliders would be even less accurate than ASIs? Insufficient evidence. Mine was a 17 year old analog electronic device hooked up to 17 year old plumbing. It sometimes seemed to work, but not consistently. Marc |
#100
Eric,
I should have been more precise in my comment. AoA, as shown by a piece of yarn will be much quicker than an ASI. The ASI will respond quickly, as you say, but it will not arrive at a steady-state indication for a few moments if the AoA change is considerable and abrupt. I have no opinion about AoA instruments, for I have never used one. In my youth, I saw one used on an inboard strut between the wings of a bi-plane; it was a blade type that floated in the air. The pilot swore by it. At 06:42 22 December 2007, Eric Greenwell wrote: Nyal Williams wrote: The inside wing; it travels a lesser distance while sinking the same amount as the outside wing. No one seems to have observed that the AoA is instantaneous whereas the ASI indicates what the aircraft was doing moments ago. I don't think this is true: all the ASI I've had or checked seemed to respond in less than a second. Surely that's fast enough to keep up with the glider? Just try blowing gently into a pitot and see how quick the needle is. If takes 'moments' to respond, you should check the indicator and the pitot line. The reason we are told to 'fly attitude and don't chase the airspeed' is it takes the glider a while settle down to a steady speed, not because the ASI is slow. -- Eric Greenwell - Washington State, USA * Change 'netto' to 'net' to email me directly * 'Transponders in Sailplanes' http://tinyurl.com/y739x4 * 'A Guide to Self-launching Sailplane Operation' at www.motorglider.org |
